displaying posts 151 to 175 of 236
Pages (10): first .. 6 [7] 8 .. last
Author Subject: Turbo Dimma 306
Post #151
Fair point. About 500hp of turbo power is going to be a s**t load of torque
Posted 8th Aug 2012 at 10:36
Post #152
Be that as it may...... We wanna see more shiny things! Big grin
Posted 8th Aug 2012 at 11:10
Post #153
Also true.
I want to see this done and on a dyno really.. Ninja
Posted 8th Aug 2012 at 11:33
birk
Post #154
I'm a bit undecided as to what to do with the gearbox, that's the reason why progress is going a tad slow.
I'm not sure if I should risk putting a 6 box on, if I take that risk, then I can get the £600 clutch and crack on with it, but the box I doubt will last that long.
I could go to the effort of putting a different box on, focus rs mk1 for example, using a bell housing adapter and flywheel spacer, but that means a lot of custom work and a set of custom shafts.
That choice delays the clutch choice, because the clutch plates will be different to match the gearbox splines.
Not sure what to do tbh.
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 8th Aug 2012 at 17:46
Post #155
ML5?
Posted 8th Aug 2012 at 17:54
Post #156
I'm interested to see how whatever box you choose gets on with the power and torque, as i may just copy you once i start chasing more power. LOL
Posted 8th Aug 2012 at 17:59
birk
Post #157
Why did I never think of that lol
Would I be better off with the ml5 or ml6 though.
Hydraulic clutch is want I wanted aswell Smile
07889376885
Dan
Posted 8th Aug 2012 at 18:12
Post #158
Yeah thats a good point , you could get it cryo treated but even then you are probably going to put about 100 ftlbs more torque in that than anyone else.
Posted 8th Aug 2012 at 18:21
Post #159
http://www.306gti6.com/forum/showthread.php?id=104373&page=1
This bloke had 400 at the wheels
Why don't all the high boost lot do this?
Is the ml6 as strong as the 5?
Posted 8th Aug 2012 at 18:23
Post #160
Just found his project thread.
Firstly
A in the end he ran and got working a Citroen evasion box which I assume is a ml5
B he got 440hp at the wheels!
C 1.3 bar on standard internals.
WTF!
I think we can safely say the box will take the power then......
http://www.youtube.com/watch?v=gPD8fgXzzt4&feature=youtube_gdata_player
Posted 8th Aug 2012 at 18:32
Post #161
It's what you get from living in Donny. Thumbs up
Posted 8th Aug 2012 at 18:36
Post #162
I'd throw back an insult, if only i could think of one.. Laugh
Posted 8th Aug 2012 at 18:40
birk
Post #163
442whp in the end for 6months before he sold it, so that's over 500bhp at the flywheel and I imagine around 450ft lbs of torque.
Sounds good to me Smile
Now...
How do I fit it lol.
07889376885
Dan
Posted 8th Aug 2012 at 18:47
Post #164
Haha I know right? Crazy.... looks like mabz doesn't have to worry about the 270hp on his lowboost
Posted 8th Aug 2012 at 18:49
Post #165
ML5T bellhousing from the turbo models, should bolt straight on IIRC
Posted 8th Aug 2012 at 18:53
Post #166
This car is going to be so f**king awesome.....
Posted 8th Aug 2012 at 18:56
Post #167
...for 10 seconds...
Posted 8th Aug 2012 at 19:03
birk
Post #168
So from my research, I need a later gearbox and a turbo bell housing so it fits the xu block.
Surely I could just use the ML5T box, or is it not as sime as that?
Cheers eliotrw, I hope it's good when I eventually Finnish it.
Phill - shut it LOL
07889376885
Dan
Post #169
Might wanna check the gear ratios, I think some of the Citreon models have higher final drives if you need more legs.
Posted 8th Aug 2012 at 19:06
Post #170
Did the crank get balanced along with the flywheel and crank pulley ? just out of interest or do you not need to bother doing that on turbo lumps ?
Posted 8th Aug 2012 at 19:24
birk
Post #171
I haven't had the flywheel balanced, I never had a problem with the previous engine with same spec Smile
Am I right in thinking the 2.0l 8v turbo runs an ml5 gearbox? With cables and hydraulic clutch on some cars.
Surely I could just get one of these and the ratios And strength in comparison to a Hdi box be ok?
07889376885
Dan
Posted 8th Aug 2012 at 20:02
birk
Post #172
And would I benefit from an ml6 box?
07889376885
Dan
Posted 8th Aug 2012 at 20:03
Post #173
I think the ratios are in the first link somewhere
Posted 8th Aug 2012 at 20:16
Post #174
birk
Post #175
Ratios seem ok to me on the 406 8v turbo box, I just hope its strong enough.
07889376885
Dan
Posted 8th Aug 2012 at 20:29
