A modded phase 2?
| Author | Subject: Phase question |
fast_eddie
Regular Location: bradford Registered: 21 Jan 2012 Posts: 285 Status: Offline |
My gti 6 is on a 1998 t plate but has all the phase 3 bits on it.. Is there any way of finding out if it's a genuine very early on phase 3, or A modded phase 2? |
jeffers
Forum AdminLocation: Leeds Registered: 14 Dec 2003 Posts: 3,702 Status: Offline |
fast_eddie wrote: My gti 6 is on a 1998 t plate but has all the phase 3 bits on it.. Is there any way of finding out if it's a genuine very early on phase 3, or A modded phase 2? Its a modded phase 2 at a guess, if it was a phase 3 it would be may 99 onwards as that was the changeover month iirc, when you say all the phase 3 bits on exactly what phase 3 parts have you got on it? ________________________________________ Team Running Engine again!Team Negative Camber! My Budget track engine build thread! Now appearing at a Trackday near you!! |
Seasoned Pro Location: Southwark Registered: 18 Jul 2010 Posts: 4,865 Status: Offline |
Not really, a 1998 t would be a mix match of both phases as the stuffed the kinds of stuff on late phase 2'smy 1999 t is phase 3 through and through and though Do you have a rf key or an ir one? are you clocks silver with white needles? do you seats have airbags is you parcel shelf a stealth shelf, plenty more to look for. ________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
jeffers
Duplicate threads deleted! ________________________________________ Team Running Engine again!Team Negative Camber! My Budget track engine build thread! Now appearing at a Trackday near you!! |
fast_eddie
Thanks JeffersRF Key Seats with airbags Stealth Shelf Colour body rub strips Crystal lights Black dials white needles Any help? Cheers |
heliosphan
Senior User Location: UK Registered: 14 Sep 2007 Posts: 950 Status: Offline |
Most of that is bolt on parts, but the RF key suggests to me that it's a P3. What would be required to convert a P2 IR car to run RF? Doubt someone would've gone to the trouble. |
stan_306gti6
Is the tailgate a P3?Also, how is the throttle cable routed? Across the engine or along the rear of the radiator? These are more clues to look out for. ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
aaron6
Is there a guard on the aux belt?________________________________________ See the sheer power and might of the lesser known burrowing owl. |
fast_eddie
Ok , No guard on aux belt, although it looks like the power steering pump bracket has holes in it for something?Throttle cable across the top of the engine. Not sure how to tell the ph3 tailgate? Are we any closer ? Cheers |
swiftyboi006
Ph2.5 ________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
stu
Seasoned Pro Location: Milton Keynes Registered: 22 Aug 2006 Posts: 5,525 Status: Offline |
aaron6 wrote: Is there a guard on the aux belt? IIRC, the belt guards were removed by Pug. Due to some of them catching on the belt and causing the belt to fail. |
Rich E
fast_eddie wrote: Are we any closer ? If you sign up to Peugeot's Servicebox online parts system you can check what equipment the car left the factory with. (Or PM me the VIN and I can check for you) ________________________________________ Rich |
Rich E
Just to clarify though, if it was registered in 1998 then it can't be a phase 3.Phase 3 production began in May 1999. ________________________________________ Rich |
If only there was an FAQ on this...________________________________________ Black X Reg PIII.VGTi 6 A4212 pt 1 A4212 pt 2 Searching the streets of Bristol for 1.36p/day.Joint Kent Leader |
ian7675
Techno Viking Location: Gloucestershire Registered: 12 Oct 2007 Posts: 6,068 Status: Offline |
Surely you can't have a 1998 'T' It would be an 'S' running into 1999!________________________________________ Less than 24 hours to go! |
stan_306gti6
ian7675 wrote: Surely you can't have a 1998 'T' It would be an 'S' running into 1999!A very good point, it must be a 1999 car then in that case and most likely is a P3. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
rich306
Seasoned Pro Location: Portsmouth Registered: 09 Aug 2009 Posts: 1,834 Status: Offline |
What phase does this make my T-reg Rallye with the IR key then? I assume a ph3 due to the registration but other factors suggest otherwise. Or is it because it's made to be lighter that ph3 parts were restricted? ________________________________________ Richies Project RallyeElectrical work carried out in Portsmouth jamiek_uk2000 wrote: - Top Tip!!! You'll need to throw money at the car. Not on parts. Just stand near your car and throw loose change at it, I find this increases performance for a short period of time |
ian7675 wrote: Surely you can't have a 1998 'T' It would be an 'S' running into 1999!Depends when it was built and how long then it sat around before someone bought and registered it. ________________________________________ ![]() |
Who really gives a f**k? |
stan_306gti6
dangti6 wrote: ian7675 wrote: Surely you can't have a 1998 'T' It would be an 'S' running into 1999!Depends when it was built and how long then it sat around before someone bought and registered it. This is true to a point, but the *actual* date of manufacture is not taken into account on the logbook etc. So if the logbook states it's a 1998 then that will be the date of first registration. The fact that the car has ended up on a 'T' plate is even more confusing. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
T plate is 1999 so my magic beanz are on it being a phase 2.5 PBS/Thread |
jeffers
Rich E wrote: Just to clarify though, if it was registered in 1998 then it can't be a phase 3. Phase 3 production began in May 1999. This was what I was trying to say, mine is a may 99 and definitely a parts bin special. If its registered in 98 it can't possibly of started life as a phase 3 as production was may99 onwards for phase 3 so it has to be a modded phase 2 at best! ________________________________________ Team Running Engine again!Team Negative Camber! My Budget track engine build thread! Now appearing at a Trackday near you!! |
