displaying posts 1 to 25 of 36
Author Subject: cant get cat off mani...
knoxie
as the title says i cant get my cat from my mani off, tried undoing the 10mil nut from the spring loaded bolts (not sure of the real name) but it just spins, do you have to have a spanner on the top of it aswell? if so how do you get to it as i can only just get my finger onto it Confused
i have had a look through some threads but cant find my question
please help
lots of love knoxie Big grin
ex S16 (K.I.A Sad )
GTI 6 Big grin
TEAM more scratches than an emo kid
TEAM BLACK
but wishing it was bianca white Sad
Posted 7th Jun 2011 at 03:03
footah212
You need someone to hold the top of the bolt from the engine bay. Trying to do it all from the underneath is a nightmare.
Passenger side 1 is easier to get to than the drivers side. You will have to sqeeze your hand down the back of the manifold to get to the drivers side bolt so make sure the engine is cold.
Hope this helps
Phase 2 Blaze GTi6
PS3 - Black Ops 2
Posted 7th Jun 2011 at 03:07
Yes you do. Need to feed it through, it's a right fiddle.
smegal
10 (or 11)mm spanner on the top too.
Ex SC-6
Now in a Megane R26
Posted 7th Jun 2011 at 03:08
ian7675
Techno Viking
This is a job I did once...and vowed never to do it again. It's a tricky job to do LOL
Less than 24 hours to go!
Posted 7th Jun 2011 at 03:10
knoxie
Hmm i have real fat hands Doh
thanks for the help guys i'll see if i can get to it Smile
ex S16 (K.I.A Sad )
GTI 6 Big grin
TEAM BLACK
Posted 7th Jun 2011 at 03:12
Gilsey's very good at doing them too. He rocked up to mine to swap one off his old car onto his new car so ended up doing 2 at once. Laugh He seemed happy though.
Posted 7th Jun 2011 at 03:13
smegal
Once you get the knack it is ok. IT just takes a lot of fiddling the first time. I used LOTS of extension bars and did it with a ratchet through the subframe and a spanner on top.
Ex SC-6
Now in a Megane R26
Posted 7th Jun 2011 at 04:28
How would you know? Dry
Posted 7th Jun 2011 at 04:29
I do it from underneath on my back. left arm up around wishbone and anti roll bar, other over rack. I use a 6sided 3/8 on the top to get good grip, and then a 10mm socket on the bottom. I advise getting the sockets on correctly, then go guns blazing until undone. once the spring loosens and the cat drops, you lose easy access to the head of the bolt. If you round it off, nut splitter through spring works. Good luck
  • Posted 7th Jun 2011 at 04:40
    6 sided socket or spanner is the way forward. A lot less likely to round off then. Easier underneath I thought.
    Before you say anything Ash yes I have done this quite a few times thank you very muchRazz
    Posted 7th Jun 2011 at 15:53
    ryans6
    Cut thmem or snap the bolts, then just replace them.
    BLACK 6
    Posted 7th Jun 2011 at 19:45
    bennn
    I went from underneath last time, but had the benefit of using a proper car ramp which made it quite easy to see what i was doing.
    Cherry Red 306 HDI
    Posted 7th Jun 2011 at 20:37
    ian7675
    Techno Viking
    Did you get the fitting kit with the new cat?
    Posted 7th Jun 2011 at 20:47
    knoxie
    Nothing wrong with the cat mate I'm putting a decat on
    ex S16 (K.I.A Sad )
    GTI 6 Big grin
    TEAM BLACK
    Posted 7th Jun 2011 at 22:28
    ian7675
    Techno Viking
    Did you get a fitting kit with the new DE-cat?
    Posted 7th Jun 2011 at 22:31
    knoxie
    Nope 'twas a second hand jobbie
    ex S16 (K.I.A Sad )
    GTI 6 Big grin
    TEAM BLACK
    Posted 7th Jun 2011 at 22:38
    FAIL,best get ordering a kit then Thumbs up
    Posted 7th Jun 2011 at 23:50
    ian7675
    Techno Viking
    I've obviously failed in my question, did you get a new fitting kit, irrespective of what you are fitting?
    It's not recommended to use the old bolts and ring gasket on a new cat, old cat, new de-cat or old de-cat.
    You can get them from Peugeot for about £13 iirc.
    Posted 8th Jun 2011 at 00:08
    ^ Nearer £20. Last one I bought about 4 years ago was £18 something. Peugeot didn't have it in stock, so I got one from Citroen, which was actually cheaper yet in the same PSA packet.
  • Posted 8th Jun 2011 at 02:46
    knoxie
    Not had time to have a look today, been a busy bee Sad
    ex S16 (K.I.A Sad )
    GTI 6 Big grin
    TEAM BLACK
    Posted 8th Jun 2011 at 02:48
    ian7675
    Techno Viking
    That's just crazy, £20 for literally a bag of bolts and a ring Shock
    Posted 8th Jun 2011 at 04:53
    smegal
    The pattern ones are much cheaper but inferior quality.
    Ex SC-6
    Now in a Megane R26
    Posted 8th Jun 2011 at 04:58
    To be fair for the hassle of fitting it, do it once, and do it properly with a genuine Peugeot one. Buy cheap, buy twice.
  • Posted 8th Jun 2011 at 13:53
    £21.56 actually.
    Posted 8th Jun 2011 at 15:09
