displaying posts 176 to 200 of 236
Pages (10): first .. 7 [8] 9 .. last
Author Subject: Turbo Dimma 306
Post #176
Sounds it if that dude had 440 at the wheels for 6 months Shock
Posted 8th Aug 2012 at 21:11
birk
Post #177
Look what I picked up today Smile
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 10th Aug 2012 at 22:41
Post #178
mmm ML box Smile
Posted 10th Aug 2012 at 22:45
Post #179
Either that, or a new bin bag in really strange packaging.
Posted 11th Aug 2012 at 09:50
Post #180
hmm, looking at it, where's half the long shaft and the intermediate bearing carrier? you'll need those...
Posted 11th Aug 2012 at 09:57
birk
Post #181
The half shaft is hiding in the other bag to the left.
Not sure on fit ment at the hub end due to the length of the Dimma shaft.
07889376885
Dan
Posted 11th Aug 2012 at 11:08
Post #182
Looking good dan, I'm interested in the gearbox and clutch setup you end up using, can't wait to see a vid/hear it running, going to sound awsome this, you've taken your time but as they say "the best things Come to those who wait"
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 11th Aug 2012 at 14:17
birk
Post #183
Got this off a guy I know for £35
07889376885
Dan
Posted 12th Aug 2012 at 12:47
fatlapit
Post #184
whats happening with this now mate???
Posted 13th Sep 2012 at 12:37
birk
Post #185
Its sat doing nothing at the moment lol
Work has slowed down quite alot over the past month or two, have more important things to buy, rent and food for one lol
07889376885
Dan
Posted 13th Sep 2012 at 12:54
fatlapit
Post #186
lol
Posted 13th Sep 2012 at 13:01
Post #187
Any updates? Smile
Posted 15th Dec 2012 at 19:48
birk
Post #188
I'm hopefully getting a twin plate clutch tomorrow, if I do, then it will be full steam ahead with the rebuild.
I've been putting it off untill I bought a clutch, as that was the most expensive bit to buy, but I've come across a 2nd hand one, which will save a good chunk of money.
07889376885
Dan
Posted 15th Dec 2012 at 19:57
simonjames
Posted 15th Dec 2012 at 20:07
Post #190
Schweeet! Good to hear Smile
Posted 15th Dec 2012 at 20:27
birk
Post #191
Well I've won the clutch Smile
It was removed from an escort cosworth rally car with 480ftlb of torque, so when I've had the splines changed over to match my ml box I know it will handle the power I will be throwing at it.
List of things to do is as follows:
Modify inlet manifold
Figure out how I will fit the new box and shafts
Figure out how I will make up a hydraulic clutch pedal
Buy some decent boost pipes for welding
Work something out with a radiator, I don't think the standard one will cope
Paint engine bay
Fit and wire up my Ecu
Get it bed in and mapped Smile
07889376885
Dan
Posted 15th Dec 2012 at 21:19
pete_rallye
Post #192
You can buy new plates with the correct splines for not a great deal of dosh, unless that's what you mean? Do the ML boxes have the same splines as BE boxes?
I'll look forward to seeing your efforts trying to cool it all...
Lap of the 'ring
Posted 15th Dec 2012 at 21:35
Post #193
nope, ML is a bigger 21 spline input shaft, BE is the same as an MA, 18 spline.
Posted 15th Dec 2012 at 21:47
simonjames
Post #194
sorry to sound a bit thick but MA ML what are they in originally 406/407 ???
MY EBAY ITEMS
07943066306
Posted 15th Dec 2012 at 21:52
Post #195
ML is found in lots of stuff, typically 2.0 turbo DW10's in bigger cars, 8v turbo and above, V6 etc, 1.9 DT van's upwards.
MA is the chocolate teapot TU gearbox.
Posted 15th Dec 2012 at 21:54
simonjames
Post #196
:thumbup that clears that up, im ok on engine numbers but boxes not a clue lol
MY EBAY ITEMS
07943066306
Posted 15th Dec 2012 at 21:58
birk
Post #197
Pete - I can't remember how much i was quoted for having the splines replaced, but it was certainly a lot cheaper than having the whole plate made up. New plates are around £100 each from CG.motorsport in Leeds. I need to see how much meat is left over before I decide on changing the splines mind, it might be more economical just to replace them both.
Any advice on cooling ? I'm sure you had some sort of Uprated cooling system in your btcc car.
Mei - I'm hoping the gearbox will be upto the job over the 6 box, I'm worried if I go to the effort of fitting it with the new clutch and getting the hydraulics sorted out I won't be able to get a diff for it Unsure
07889376885
Dan
Posted 15th Dec 2012 at 22:16
birk
Post #198
07889376885
Dan
Posted 15th Dec 2012 at 22:27
Post #199
Cosmic spanner had a custom rad of some sort i believe?
You could fit 2x12" fans too.
1x12 inch flows nearly as much as 2x10" Comparing Spal to Spal in each case.
Posted 15th Dec 2012 at 22:40
birk
Post #200
I think I will just end up getting a custom rad, from memory I had a quote for £275, but that was a while ago.
I do have a universal alloy race rad, but it's a bit big, and it looks a bit s**t and flimsy, so I doubt I will use it.
07889376885
Dan
Posted 15th Dec 2012 at 22:45
