need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets.
| Author | Subject: Refitting box after clutch change - nightmare, please help! |
Post #51
I have seen it done, some guy on the 205 forum used a big pry bar and pulled the release bearing through the pressure plate ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Batesy86
Regular Location: Canterbury Registered: 12 Dec 2011 Posts: 138 Status: Offline |
Post #52
jonnie205 wrote: i cant see how you got the gearbox off in the first place without removing pin and rotating the arm, no wonder you couldnt get the box back on I took the pin out and spring off but couldn't get the arm off, the box just wiggled off... |
Post #53
welshpug! wrote: I have seen it done, some guy on the 205 forum used a big pry bar and pulled the release bearing through the pressure plate ![]() Wasn't me was it I have done that in the past 4 foot bar FTW.________________________________________ ![]() |
Post #54
Batesy86 wrote: jonnie205 wrote: i cant see how you got the gearbox off in the first place without removing pin and rotating the arm, no wonder you couldnt get the box back on I took the pin out and spring off but couldn't get the arm off, the box just wiggled off... The shaft probably twisted in the arm. Try getting the pin in now - I imagine it's moved around when you wiggled. ________________________________________ ![]() |
Batesy86
Post #55
Looks like it may have. Just got in from work with a view to get the arm off, but it won't budge, big lever bar under it and no movement at all, even with a shock from a hammer too |
Post #56
trip to a scrappie then off with the angle grinder it is then ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Batesy86
Post #57
Other models use the same arm? |
Post #58
yes, loads.namely 1.9 turbo diesels in lots of other PSA vehicles. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
stan_306gti6
Post #59
The arms themselves aren't actually that dear from Pug. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
Post #60
stan_306gti6 wrote: The arms themselves aren't actually that dear from Pug. ![]() indeed not, only £53 + vat. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Batesy86
Post #61
Don't suppose 206 gti box has the same arm? |
Post #62
no, very different, pokes out of the front of the box, pivots on a ball and is actuated by a hydraulic slave cylinder.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Batesy86
Post #63
I've had a breakthrough, literally. Good and bad I guess... |
Batesy86
Post #64
Hit too hard out of frustration and the bottom of the fork must've smashed through the bottom. Also that metal ring fell from somewhere... |
rikky
Post #65
i've also just been out to see if my top arm comes off my 1.6 gti 205 box and it won't. likewise i smashed both top and bottom bushes out so it cleared the input shaft and came out the top so i have better access to getting the pin out. seized solid and i have about 1.5mm each side to work with. nice________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
stan_306gti6
Post #66
Oh dear, I guess you hit the fork shaft downwards and it came out the bottom?________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
rikky
Post #67
me? or him? he probably did. i had the box in the boot of my 205 and removed the bushes so i had movement (deliberately) so i can get some oxy acetylene or a drill in there________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
Batesy86
Post #68
stan_306gti6 wrote: Oh dear, I guess you hit the fork shaft downwards and it came out the bottom? Indeed. Got some pug ones today though. Got 2 hours without the missus tonight I'm hoping the get the bushes in and fork clipped on the bearing an bolted up atleast. Fingers crossed! |
stan_306gti6
Post #69
![]() Yes Rikky, I meant Batesy. ![]() Hopefully, now that you.ve got the arm off and you can fit new bushes etc you should be able to get it on fairly easily. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
Batesy86
Post #70
Boom, it seems to be on, went to test it before putting all bolts in etc and the cable has come off the pedal, can't see where it's gone either or how it goes back on :/ |
Batesy86
Post #71
Maybe found it, bit white rectangle on the pedal end? How does it reattach? |
rikky
Post #72
yeah________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
tvrfan007
Seasoned Pro Location: In the garage Registered: 29 May 2005 Posts: 3,488 Status: Offline |
Post #73
On the top of the clutch pedal is a hook that you slot the white rectangle onto.________________________________________ I'm Si btw![]() Night Blue VW Golf GTD Bianca LBSC Rallye - Track/Road Slag Project Thread Sparkling Silver Mini Cooper D - Super Dooper - (The other half's wheels) |
Batesy86
Post #74
Oh yeah, it feels like it just sits in there, or is it meant to clip in with a bit of force? Pedal now operates arm with some resistance, although not the same as prior to starting |
Post #75
no, just sits in there, when connected to the clutch it can't come off, unless it breaks.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
