displaying posts 176 to 200 of 205
Pages (9): first .. 7 [8] 9
Author Subject: GTi-6 - ITBs & CAMMED Track Car.. NOW ON EMERALD
Post #176
there's a single 62x55 washer on the rhs under the speedo drive housing against the right hand diff bearing, I've never needed to change from the original one.
they aren't on all boxes, and you can;t just buy one on its own, you have to buy a kit and set the pre load, I think the set of washers are about £20.
You all had me worried about this ....seeing as I'm fitting my 3j next week ?
Spoke to Miles who said ..not all boxes have shims or need them ....they used them !!!...then they didn't ...then they did again ...then they didn't .!!!!....it's a lottery he said Smile
Posted 7th May 2014 at 07:08
jammapic
Post #177
but how do you get the fuelling correct on all 4 cylinders without spending thousands on an ecu and fitting 4 wideband sensors?
Welshpug, do some reading into volumetic efficiency. We can work out exactly what the AFR is on each cylinder by looking at the power curves with different trumpet setups. We can then ensure the "mean" AFR coming out the tailpipe is rich enough to keep the cat cool, and also rich enough across all the cylinders to not cause issues.
dcc wrote:
It does exactly what you think it isnt.
can't help but think each cylinder is not working in balance with the others.
That's exactly what it's doing dcc, NOT working in balance, and thus giving me a totally smooth torque curve, removing the resonance you get with different trumpet lengths.
rallyeash wrote:
227hp! You'd be lucky!
Mines making that power with an 88mm steel crank, steel rods, 87mm forged pistons (2088cc), cat cam 109's, mild headwork from Sandy, Jenvey DCOE's, Colin/sandy long inlet manifold, 8 injectors, DTA E48 ecu, maniflow works exhaust manifold, 2.5' system, dry sump etc
I can only go off what the dyno told me. It said that stock, and just with a K&N and sports cat / exhaust system, I made 177hp and now, on the same dyno with all the mods, 227hp.
As I keep saying, I think the dyno is a touch optimistic... that said, I can't get away from the fact it's shown a 50hp gain, and the way the car feels I'd say that's right.
Why would Wayne Schofield of Chip Wizards lie?
rallyeash wrote:
In his defence there was something in PPC a little while back on walkers workshop about varied length trumpets and testing it all
Varied trumpets have been around for years. Look at the old Mclaren Can Am cars for example:
Multiple lengths gives you a better spread of torque and smoothed out resonance. Plain and simple. Read organ pipe tuning, volumetic efficiency, velocity stacking and then realise what a power run on a dyno ACTUALLY shows you (volumetic efficiency). From this, we can work out the dips and the troughs and use the AFR out the tailpipe to calculate exactly what lengths we need.
Once we've staggered the lengths, we can make sure we get the fuelling right and rich enough not to give us hot spots in the rev range.
JP
HDI Engine Tuning / Remapping Services - https://www.facebook.com/dervtech
306 GTi-6 Track Car - 200+ hp all N/A!
306 DTurbo Track beasty - 209.9hp - RIP
Posted 7th May 2014 at 09:26
Post #178
Or just build it properly and use less fuel.
Posted 7th May 2014 at 09:43
jammapic
Post #179
Build it properly? Absolutely no resonance in the torque curve whatsoever and smoother than any throttle bodied 306 I've ever been in? Hmmm.
Also, on the trip to the Nurburgring, I averaged 1mpg less than a totally stock GTi6. Doesn't seem to use too much fuel to me.
JP
Posted 7th May 2014 at 11:08
Post #180
not been in many properly build bodied 306's then...
Posted 7th May 2014 at 11:14
jammapic
Post #181
Maybe in your opinion. Of the ones I've been in, running all 4 trumpets the same length, aftermarket management etc, on Omex, DTA and Emerald, mine is smoother. I doubt the management has much to do with it, at the end of the day, they all have a VE table to do fuelling, and timing maps. It's more likely the trumpet lengths smoothing out the peaks, and filling up the troughs.
To be fair, it made more torque with all 4 trumpets longer, but soon after the peak, there was a dip, which made less. The staggered lengths smoothed that out.
I'm happy with it, it goes like the clappers and it seems to be working well.
The whole point of this thread was to show we don't all have to be sheep, and things can be done differently. I'd say I have proved that, stock management, staggered trumpets and certainly over 215hp on a stock motor. If people don't believe the numbers, fair enough, I'm not bothered, I have a feeling the dyno was a little enthusiastic... but when was the last time you saw one on stock management, with staggered trumpets etc run on the dyno? ;-)
JP
Posted 7th May 2014 at 13:29
Post #182
http://www.306gti6.com/forum/showthread.php?id=104582
Posted 7th May 2014 at 12:08
Post #183
I think Stef205 ran one on stock management also.
  • Posted 7th May 2014 at 12:29
    Post #184
    Fair play James, good effort on doing it slightly different and you seemed to of got decent gains etc Smile
    Posted 7th May 2014 at 12:50
    jammapic
    Post #185
    You missed an important bit out that I said welshpug, the staggered trumpets.
    I remember reading he did that on stock management, but with a bit of a botch to get it running with a map sensor still in place. Also, didn't he ditch the setup as it didn't work right in the end or bad fuel consumption or something?
    JP
    Posted 7th May 2014 at 13:24
    Post #186
    You appear to have edited that post now though as the posted time is later than Welshmugs.
  • Posted 7th May 2014 at 14:19
    jammapic
    Post #187
    Yes, I read it back to check I wasn't wrong and noticed a spelling mistake. I'm sure the admin would be happy to confirm I didn't change any of the detail.
    Jeez, you lot are pedantic.
    JP
    Posted 7th May 2014 at 16:06
    Post #188
    Any pictures James?
    Curious to see how much the 'bodies are staggered etc.
    Posted 8th May 2014 at 14:29
    Post #189
    There is nothing fundamentally wrong with a staggered trumpet setup, it's been used on more engines than I have digits to count on.
    Posted 8th May 2014 at 16:15
    jammapic
    Post #190
    cjm_harris wrote:
    Any pictures James?
    Try this. It took some maths and some trial and error to get the lengths just right. I really need to get you all the dyno plots from testing so you can see how well it works:
    Finally... Smile Knew you'd get it Philip... smoothing the torque curve, making the most of the setup you've got can only be a good thing, right? Smile
    Posted 8th May 2014 at 17:59
    rallyeash
    Post #191
    There is a company that make adjustable length ones. Would of made your life much easier.
    309 3dr K20 Type R
    Posted 8th May 2014 at 18:17
    superchargedblack1997gti6
    Post #192
    Should think you'd benefit now from a lowered custom radiator now wouldn't you jamma?
    Posted 8th May 2014 at 18:26
    jammapic
    Post #193
    Yeah, I probably would tbh. It's noticeably slower if you gun it after it's been sat running a while, as it pulls in all the hot air - then gets going after a few seconds.
    Posted 9th May 2014 at 19:54
    Post #194
    Emerald make them Yes
    Posted 9th May 2014 at 20:24
    jammapic
    Post #195
    Yeah, I saw those... but got the others free from Jenvey for testing! Smile
    Posted 10th May 2014 at 11:12
    jammapic
    Post #196
    OK, so after a tough few months in storage / workshop and then a hard trip to the Nurburgring, the shell was starting to look a little tatty as people has been leaning on it, dropping tools on it etc etc.
    So, had the Paintless Dent Removal guy come and knock a load of dents out, and a couple of touchups done with a little touchup pen and some wet sanding.
    Have also given it a full detail today, using poorboys stuff, machine polisher, and wax.
    Some up to date piccies.
    Pretty much ready for FCS now! :-)
    JP
    Posted 18th May 2014 at 13:47
    jimmyrallye
    Post #197
    Looks spot on mate but that number plate gets me everytime
    Posted 18th May 2014 at 16:43
    jammapic
    Post #198
    Good.. then it's doing it's job! Smile
    Some more outside in the yard after I'd cleaned hers too.
    Posted 18th May 2014 at 16:54
    jammapic
    Post #199
    OK, so backtrack a tad...
    I talked about using staggered trumpets to move harmonics in the torque curve, and make for a smoother power band and more area under the curve.
    But, they say the proof of the pudding is in the eating, so here it is.
    Here, you can see two dyno plots overlaid. The one which makes peak power at slightly higher RPM is with the shorter trumpets, and the one with power at lower RPM are the longer trumpets.
    You can see the shape of the curves are identical, but higher and lower RPM peak power. This is normal for longer and shorter trumpets. This is the key here.
    When we have two of the trumpets long, and two short, we effectly find a "middle ground" in the curves. This is helpful as we fill the troughs with power, but we do also lose our peaks - hence the peak power is marginally lower.
    What's important though, is area under the curve. Clearly, the more the better, and by filling the troughs we make the car smoother and more drivable.
    Below is the outcome of the staggered trumpets:
    We actually did find a little more power with some more ignition advance and leaning the mixture out a touch, but the shape of the graph remained largely the same.
    Posted 21st May 2014 at 20:06
    Post #200
    214 bhp and 177 ft lbs nice
    Posted 22nd May 2014 at 13:00
