displaying posts 51 to 75 of 86
Pages (4): first .. 2 [3] 4
Author Subject: Argh Heater matrix
Post #51
Sad
It certainly sounds like it Dave, looks like the ol' girl will be getting ripped apart and a new HG fitted. Thumbs up
Posted 19th Nov 2012 at 07:23
davewagon
Post #52
Yeah cheers Stan
Do you know what the recommended cambelt kit is please? Something about teeth?
Team: Moonstone GTI-6™
Team: Working air-con™
ian7675 wrote:
Posted 19th Nov 2012 at 07:34
Post #53
Youre looking at 5-600, best belt is 136 from gsf, £60 for a decent branded item, if its 137 now you will need the stud the tensioner sits on
Posted 19th Nov 2012 at 09:40
Post #54
Dayco is the original belt manufacturer, and INA for the tensioners. However, you can pick up INA tensioners at most factors or SKF ones both are a good make.
For the belt either go for the Dayco, Gates or Continental. Yes
Posted 19th Nov 2012 at 10:30
davewagon
Post #55
So quotes came in, £600 + vat from a local garage, think Carl said something cheaper but still £500 + vat
Then a mate of a mate can do it as a sideline earner for £400 (but no receipt or comeback presumably)
Not sure how to proceed, it's the wrong month of the year for this to have happened really and I'm considering chucking the car.
What's a realistic price if sold for spares and repairs?
Dave
Posted 23rd Nov 2012 at 22:57
Post #56
£300-£400 really if it needs a HG and heater matrix. Yes
Posted 24th Nov 2012 at 07:14
swiftyboi006
Post #57
£300 and id take it to carl to be honest if hes cheaper. You could of course buy an engine from here £250-£300 fit it yourself
Black p3 Love
Posted 24th Nov 2012 at 09:34
davewagon
Post #58
Right well the HG has been repaired, including a skim and I've had the car back.
However the car (in my non-mechanic opinion) is now definitely tapping like a sewing machine!
So before I even attend to the heater matrix, I'll be wanting that sorted.
The chap who did the repair (not a garage, was cash in hand) said the noise was most definitely an oil lifter (?) that was probably stuck and would pop back into action once the car had gotten up to temperature and been run for about 50 odd miles (now done 80 since getting it back).
He said this usually happened when he repaired heads at Vauxhall (where he used to work).
He did say if it didn't clear, bring it back to him to get looked at again.
Sadly I think it is valve contact to a piston head and am going to ask him to repair it again
What sort of work will this require to correct, presumably new valves?
The head wont need skimmed again will it, and the new cambelt and water pump shouldn't need replaced again right??
Will it need new head bolts?
I don't plan to pay for the repair seeing as it his error to correct, but i'd like someone to give me an idea as to the cost of parts needed to sort it please?
I might offer to pay for some of the parts to ease things along (but maybe I won't!) - will see what he says first...
Posted 15th Dec 2012 at 13:07
davewagon
Post #59
Oh, is there any other reason it might make a tapping noise, just so i'm aware of any other bulls**t excuses (like friggin' oil lifters!!) that might come my way if the chap doesn't agree its valve contact.
Does he need any special tool to time it up correctly, that he may not have realised he will have needed?
It has PT80 cams, would that have caused confusion?
Posted 15th Dec 2012 at 13:09
Post #60
cams+skim = oh feck.
did he use a repair thickness gasket and how much was taken off?
Posted 15th Dec 2012 at 13:17
Post #61
did you tell him you had different cams?
Posted 15th Dec 2012 at 13:18
Post #62
also do you know 100% that the bottom pulley is good?
Posted 15th Dec 2012 at 13:20
Post #63
I very much doubt it's piston to valve contact that has caused it, it's probably valve to valve where they have tangled during installation and timing of the head. Yes Sad
Posted 15th Dec 2012 at 13:23
Post #64
are you sure stan?...
0.3mm skim and PT's...
worse case scenario of course....
Posted 15th Dec 2012 at 13:30
Niall
Post #65
seeing as you have cams, it does sound like some valves have tangled Sad
Dont rule out the tapping lifter though. When i did my cambelt, mine tapped like a goodun but after a good ragging, the lifters sorted them selfs out and its nice and quiet now. Take it for a seriously hard drive and see if it calms down.
davewagon
Post #66
I did say it had different cams (but I wasn't the guy to give him the car, so whether it was translated to him or not?)
Don't know about how much was skimmed, or whether a thicker gasket used?
As for bottom pulley, I have no idea what you mean, but the car should have the aluminium RichW pulleys??
Posted 15th Dec 2012 at 14:01
davewagon
Post #67
Hopefully this, I have yet to give it a good thrashing, which is what he recommended first.
I'll try that first, and see if I can rule the problem out
PT80s are incredibly mild though aren't they, not as aggressive as PT81's??
Posted 15th Dec 2012 at 15:43
Post #68
No, the inlet is identical to pt81.
Posted 15th Dec 2012 at 16:39
Post #69
That can't be purely down to cams though Mei, it's only affected one pot, the others are all untouched.
I suspect that failure was down to a 'tapper' where by the valve head snapped off.
Posted 16th Dec 2012 at 08:23
Post #70
Not untouched, all inlets were marked, you can see the ring aound them where theyve been rubbing.
I am not speculating here, this is hard evidence of how close to the wind many "respected" so called specialists are, and how clueless joe bloggs is.
Posted 16th Dec 2012 at 08:25
davewagon
Post #71
So can it be fixed
It'll be going back on Friday, but is I even worth it? Any idea of cost?
Posted 16th Dec 2012 at 08:53
Post #72
With already being skimmed and what could be contact I'd say you're gonna need another head possibly Sad
Posted 16th Dec 2012 at 08:56
Post #73
Buy my 77k engine for £350 and fit and forget Thumbs up
  • Posted 16th Dec 2012 at 09:00
    Post #74
    Buy my engine for cheaper than Dan's which has had a timing belt and clutch then fit and forget Wink LOL
    Posted 16th Dec 2012 at 09:02
    Post #75
    what ratty said.
    Posted 16th Dec 2012 at 09:47
