Author Subject: the best ride height for front and rear?
tom28
Hi all, before you flame me YES i have done a search but couldn't find any info that satifies my question.
if i used eibach springs to lower the front (which would approximately be around the 30mm mark) what would be the best height to lower the rear by to get the best handling out of the car??
cheers
Tom Thumbs up
Posted 10th Jun 2012 at 21:06
anth
About 30 mm just don't make it nose heavy and it will be fine
Posted 10th Jun 2012 at 21:13
Eibach springs on standard shock won't lower it at all - I should know as I've just done it ? Left the rear as it was ?
Handles fine Yes
tom28
forgot to add i would be uprating the shocks to match the lowering springs not just using lowering springs on their own
Posted 10th Jun 2012 at 21:36
tom28
c'mon guys surely someones got an opinion on this!
if the front was lowered by 30mm (for example) should the rear also be lowered by 30mm so the cars stance is level and flat at both ends or should the rear be slightly higher than the front, and if so, how much higher?
genuinely need your advice!! Smile
tom
Posted 10th Jun 2012 at 22:32
30mm front 25 rear
end thread
Posted 10th Jun 2012 at 22:34
tom28
thx roland
Posted 10th Jun 2012 at 22:37
The rear of the car is 10mm higher than the front as standard anyway, and that is the way it should be. Yes
I have lowered mine by 40mm all round, handles like a go-kart and sticks to the floor like jam to a blanket. Smile
Posted 10th Jun 2012 at 23:23
Bit of rake ftw
  • Posted 10th Jun 2012 at 23:37
    Shocks make no difference to height!!!Dunno
    Are you sure you did not have lowering springs on it before??Whistle
    Fitted Eibachs to my standard Rallye shocks and it was deffo lowerYes
    Posted 11th Jun 2012 at 09:23
    jord294
    by fitting eibachs to std front struts, a measurement of 322mm between the rear shocker bolt points, will be spot on when lowerering
    although, i usually set lowered beams to 320mm
    Posted 11th Jun 2012 at 09:45
    tom28
    ok cool stan Thumbs up now to add abit of confusion into the mix LOL , by 40mm all round do you mean 40mm reduced at front and rear compared to the standard ride height so the back end is still higher by maintaining a 10mm difference, or has it been lowered so the height at the front and rear is exactly the same making the car level?
    also, when roland said to me lower the front by 30mm and the rear by 25mm does this mean in comparision the difference between the rears ride height compared to standard would it now be higher? (increasing it by 5mm basically) so now the difference would be a 15mm higher ride height at the rear as opposed to the 10mm standard setting?
    cheerz
    Tom
    Posted 11th Jun 2012 at 12:52
    I always set the rear to 322 as Andy said, matches eibachs very well.
    Posted 11th Jun 2012 at 13:16
    tom28
    what is the difference compared to the front then?
    Posted 11th Jun 2012 at 13:32
    tom28
    best to keep the difference between heights to 10mm?
    Posted 11th Jun 2012 at 13:34
    sjheardy
    hey guys just noticed this thread, does anyone out there know the standard heights for front and rear, and where i'd measure that from, because i've just bought a 6 and the front looks much higher than the rear :S if i use the fingers between tyre and wheel arch technique, i have 2 fingers at the rear, but 4 at the front!!!
    help please!!
    Astor 6!!
    Posted 10th Jul 2012 at 22:02
    darzmat
    help please!!
    i dont know the heights but mine was the same.
    shown here. dont have a side on pic
    Posted 11th Jul 2012 at 00:01
    7057sam
    I think mine is at about 40mm alround but looks gay as f**k at the moment as its stripped out.So going to go for about 45-50mm all round.
    Team rallye,built for track
    Rallye dead Sad
    Secret Team Astor...
    Posted 11th Jul 2012 at 00:57
    aaron6
    Mine 40 on the front and 30-35 at tte back. Handles well id say. Turn in is nice and sharp. Better than when it was 40 all round. Personal opinion though. Smile
    Posted 11th Jul 2012 at 10:16
    sergioiacobucci
    REVIVE!
    Ok so I switched over to B12s on the front recently and the front is still about 10mm higher than the back I'm not even sure it's lowered it at all (its stripped out) is this normal? The rears are still on standard.
    Phase 1 silver track car
    335i daily
    Posted 6th Sep 2016 at 12:55
    You mean b8s with eibachs bud ? B12 kit just means you get b6 rears with the b8 fronts ? Sounds like the rear needs adjusting
    Posted 6th Sep 2016 at 14:04
    sergioiacobucci
    Yep thats what i mean mate. Reading the above though it sounds like the rear is always lower?
    335i daily
    Posted 6th Sep 2016 at 17:11
    mocinim
    If youve just fitted new ones they will sink a little with some use not a great deal
    Best get iut there n drive sling it about abit and get some miles into the springs and you may find it sorts just nice i have b8 n eibach on one of mine drops it nicely now they're worn in
    It should look lower at the front if you set the rear to the correct height Smile
    BLACK RALLYE - phoenix
    WHITE RALLYE - valliant
    Posted 6th Sep 2016 at 17:27
    sergioiacobucci
    Thanks they are not new but have been sitting off a car for a while so maybe once i take it out it might settle a bit.
    335i daily
    Posted 6th Sep 2016 at 18:24
    mocinim
    No not likely then eibach sink a little from new then work harden as they set in
    May though if theyve been out a while and where never run in properly
    Posted 6th Sep 2016 at 18:56
