displaying posts 26 to 50 of 73
Pages (3): 1 [2] 3
Author Subject: Peogeot 306 GTI 6 Handling - Understeering and how to Kill It
miles wrote:
I always say a 30mm rear ARB is fine even for road use, No issue's with them along with solid mounts as along with up-rated front bush's it makes the car turn allot sharper as you don;t have to wait for the rubber to react.
This ^^
Posted 1st Aug 2012 at 09:18
I sort of wish i got a 30mm arb now :S oh well im sure it will be good enough.
Posted 1st Aug 2012 at 09:19
The 30mm does make quite a difference, it made the rear end of my '6' nice and stiff and coupled with the solid mounts it makes it very predictable which is a quality that I look for in a car. I fitted the 21mm TB's at the same time and the whole setup seems to really work well. Yes
Posted 1st Aug 2012 at 11:49
phillipm wrote:
Yeah, should be in tension really - pulling inwards on the strut tops, but not a lot.
is that just 306 based info?or all cars with a front strut brace?Thumbs up
had mine like that anyway......Whistle
not tensioned pushing the struts out......Roll eyes
Posted 1st Aug 2012 at 20:01
Most cars with struts, unless the strut is outboard of the crossmember/bulkhead connection.
Posted 1st Aug 2012 at 20:02
Ah right,cheersThumbs up
Posted 1st Aug 2012 at 22:07
JimmyC379
An update on my handling issues. I have fitted the Koni yellow shocks and 30mm lowered springs to the GTI and handing seems better, however I will see what it is made of this weekend at the track. I think I will need to stiffen the rear torsion bars as it has bottomed out a few times now. I lowed the rear 30mm [same as the front] and the rear looks lower than the front. What height do most people set there rear to front height ratios at and why?
Cheers.
Posted 25th Sep 2012 at 11:22
I don't set them lower than 322 between damper bolts on standard bars, equates to about 25mm rear drop, works well with Eibach springs which are reputed to be a 30mm front drop.
Posted 25th Sep 2012 at 11:25
Post #35
It will because the arches are lower on the rear of the car. You need to measure on a flat hard surface from the chassis rails underneath (if they aren't too crusty). Ideally you want a bit of rake to the front (nose down).
Posted 25th Sep 2012 at 12:16
Post #36
Depends on the dampers used (if they have the correct height platforms) and engine weight - aircon/airbags etc for the front. And of course on the front/rear height/weight distribution.
Torsion bars are a pain in the arse Whistle
Posted 25th Sep 2012 at 12:19
milkyb
Post #37
milkyb wrote:
FYI- you have spelt peugeot wrong in title. i always do this also..such a stupidly difficult word to spell
Posted 25th Sep 2012 at 12:30
gota6again
Post #38
milkyb wrote:
FYI- you have spelt peugeot wrong in title. i always do this always..such a stupidly difficult word to spell
Should have used spell check Thumbs up
Posted 25th Sep 2012 at 12:33
milkyb
Post #39
why you always gotta be a playa hater?
Posted 25th Sep 2012 at 12:35
Post #40
[/i]Peugeot[/i] torsion bars are a pain in the arse.
Posted 25th Sep 2012 at 15:44
JimmyC379
Post #41
Cheer guys and girls. Once I get some bigger bars I will jack it up 5mm!
Posted 26th Sep 2012 at 13:27
demondriverdan
Post #42
Out of interest, where can we get 30mm ARBs from? Smile
Rallye Race Car
Posted 29th Sep 2012 at 20:38
JimmyC379
Post #43
I went to the track this weekend and these are my notes:
Well handling is defiantly better with the rear konis on the heavyest setting. She is now trypoding majorly - but I am not sure if that is a good thing. With it trypoding I am finding the rear way more unstable. She is still fairly predictable but it does not feel even 80% of what I want it to feel like. Next step will be to upgrade all the bushes to urethane and maybe solid mounts and see how she goes.
The linkage also came of the ball joint on a small off so will also need to address this - it was easy to pop back in but had to get towed back to the pits and don't what this to happen again.
Posted 30th Sep 2012 at 14:03
aaron6
Post #44
Stiffer anti roll bar and torsion bars should eliminate the tripoding I'd have though. The solid mounts just stop the passive steer which is a trait I really rather like. Smile
Posted 30th Sep 2012 at 16:47
ryangti6
Post #45
My logic would be that it would actually make it tripod more as there would be less 'roll' so will lift the other wheel more easily.
Ryan
Posted 30th Sep 2012 at 17:28
aaron6
Post #46
But with less roll on a flat road could it still clock a leg as it shouldn't be rolling. Well, that was my thinking. I could be wrong though. Often am infact. LOL
Posted 30th Sep 2012 at 19:18
Post #47
unless you stiffen up the front corners it will still roll and tripod, though the rear ARB will decrease the amount it does it at by increasing rear slip.
Posted 30th Sep 2012 at 22:34
Post #48
Im going to stick to what i said in the beginning in that you have a standard ish back end with a mega stiff front. You need to stiffen the back to help keep the front on check other wise you will always have understeer.
Posted 30th Sep 2012 at 22:38
24seven
Post #49
If you're still getting terrible understeer try disconnecting the front ARB (without removing the whole thing you can just take out one of the drop links so you can just put that back in if you don't like it). If you've stiffened the front you'll be getting less roll than a standard set up during cornering and so the extra roll stiffness the ARB is providing will make it understeer more.
Posted 30th Sep 2012 at 23:25
Post #50
It's overly soft springs and an undersized front ARB you need to sort if you want to lessen/eliminate the front end dive & roll that unloads the inside rear and reduces the outside front tyres contact patch all at the same time (not a winning combination) increasing the front track (wider wheels/spacers/longer wishbones etc) will help to reduce roll induced under steer but springs and ARB is where you need to put your money.
Posted 1st Oct 2012 at 02:28
Pages (3): 1 [2] 3
