displaying posts 101 to 125 of 163
Pages (7): first .. 4 [5] 6 .. last
Author Subject: idle and low revs issue, loads replaced no joy..CONTINUED
Post #101
Fingers Crossed Smile
Posted 20th Aug 2012 at 16:29
Post #102
Keep us posted mate, here's hoping for you. Smile
Posted 20th Aug 2012 at 16:31
BlackSix
Post #103
i dont know how a nice one runs tbh, dont really come into contact with many that was the appeal.
just disconnected my fpr and i can smell fuel at the nipple at the end. i know theres fuel near it, but i shouldnt smell it should i?
edit: more weirdness.....the top of the fpr says 300kpa, but elsewhere says 4bar.....300kpa is 3 bar lol.
all i can be sure of is its overfueling
Posted 20th Aug 2012 at 16:39
Post #104
Glad the injector swap was worthwhile even if it didn't resolve your problem alone.
Let's hope the FPR finally sorts it.
  • Posted 20th Aug 2012 at 16:52
    BlackSix
    Post #105
    oh yeah, well worthwhile considering the 4 that were on it werent even the same as each other let alone the ones you sent me. the numbers were different
    Posted 20th Aug 2012 at 16:53
    woody.
    Post #106
    How much have you spent on all the sensors in the engine bay? As said, it'll run better than ever with all these new parts! LOL
    Posted 20th Aug 2012 at 17:01
    BlackSix
    Post #107
    ermm...ALOT haha lost count tbh.
    just got to hope this cures it otherwise ive got to get it in for a full diagnostic Sad
    Posted 20th Aug 2012 at 17:03
    Post #108
    I hope it cures it too. Yes
    I really can't think of anything else which would be causing such issues...LOL
    Unfortunately a full diag will not be cheap, so therefore with a bit of luck the new FPR will solve it...finally, here's hoping. Smile
    Posted 20th Aug 2012 at 23:15
    BlackSix
    Post #109
    full diag including rolling road run if needed = £65+vat and thats using all diagnostic equipment they have
    Posted 21st Aug 2012 at 00:12
    Post #110
    To be fair, that's not a bad price for what you're getting.
    Hopefully though the new FPR will solve it and won't need to go down that route. Smile
    Posted 21st Aug 2012 at 06:29
    BlackSix
    Post #111
    well, on my way out to the motor factors, every time i came to a stop it was shuddering like crazy you could feel it quite violently through the car.
    got to the motor factors, picked up the fpr and fitted it straight away. the vacuum hose stank of fuel, quite strongly which i think shouldnt happen.....
    the bottom of the fpr was spinning freely. might crack it open later just to have a looksie whats inside it.
    drove home, came to a stop a few times and it didnt do it again, just the occasional bobble which im told is normal for these engines. is this correct?
    got home, whipped the vacuum hose off and it didnt even slightly smell of fuel. s not only was the old one wrong, it was busted (i think0
    currently got the battery terminals off to do an ecu reset. my thinking is that if the ecu is still trying to lean down the mixture, it still might not be running right so it cant do any harm to reset it Big grin
    fingers crossed
    Posted 21st Aug 2012 at 11:33
    BlackSix
    Post #112
    took it for a drive after putting battery back in and.....
    it seems alot better but time will tell. the really rough feeling like its going to cut out at any point is defo alot less, but the "shudder" is still there
    Posted 21st Aug 2012 at 14:14
    woody.
    Post #113
    Is anyone local to you that can go out in the car with you? Might just trigger something that you haven't thought of?
    Posted 21st Aug 2012 at 15:40
    BlackSix
    Post #114
    managed to get a pic of teh sparky plugs.... all look like this now
    Posted 21st Aug 2012 at 16:45
    Post #115
    What type are they, NGKs?
    But which actual type?
    Posted 21st Aug 2012 at 16:51
    BlackSix
    Post #116
    just ngk motor factor plugs
    Posted 21st Aug 2012 at 16:52
    Post #117
    I'm only 30 mins from Northampton if it's any help? Dunno
    Posted 21st Aug 2012 at 16:55
    BlackSix
    Post #118
    that would be great actually, thanks for the offer
    Posted 21st Aug 2012 at 16:56
    Post #119
    No problem, I spend most of my working day in and around Northampton, could have a look for you and see if it runs anything like normal?
    Posted 21st Aug 2012 at 17:10
    BlackSix
    Post #120
    yeah that would be great Big grin
    Posted 21st Aug 2012 at 17:12
    Post #121
    Thumbs up
    See how you get on with the diag check tomorrow first. I am in Northampton next on Thursday, so could meet you then if it's still having issues. Smile
    Posted 21st Aug 2012 at 17:17
    BlackSix
    Post #122
    diagnostic LOL he tried to say the idle was totally normal and my clutch was on its way out...conveniently they could replace it then and there for £450 +VAT.....
    i invited the guy outside, put the car in second with the handbrake up and the car moved without a hint of clutch slip which prompted much umm and arrr before i told him to get the f**k out of my car....
    he also mentioned that my crankcase breather hose is cracked...would that cause this type of issue?
    i went to somewhere i actually trust (he has alot less diagnostic equipment to use) and he wants to check the timing isnt a tooth retarded which he wants to to on friday afternoon....
    Posted 22nd Aug 2012 at 13:41
    Post #123
    Crank case breather could cause issues,as its connected to the inlet manifold.
    Bang some tape around it for a temp fixThumbs up
    Posted 22nd Aug 2012 at 14:11
    BlackSix
    Post #124
    yeah will do that bud.
    hmm....bad running from crankcase hose spilt?
    Posted 22nd Aug 2012 at 14:21
    Post #125
    plastic helmholtz resonator behind the inlet ok? although mine caused mad idle rather than misfiring
    Posted 22nd Aug 2012 at 14:25
