displaying posts 26 to 50 of 139
Pages (6): 1 [2] 3 .. last
Author Subject: Refitting box after clutch change - nightmare, please help!
Batesy86 wrote:
Even if I left the box hanging half out because my arms were ruined?
Yeah, plate won't have moved.but you might have damaged somethingSad
Posted 15th Oct 2012 at 22:50
Batesy86
Can get the box to slide on and off freely now just need to line bearin up. I presume as you look down then gaps in the bearing for fork are meant to point bulkhead side?
Posted 16th Oct 2012 at 19:06
no, rad side, if its a Valeo or luk unit it will say top....
Posted 16th Oct 2012 at 19:21
Does it? I've fitted loads of Valeos and never seen the word "top" on the bearing...
Handy if they do though and you're unsure. Yes
Posted 16th Oct 2012 at 19:29
Batesy86
Ok so on the pic below (sorry for stealing pic off someone) the left hand side of the bearing has to be rad side when fitted? And does it have to be positioned so the gaps are lined up parallel vertically? If so when I try that the fork just pushes the box back towards the wing!
Posted 16th Oct 2012 at 21:17
Slide your clutch on to the input shaft and when you move the fork you will soon see how it needs to go Thumbs up
  • Posted 16th Oct 2012 at 21:22
    That's it indeed.
    the fork should be at about 45 degrees to the input shaft, and as you move the box towards the block it will slide behind the bearing
    Posted 16th Oct 2012 at 21:23
    Batesy86
    Do you lift the lever arm halfway up at the same time?
    Posted 16th Oct 2012 at 22:44
    what?!
    the clutch lever arm shouldn't be on till the box is bolted to the block.
    Posted 16th Oct 2012 at 22:56
    pete_rallye
    Post #35
    You won't get it on with the clutch arm still attached, at least I've never managed too! You need to remove the arm to allow the fork enough movement to line up with the bearing as you put the box back on. PS. Good luck getting the pin out!
    Lap of the 'ring
    Posted 16th Oct 2012 at 22:58
    Post #36
    Must of taken arm off to get the box off ?
    Posted 16th Oct 2012 at 23:03
    Post #37
    big fate case of RTFM Doh
    Posted 16th Oct 2012 at 23:10
    Post #38
    Unless he bent it up, yes. Yes
    Posted 17th Oct 2012 at 06:19
    Batesy86
    Post #39
    The box came off with the lever arm still on, I can't get it off, how is it attached to the fork? I've taken the spring and the pin out but the arm won't seperate from fork!
    Posted 17th Oct 2012 at 08:51
    Post #40
    If you have removed the spring and pin, then corrosion will be the only thing holding it on. Keep twisting it while lifting.
    I'm guessing the hole isnt lined up with the pin hole still, as it would have moved around when you wiggled the box to get it off as the shaft moves around a bit to get the fork from behind the bearing. Hence why when people leave the arm on with the pin through it, it will foul on the casing and not release easily without bending it out the way.
    You have a couple of options I suppose. Wiggle the arm off the shaft and break the corrosion grip. Use a drift to whack the shaft down while using a pry bar under the arm so it shocks the corrosion free.
  • Posted 17th Oct 2012 at 09:15
    Post #41
    just don't hit it too hard or you'll crack the casing...
    Posted 17th Oct 2012 at 09:24
    Batesy86
    Post #42
    The arm itself is it hollow at the top, I.e the top of it you can see is that lever or fork?
    Posted 17th Oct 2012 at 10:22
    Post #43
    the arm is a flat plate bent to shape with a tube welded into the end that slides over the shaft.
    Posted 17th Oct 2012 at 10:31
    Batesy86
    Post #44
    So the rusty top bit is part of the arm not the fork?
    Posted 17th Oct 2012 at 10:43
    Post #45
    no, that's the top of the shaft the fork is welded to.
    also you should buy a pair of bushes.
    Posted 17th Oct 2012 at 10:45
    Post #46
    WP has described it perfectly well.
    One piece shaft with a fork you're struggling to get behind the bearing. That's one item.
    Arm is another. As mentioned, it has a tube which slides over the shaft, with holes that will line up with the hole through the shaft.
    It comes off.
  • Posted 17th Oct 2012 at 10:50
    Batesy86
    Post #47
    Ok I'll have another go at getting it off, thought the IB was the worst bit!
    Posted 17th Oct 2012 at 11:50
    Post #48
    Not only does the arm come off, it HAS to come off for you to complete this job. Yes
    Posted 17th Oct 2012 at 12:03
    Post #49
    the arm is a bas**rd if it's stuck. i couldn't get the pin out on one (had no access to heat either) so bent the arm slightly. got a 205 box on my floor at the moment which i removed with the arm still on but the bearing was smashed to bits LOL so got that to remove before i put it all back together
    Posted 17th Oct 2012 at 12:13
    jonnie205
    Post #50
    i cant see how you got the gearbox off in the first place without removing pin and rotating the arm, no wonder you couldnt get the box back on
    Posted 17th Oct 2012 at 13:42
