displaying posts 76 to 100 of 132
Pages (6): first .. 3 [4] 5 .. last
Author Subject: Richies Project Rallye
rich306
Post #76
Gaaah More rust!!! Just a little more severe this time.
Don't you ever get that moment when you wish you hadn't poked anymore with the screwdriver and found more holes??
Looks like this might need welding at some point!!
Rust treatment doing its work:
jamiek_uk2000 wrote:
- Top Tip!!!
Posted 27th Dec 2012 at 16:53
ed_doe
Post #77
It's this sort of resto projec that makes me seriously worry about the integrity of the underside of my '6 :S
'97 Black Dturbo 110,000miles: SOLD
'99 Ph3 Diablo Gti6 108k RIP
'93 106 1.5n/a d: daily hack YAAAAAWN
'00 Ph3 Astor GTi6 117k Love
Posted 28th Dec 2012 at 13:33
rich306
Post #78
The sooner you crack on with the underside the better though. I'm just drilling new holes for the heat shields and undersealing atm. Wink
- Top Tip!!!
Posted 28th Dec 2012 at 14:00
Post #79
So many cars are going at those points these days due to idiots jacking them up on the wrong points etc Sad
*EDIT* and you'll need to sort it out asap as thats deffo an MOT fail Wink
Posted 28th Dec 2012 at 15:03
rich306
Post #80
What? the welding of the holes?
I've already treated the rust and now it has a fresh coat of underseal on the Chassis. Smile Pictures will come soon.
- Top Tip!!!
Posted 28th Dec 2012 at 15:26
mik
Post #81
That needs more than some Kurust and underseal.
I've just had these crossmembers on mine cut off and replaced with new metal as, like yours, some bellend quite early in the car's life had jacked my car up on these and stoved them in (maybe even at the dealer where they were both sold new!), damaging the paint and allowing rust to start and holes to form.
The guy who did it for me said it was not a big job to fix, the metal was easily formed with basic tools, using the old ones as a template. The new metal was primed with Etchweld weld-through primer before installation, then seam sealed, stone chipped and wax injected after. Now good as new.
EDIT: In my case it needed the subframe dropping to get the welder under the subframe corner, but I was replacing my subframe anyway.
I pulled up the carpets and bent the floors down flat (also bent up by wrong jacking so carpets didn't fit properly) before welding, then zinc primed and after welding painted the inside where there was a bit of paint blistering.
The old metal after being cut out was rusty on the inside. If you are keeping the car indefinitely, I'd get it done now while it is a simple enough job.
I also remember the feeling of wishing I hadn't uncovered it.
Cherry Rallye SOLD
Posted 28th Dec 2012 at 18:04
rich306
Post #82
I'm gonna have to wait a little while before i get it welded, might pay Daveyboy a visit in Southampton one weekend to get it sorted.
I will be keeping the car for as long as i can afford it, so it will need to be done.
This is a more temporary fix in order to preserve it a little longer until i can afford to get it cut out and welded.
Cleaned up the rear end, however i need to take off the Rear beam at some point due to rust on the mounts. Also enables me to completely respray the entire underneath. Probably will take down the Fuel tank as well.
- Top Tip!!!
Posted 28th Dec 2012 at 18:36
rich306
Post #83
List now updated:
Engine Bay:
- Take engine out and remove rust followed by treatment and respray of bay.
- Clean up and spray Engine removing corrosion
- Service and replace Cambelt
- Move Air Induction kit
Interior:
- Repair/Replace Radio head unit
- Sew Drivers seat up
- Move Amp and tidy up wiring
- Fix interior light
Exterior:
- Replace droplinks
- Find and sort exhaust leak
- Refurb Cyclones
- Fix Trolley dent on N/s Door
- Push out dent on O/s door
- Damage on N/s Mirror
- Clean and paint 2 minor rust spots on Bonnet
- Replace morrettes with Crystals
- Replace Fog lights with Rallye Blanks
-Polish the car and wax it
- Top Tip!!!
Posted 28th Dec 2012 at 18:41
eskiiboi
Post #84
Such a shame about the rust Sad
I had a 106 Rallye a few months back and did the same, shell had done 165k so started poking underneath to discover there was a huge hole near the wishbone mount
An easy fix though and you will have stopped it starting anywhere else Smile
Posted 28th Dec 2012 at 21:14
rich306
Post #85
That was the main aim for getting under there, i'm sure there is more rust around the crossmembers but... i did expose all that i could find and treated it. Fingers crossed it will have sorted it out as the metal underneath the rust seemed solid.
- Top Tip!!!
Posted 29th Dec 2012 at 03:12
rich306
Post #86
Spent some monies today Sad
Bought myself a replacement Spare wheel carrier bolt
And found myself tempted by some mint condition Crystal headlights for £36 from a scrapyard.
I wanted to black mask them, so i did Wink
Same colour as my Cyclones will be going
Photo of the old headlights with standard bulbs
Can tell the difference with the new Osram Nightbreaker bulbs, much better clearer headlights!!
Will get a better photo of the Black masked headlights tomorrow.
Not bad for a second time of doing this to headlights huh?
- Top Tip!!!
Posted 29th Dec 2012 at 22:48
Tallguy_2
Post #87
How long did the lights take?
"winners come and go but legends never die..."
autorite-sport.co.uk
Posted 29th Dec 2012 at 22:59
ash j
Post #88
They took about 4 or 5 hours in total for the pair, not bad going!
Posted 29th Dec 2012 at 23:06
rich306
Post #89
I might start making a business out of them Wink
- Top Tip!!!
Posted 29th Dec 2012 at 23:10
7057sam
Post #90
Yeah you can make me a pair Smile
Team rallye,built for track
Rallye dead Sad
Secret Team Astor...
Posted 30th Dec 2012 at 00:06
rich306
Post #91
It'll be quite expensive, as there is quite a lot of hard work and supplies that go into this to achieve such a good standard.
I'll have to track down some decent lights (unless you send me some) and once done - send it back to you. Smile
- Top Tip!!!
Posted 30th Dec 2012 at 00:16
mik
Post #92
Black mask headlights on a red or black Rallye are the duck's nuts.
Going to have to sort a set for mine.
Cherry Rallye SOLD
Posted 30th Dec 2012 at 09:56
Takedown
Post #93
Nicely done mate!!!! looks ace
Posted 30th Dec 2012 at 10:27
rich306
Post #94
Just waiting on the cyclones being painted and put on the car now. Smile
Used Autoglym products to clean and bring her up to a shine!
I also painted the Peugeot badge whilst i had the paint out from the previous night! Big grin
What do you think?
Mik - You able to do the black masks yourself or do you need a set done for you? Wink
- Top Tip!!!
Posted 30th Dec 2012 at 17:41
rich306
Post #95
Also forgot to write that i've changed the numberplate too Wink
- Top Tip!!!
Posted 31st Dec 2012 at 18:18
silky
Post #96
What colour clones you gonna put on?
Posted 1st Jan 2013 at 10:36
rich306
Post #97
Black with a Red Pearl in the paint so that it shines Red in the sun Wink Same as a couple of pages earlier! Smile
- Top Tip!!!
Posted 1st Jan 2013 at 11:53
eddy_gti6
Post #98
Just need some brighter bulbs now Big grin
Posted 1st Jan 2013 at 17:29
phil b
Post #99
Thumbs up Thumbs up LOL LOL Thumbs up Thumbs up
'97 PH1 'Sigma Blue' 306 GTI 6 project 'Tooters'
194.2bhp 127.6 dB
'96 PH1 'Black Noir' 306 DTurbo (project in permenant storage)
'94 300tdi LR Discovery (project gone dead and buried)
'99 td5 LR Discovery 2 (trailer tug and family bus) project 'in the garage getting chassis welded' (again)
The 6 can go fast, the disco can go anywhere
Built: 9 January 1997 - that's a Thursday
Skip Brown cars: tarporley Cheshire Tel: 01829 720492
add me --> philbrindley85@hotmail.com
TEAM: Snapper Sad
Posted 1st Jan 2013 at 22:30
rich306
Post #100
Laugh my ass off You gonna send me some? Wink
- Top Tip!!!
Posted 1st Jan 2013 at 23:32
