displaying posts 226 to 250 of 497
Pages (20): first .. 9 [10] 11 .. last
Author Subject: Eddy's 306 V6 XSI
Post #226
That wishbone angle is pretty nasty with you having the subframe that low. Probably find it rolls a lot and scrubs the outside of the tyres.
Posted 9th Dec 2012 at 22:19
JWP EFi
Turbo Legend!
Post #227
car felt a bit vague, even from passenger seat lol, on and off the power it pulled off to left and right
Eddy, if you can make it up, the guy that does our welding will sort you out unless you have someone
in mind closer to home
Posted 9th Dec 2012 at 22:24
eddy_gti6
Post #228
Yes it scrubs theouter edge of the tyres like hell! Killed the ones on my wheels. Any way around it? Maybe some negative camber or if i can excend the ball joint somehow? Also as seb says when i accelorate quick or hit the littlest of bumps it trys to throw me off to one direction. Not much i can do about the subframe tho. I have lifted the engine around 15mm so i could maybe lift the subframe too but if i do it will give me less engine clearance and i wont be able to fit me engine tray as its very very close as it is.
Seb i could pop up over the new year maybe if i dont get anything sorted. Let me know about a price if you can Thumbs up
Posted 9th Dec 2012 at 22:31
JWP EFi
Turbo Legend!
Post #229
from what i saw earlier, your subframe spacers were about 30mm, maybe try taking 15mm off them
or more if clearance will let you???
probs about £40 to reangle your decat flange, i will see him tomorrow to get more accurate price, if i
had decent mig welder then i'd do it for you
Posted 9th Dec 2012 at 22:36
eddy_gti6
Post #230
Could maybe lift subframe but i want to keep the sump guard and i wouldnt be able to if i lifted the subframe. Will have to get it up in the air and have another good look at it
Posted 9th Dec 2012 at 22:45
pugheaven
Post #231
Could you not just buy the roll centre kit and bump stear kit??
I know it wouldn't help the shaft angle but at least it will get rid of the stearing issues
I'm having the same problem with the Dimma however I can't use the roll centre kit as I'm running 330 rotors and the ball joint hits, rose joints ftw Sad
Posted 9th Dec 2012 at 22:48
Post #232
Space the guard down, lift subframe.
JWP EFi
Turbo Legend!
Post #233
if you want to keep your guard then why not space it away from engine a bit
Posted 9th Dec 2012 at 22:51
JWP EFi
Turbo Legend!
Post #234
welsh beat me to it
Posted 9th Dec 2012 at 22:53
eddy_gti6
Post #235
Ah didnt think about that. By lifting the subframe will that help my steering issue?
Whats this centre kit and bump stear kit?
Posted 9th Dec 2012 at 22:56
JWP EFi
Turbo Legend!
Post #236
more tahn likely mate, worth i try
Posted 9th Dec 2012 at 22:57
pugheaven
Post #237
The roll centre kit is an extension of the ball joint spindle which in turn lowers the wishbone angle, the bump stear kit spaces the track rod down from the hub which lowers the track rod angle!
Both will help to get rid of the issues your having however the drive shaft angle will be the same, the only way to change that is to raise the subframe and by the looks of it you would have to raise the engine too!!
Lots of work, if the shaft are fine as they are I would just buy the kits and leave the subframe and engine as it is... Lower centre of gravityDunno
Posted 9th Dec 2012 at 23:03
calibra306
Post #238
eddy_gti6 wrote:
Need to get that decat modified to fit the v6 down pipes
have you heard a V6 without the cat? Proper excessive i must say!
Head turner definatly! Police tugger without a doubt! Be warned if you have not changed the log book!
I was in the other car Xsi before i took off the road and the police stopped me and checked the engine cause it sounded more sporty then it should from factory.
Only had a viper induction kit and scorpion exhaust fitted.... Jesus! Lol
V6 Power!
Faster I can go the better!
Posted 9th Dec 2012 at 23:07
JWP EFi
Turbo Legend!
Post #239
unlucky
Posted 9th Dec 2012 at 23:15
eddy_gti6
Post #240
You have a link to these pugheaven?
Posted 9th Dec 2012 at 23:46
calibra306
Post #241
unlucky
was standard engine as my V6 is in another car but was trying to make a point. You think they wouldnt bother checking under the hood but they do!
V6 Power!
Posted 10th Dec 2012 at 00:04
calibra306
Post #242
there was a manafacturer on here selling them but he said he was doing morE
They never surfaced and for sale thread never updated. Messaged a few times as i was looking at getting some.
http://www.306gti6.com/forum/showthread.php?id=146338
V6 Power!
Posted 10th Dec 2012 at 00:07
eddy_gti6
Post #243
Thanks mate. I will look into it Thumbs up
Posted 10th Dec 2012 at 06:09
calibra306
Post #244
Nice one, i thought id bump the thread as well which ya probably already noticed.
V6 Power!
Posted 10th Dec 2012 at 08:58
eddy_gti6
Post #245
May have to look at other things to do as it looks like he hasnt been on in a while. Sure i will be able to sort something out.
Posted 10th Dec 2012 at 09:57
24seven
Post #246
Who is it that makes the ball-joint "extenders" to correct the wishbone angle on lowered cars? Saw a thread in "for sale" a couple of weeks ago but I'm far too lazy to dig it out for you. Razz
Posted 10th Dec 2012 at 12:46
Post #247
CRF450 and allanallen, at bridgecraft engineering.
Posted 10th Dec 2012 at 12:50
eddy_gti6
Post #248
Whats this welshpug? Is that who i need to contact? Expensive at £95 a set but if its going to save me from changing tyres every other week then its money worth spending.
Posted 10th Dec 2012 at 12:57
Post #249
It would just be easier to sort the engine/subframe spacer issue out first is last than buying bits to "bodge" it Wink
Posted 10th Dec 2012 at 13:19
Post #250
Tracking will be out too after fitting coiloversYes
This will affect your handling a fair bitThumbs up
As above regarding sump guard,either space it out,or get it cut/re-welded lower just where the sump/exhaust are going to touchSmile
Posted 10th Dec 2012 at 14:28
