displaying posts 151 to 175 of 205
Pages (9): first .. 6 [7] 8 .. last
Author Subject: GTi-6 - ITBs & CAMMED Track Car.. NOW ON EMERALD
jammapic
Post #151
If it uses the stock ecu, the answer is yes I expect. Give him a call on 07874328306.
HDI Engine Tuning / Remapping Services - https://www.facebook.com/dervtech
306 GTi-6 Track Car - 200+ hp all N/A!
306 DTurbo Track beasty - 209.9hp - RIP
Posted 14th Dec 2013 at 19:30
markylee
Post #152
Hi mate which cat cams did you use and did you need to change the cam pulleys
Posted 14th Dec 2013 at 21:05
jammapic
Post #153
Cat cams 106s. No, I didn't.
Posted 14th Dec 2013 at 21:07
markylee
Post #154
How much did pug1off charge to supply and fit
Posted 14th Dec 2013 at 21:26
jammapic
Post #155
Best of asking them what they charge for supply and fitting.
Posted 14th Dec 2013 at 21:28
markylee
Post #156
sorry mate, one last question, have you pocketed your pistons with them cams and has your head been skimmed
Posted 14th Dec 2013 at 21:31
jammapic
Post #157
No, and no.
Posted 14th Dec 2013 at 21:38
eddy_gti6
Post #158
What catcams are you running mate? Also are you running stock injectors too?
Will need to speak to wayne soon to have mine mapped again as the map on mine with the cat cams in isnt too good to be honest, seems to be running rich too. Also have my VLR BTCC inlet to fit so hopefully the map you have on yours may be good to run on mine
Posted 1st Feb 2014 at 20:13
jammapic
Post #159
Mines on throttle bodies mate - totally different map, he may be able to use bits of it though.
Definitely get on to him - and let me know when you are down there and I'll come say hey!
JP
Posted 1st Feb 2014 at 20:15
eddy_gti6
Post #160
Will do, hopefully be around mid march as I have a few other bits and bobs to sort out before mani can go on
Posted 1st Feb 2014 at 21:19
jammapic
Post #161
OK... so....
Got the car out of the mates' workshop, finished mapping it (227hp and 170lbft), then promptly MOT'd it and put it back on the ramp again. Lol.
Fitted a set of KSport adjustable coilovers, then stuck it on the Geo machine, setup camber, castor, toe etc before giving it a full corner weighting setup:
Finished fitting my electric PAS setup:
Also fitted solid engine mounts, solid rear beam mounts and sorted a few knocks and rattles from the suspension... then, finally... BROUGHT IT HOME!
We've lived in our new house since October, and this is the first time I've actually parked it on the drive here.
The drive home from the workshop was amazing. Was a little ginger with it at first, given it's been sat for a while... but when I did give it the beans, my god - it's quick.
Corner weighting the car showed up a few weaknesses, like the fact that 66% of the cars weight is at the front, and only 34% is at the back. However, cross axle is next to perfect.
Also, with half a tank of (stale) fuel, and a load of spare parts inside, the car weighs in at 984kg. I reckon without all the spare manifolds, spare wheels etc inside, it would probably be pretty damn close to 960kg.
Got the love back? Hell yeah.
Watch this space!
JP
Posted 6th May 2014 at 22:03
Post #162
200 lbft?!
Laugh my ass off
Posted 23rd Apr 2014 at 07:37
mcvite
Post #163
Very nice mate,well doneThumbs up
http://s1160.photobucket.com/albums/q486/mcvite/
Posted 23rd Apr 2014 at 15:30
allanallen
Post #164
What's the spec of the engine now jamma? I know r/r figures are nothing to go by but 200lbft is a hell of a lot of torque for a 1998cc 6!
Facebook
Posted 23rd Apr 2014 at 18:28
Post #165
Cat 106's running retarded in a skimmed head stock pistons and a load of bullpoop LOL
Posted 23rd Apr 2014 at 19:03
dcc
Post #166
so these figures you have, where exactly have you plucked them from? Hillary us.
205 GTI
Xsara HDI
Posted 6th May 2014 at 21:49
jammapic
Post #167
It's not 200lbft, I was wrong. It's just a touch over 170lbft, through the midrange and 226hp at 7000rpm, without much point revving it past that despite an 8000rpm rev limit.
I do think the dyno is a touch optimistic, however it is a fully calibrated Bosch unit.
Car has staggered inlet trumpets, some light headwork, total seal rings, arp rod bolts and acl main bearings.
JP
Posted 6th May 2014 at 22:02
dcc
Post #168
Why staggered? surely thats not going to help the balance of the cylinder power?
Good job on getting those total seal rings to work though!
205 GTI
Xsara HDI
Posted 6th May 2014 at 22:09
jeffers Forum Admin
Post #169
It's something to do with resonant frequencies affecting the inlet pulses or something, Pete Rallye had staggered trumpets on his btcc iirc...
Team Running Engine again!
Team Negative Camber!
Posted 6th May 2014 at 22:15
jammapic
Post #170
Moves the resonance in the torque curve out of phase to smooth it out. Read about organ pipe tuning....
I'll get the dyno plots if you like. You'll see one set of resonance for one set of trumpets, another resonance for another set, and then a third, smoothed torque curve for a mixture of both.
JP
Posted 6th May 2014 at 22:18
Post #171
but how do you get the fuelling correct on all 4 cylinders without spending thousands on an ecu and fitting 4 wideband sensors?
Posted 6th May 2014 at 22:32
RetroPug
Post #172
Surely having varied trumpet lengths isn't changing the mass flow rate of air being drawn in, hence no need for varied fuelling on different cylinders, it is just preventing the air induction for all four cylinders from resonating at once.
Posted 6th May 2014 at 23:10
dcc
Post #173
It does exactly what you think it isnt.
can't help but think each cylinder is not working in balance with the others.
205 GTI
Xsara HDI
Posted 6th May 2014 at 23:27
rallyeash
Post #174
227hp! You'd be lucky!
Mines making that power with an 88mm steel crank, steel rods, 87mm forged pistons (2088cc), cat cam 109's, mild headwork from Sandy, Jenvey DCOE's, Colin/sandy long inlet manifold, 8 injectors, DTA E48 ecu, maniflow works exhaust manifold, 2.5' system, dry sump etc
309 3dr K20 Type R
Posted 6th May 2014 at 23:28
rallyeash
Post #175
In his defence there was something in PPC a little while back on walkers workshop about varied length trumpets and testing it all
309 3dr K20 Type R
Posted 6th May 2014 at 23:30
