displaying posts 1 to 25 of 163
Pages (7): [1] 2 3 .. last
Author Subject: idle and low revs issue, loads replaced no joy..CONTINUED
BlackSix
hey all, i bought a gti 6 quite recently and its got a fault.
when left to idle it misfires. the misfire gradually gets worse until you can feel the whole car shaking. it feels like theres the occasional misfire at around 2k rpm using light throttle.
the fault code that comes up is lambda malfunction type 2.
the parts that have been replaced are :
idle control valve
MAP sensor
throttle positioning sensor
green coolant temp sensor
lambda sensor (also tested, getting 12v from heater element)
coil packs
spark plugs
fuel pressure regulator
ive also unplugged the injectors one by one to see if the problem stayed the same while replicating the fault, no joy.
there are no vacuum leaks, tested at idle and at 3k rpm by spraying brake cleaner all around the inlet side and connected hoses.
any ideas on what to try next?
Posted 30th Jul 2012 at 17:28
smegal
Check that the exhaust isn't blowing.
I would also check the coolant level perhaps getting a garage to do a "sniff test" in case it it the head gasket.
Ex SC-6
Now in a Megane R26
Posted 30th Jul 2012 at 17:38
BlackSix
knew there was something i forgot to add. coolant level hasnt moved since i replaced the thermostat and topped it up, was sniff tested and found nothing.
the exhaust isnt blowing either (another part ive had to replace)
edit: its been tinkered about with today a fair bit, but the same fault code keeps returning after about 5 mins at idle. the EML stays off
Posted 30th Jul 2012 at 17:46
Timing?
  • Posted 30th Jul 2012 at 17:51
    BlackSix
    it was doing it when i got the car and have since had a cambelt kit and water pump fitted. the locking pins just went straight in.
    its a really weird problem because when you start it youd never think there was a problem. then after a minute or so it starts missing once in a while and shortly after you can see it shaking the whole car.
    quick blip on the throttle sorts it out for a minute or so before it all starts again.
    there definitely doesnt seem to be any loss of power either and it starts first time
    Posted 30th Jul 2012 at 17:55
    Bottom pulley a good one?
    Any sign of head rebuild? Valve seals?
  • Posted 30th Jul 2012 at 17:57
    BlackSix
    the history says its had a head rebuild in the past but that was 60k miles ago. bottom pulley looks fine
    Posted 30th Jul 2012 at 17:59
    BlackSix
    something that has been suggested is the ECU. would this cause these issues?
    Posted 30th Jul 2012 at 19:37
    From the symptoms you describe, it definitely sounds like a lambda issue...Yes
    Have you got any idea what kind of MPG you're getting?
    I know you said you have replaced the lambda, but it is possible that the wiring that leads to it has been damaged and therefore the engine is acting as if the sensor is playing up. Have you checked the supply wiring to the sensor to make sure it hasn't been chaffed/damaged/cut? Unsure
    Posted 30th Jul 2012 at 19:54
    BlackSix
    ive only run through 2 tanks of fuel since i got the car, got 30 and 33 mpg measured by brim to brim method.
    from what i can see there isnt any damage to the wiring. im starting to worry because according to the only wiring diagram ive seen, 3 of the wires go to the ecu and the other goes to the engine bay fusebox (checked all fuses there, all fine)
    the amount of the sensor wiring i can see isnt great though tbh. with it hooked up to diagnostic machine it looks like the ecu is reading the lambda as the reading is constantly changing.
    Posted 30th Jul 2012 at 20:01
    Try changing the power steering sensor bud ? Seen them cause all sorts of running problems when on the way out Thumbs up
    Posted 30th Jul 2012 at 23:27
    BlackSix
    i did try unplugging that earlier, didnt do anything. does it bring up its own fault code?
    i do remember seeing something to do with wiring that i wasnt too sure about, will check it in the morning
    Posted 30th Jul 2012 at 23:32
    This was going to be my next suggestion, although they generally cause stalling issues rather than a misfire.
    Posted 31st Jul 2012 at 10:45
    Yes it does usually. Yes
    Posted 31st Jul 2012 at 10:48
    BlackSix
    the only code stored is lambda malfunction type 2.
    i disconnected the lambda sensor earlier, made no difference at all so does that point to a lambda fault?
    Posted 31st Jul 2012 at 17:10
    Yes it does...as I said I suspect some sort of damage to the wiring perhaps if the sensor has already been replaced...Wink
    Posted 31st Jul 2012 at 19:10
    BlackSix
    so what would be the best method to test the wiring?
    and do you have any idea of what values i should be looking for it i were to disconnect the pug and test each pin to earth?
    edit: just in case....what way round is it meant to plug in or does it only go in one way?
    Posted 31st Jul 2012 at 19:24
    It can only plug in one way...
    The best way of testing the wiring would be using a multimeter check each wire for continuity so ensure there are none broken. They should all "bell" out on the meter. Yes
    There are 4 wires going down from the loom to the lambda sensor, you will need to find where the other ends of these wires go in order to test them.
    I think it's definitely a good starting place though. Yes
    Posted 1st Aug 2012 at 06:41
    BlackSix
    ive continuity checked the wires, all belled out Sad
    its been decatted so can eliminate a collapsed cat, and ive checked for leaks in the exhaust and there are none
    Posted 1st Aug 2012 at 15:27
    I was going to say pas pump but thats already been suggested.
    Posted 1st Aug 2012 at 15:37
    BlackSix
    ive spoken to a couple of garages and theyve said ive eliminated everything they would try bar the ecu.
    dont really wanna pay out again if its not 100% the problem Sad
    Posted 1st Aug 2012 at 15:42
    Have to say I agree to be honest, it's an odd one. The next step would be to try and find another member who has a permanently unlocked ECU who wouldn't mind meeting up with you and letting you borrow their ECU and see if the issue remains or disappears. Smile
    Posted 1st Aug 2012 at 16:09
    Not far from leicester, maybe give Mechanical_Repairs a shout?
    Posted 1st Aug 2012 at 16:14
    Good call - I know he has stock of unlocked ECUs, will eliminate it one way or the other. Wink
    Posted 1st Aug 2012 at 17:12
    BlackSix
    thanks. got his number from here will give him a call Smile
    Posted 1st Aug 2012 at 17:20
