displaying posts 551 to 575 of 884
Pages (36): first .. 22 [23] 24 .. last
Author Subject: Goldie the track car
stef306
Post #551
i dont know if your dead set on a icv but i had nothing but issues on mine im now using without one and its 100 times more reliable and stable. I now control it through scatter spark via the omex.
1990 205 gti6 supercharged
Posted 12th Aug 2015 at 13:34
Post #552
Not much in terms of updates worth posting.
I've decided to abort the idea of the icv as it was proving to be a pain like you said stef, so for the time being i've just made a gasket and covered the hole in the plenum.
I've made a new wiring loom to suit my dta ecu, that seemed to take an age to complete, but it's pretty much there now, just need to wire the tacho wire to the clocks and one other switched live and thats complete.
I got a base map to try and get the engine running n/a just to check the ecu worked but it appears that the ecu is faulty. In fairness i did buy it as untested so it was sold as spares or repairs.
The problem seems to be that the injectors are constantly open as soon as the ignition is on, i got in touch with dta about it and they want £75 to repair the injector drivers. Instead i took the ecu apart and it looks to be the transistor that is faulty that does the injectors, so i've just bought an identical model off ebay and i'm going to have a go at replacing it myself.
Hopefully that will arrive tomorrow so i can get started on that.
The down side of this is that i'm now sure that i flooded my engine, so i reckon the fresh oil will now be contaminated with petrol. Sad
I've also made a small adapter that means i can control two throttle cables with the throttle pedal, i wanted to use two standard throttle cables but in the end it seemed much easier to just buy a set of push bike brake cables and adapt them, which is what i'm in the process of doing now.
Progress was hampered a little when the headgasket on my other gti6 (the daily) went last week, so i wasted all my evenings last week stripping the head off that, getting it skimmed then rebuilding it, that also took up the money i was going to use to have the track car mapped. On the bright side the daily now starts like a dream and runs much better than it did before.
EDIT: It seems i've done a few more things to the car since the last update, i'll get some photos up tomorrow when i hopefully have a bit more motivation to do stuff Laugh
Posted 12th Aug 2015 at 16:43
stef306
Post #553
Glad youve decided to ditch the icv what an arse it was on mine! what control does the dta have for idle strategies?
Two throttle cables sounds like youve been hanging around mr storer!
Posted 12th Aug 2015 at 23:49
Post #554
Two throttle cables is always a good idea, got sick of breaking them on the bloody buggy and did the same LOL:
Posted 13th Aug 2015 at 00:58
allanallen
Post #555
Steve and I are a couple now, we hold hands and s**t Thumbs up LOL
Facebook
Posted 13th Aug 2015 at 07:11
Post #556
Bit of a strange fetish that...
Posted 13th Aug 2015 at 10:38
allanallen
Post #557
Jealous pedant Roll eyes Razz
Facebook
Posted 13th Aug 2015 at 10:59
Post #558
Two guys, one cup?
Posted 13th Aug 2015 at 11:02
allanallen
Post #559
phillipm wrote:
Two guys, one cup?
You've seen us then?
Facebook
Posted 13th Aug 2015 at 11:11
Post #560
LOL
Posted 13th Aug 2015 at 11:12
Post #561
Ffs Allan, i thought that was our little secret? Sad
I'm unsure on the strategy for idle control, just had a look round DTAWin but nothing jumped out at me. Alex at DTA did say something along the lines of idle by ignition, though he sometimes seems quite vague when i've asked him things in the past. Dunno Laugh
I'll leave the idle problem to the mapper, although i ran the engine just fine with the old ecu and no icv once i'd stopped all the air leaks.
The transistor still hasnt turned up so i can't get that fitted tonight, hopefully it will turn up tomorrow.
Posted 13th Aug 2015 at 16:43
Post #562
Not sure about yours, but on the S-series DTA's, you can just crack the throttle open a bit at idle so it runs at ~1250-rpm ish (basically whatever you want the cold idle to be) and pull the idle down to under 1k by using next to zero ignition advance, or even a bit of retard.
You can use the PWM mapping for idle control (hit the 'by ignition' checkbox) to create a map for advancing the ignition if the idle drops below target, and you can put a full temperature/time map in there to give fast idle when cold, etc, as well as an adaptive control to adjust it away from the map if it deviates in different weather conditions, etc.
The only issue is the emissions can be a bit more tricky with the throttle open and less advance, but it's not generally too bad so long as you don't go nuts with the idle.
If you get it right it can respond much faster than an ICV would - you can usually let the clutch out with no throttle and it'll compensate so fast the car will just drive off. Handy for shunting around town with paddle clutches LOL
If it doesn't have that in the '48, you can do a crude version in the idle corner of the main map, pull all the timing out at idle, and have a cell below idle at, say, 700rpm with the advance back in.
Posted 13th Aug 2015 at 19:24
Post #563
Thanks for that Phill, I've just been having another look in the dtawin software under the General engine settings section and wondered what i should have set under the 'Firing tooth on startup'?
[Image lost]
Posted 10th Dec 2017 at 18:16
Post #564
1 or 2 is usually fine, it's just which tooth it fires the ignition on before the engine is running properly for a clean signal. Have it up too high and the engine tries to go backwards when it fires LOL
Posted 13th Aug 2015 at 20:52
Post #565
Thanks Phill.
My new transistor still hasnt arrived, despite paying extra for first class postage and estimated delivery being wednesday. Sad
I've had a sniff of the oil today and it stinks of petrol from when the ecu basically flooded the engine by holding the injectors open whenever i turned the ignition on and the fuel pumps primed, so it needs fresh oil before i dare start it up once the transistor arrives. A bit annoying as its brand new oil. Sad
Anyway, a few pics of recent progress.
IMG_5039 by Steve Count, on Flickr
The second one in from the left is the 'injector driver' which needs replacing.
Mounted a new coil pack to the head, i've got some HT leads from a corsa which seem to be a pretty decent match.
IMG_4973 by Steve Count, on Flickr
The wiring loom in it's early days.
IMG_4974 by Steve Count, on Flickr
Virtually all the wires run in plastic braiding, and a mate had a genius idea of knowing what each wire was, made life much easier when finishing the loom off.
IMG_5007 by Steve Count, on Flickr
Added a few relays, one for each fuel pump (one also does the heating on the lambda too), the middle is for the ecu, and the two on the right are for the two cooling fans.
IMG_4978 by Steve Count, on Flickr
Trimmed the slam panel to clear the boost pipes.
IMG_5049 by Steve Count, on Flickr
IMG_5064 by Steve Count, on Flickr
IMG_5047 by Steve Count, on Flickr
Also had to fettle a bit of the headlight Laugh
Also trimmed a bit of the bumper. It would benefit from a bit more material being removed but it fits for mocking up purposes.
Finally starting to look more like a car again now Big grin
IMG_5052 by Steve Count, on Flickr
IMG_5050 by Steve Count, on Flickr
I've given the slam panel a lick of paint after cleaning the rust off, so it shouldn't look so shabby once properly fitted.
Posted 10th Dec 2017 at 18:27
eddy_gti6
Post #566
Nice work as always, looks very well setup Cool
Posted 16th Aug 2015 at 10:19
Post #567
Thanks chris.
Did a little more today, made a cradle to hold the ecu and made a shroud for the radiator so most of the air should be forced through the radiator keeping the temps down, also gave the intercooler a light mist with some matt black spray, i'm not a big fan of in-your-face intercoolers so this should help keep it subtle at the expense of a small amount of efficiency.
IMG_5054 by Steve Count, on Flickr
IMG_5066 by Steve Count, on Flickr
Posted 10th Dec 2017 at 18:31
t3ora
Post #568
Very nice work and to a very high standard
Just one little thing,that top boost hoses looks really close to the edges on the front panel you cut out
Road/track car coming together slowly
Posted 16th Aug 2015 at 21:09
Post #569
Thanks.
Yeah it is quite close but i've tried rocking the engine (virtually no movement with my new top mount), and there isnt a lot of movement in the intercooler either with the way it's mounted so i dont think there will be any rubbing/cutting issues. I'll keep an eye on it though as the engine will probably rock a tiny bit when it's actually under load rather than me trying to rock it by hand.
I also sorted my satchshift out today, i was having issues with the link bar from the selector to the gearstick rubbing on the bulkhead hole meaning i couldnt select 2nd gear. I can now select all gears thankfully. I haven't tried fitting the revised rubber boot thing though as i cant imagine getting a drill anywhere near where it needs to be will be an easy task and it was late in the evening when i was finishing off.
I've got one of them plastic screen wash bag things to fit too, i'm not sure where is the best place to put it though, the only real place that it'll fit is on the bulkhead to the right of the exhaust manifold but i'm not convinced the heat from the exhaust won't melt it. Hmm
Posted 16th Aug 2015 at 21:46
Post #570
Under the seat for quick refills.
Posted 16th Aug 2015 at 22:11
Post #571
Just heard back from Alex at DTA, my E48 is fubar'd. Sad
Just got off the phone with Martin at MEF Motorsport, brand new S40 will be with me next week. Smile
Posted 27th Aug 2015 at 13:34
Post #572
LOL:
How to stop drug addiction - get into cars so you can't afford any.
Posted 27th Aug 2015 at 15:23
Post #573
More like 'get into cars and never be able to afford anything again' Laugh
Posted 28th Aug 2015 at 00:47
jeffers Forum Admin
Post #574
I struggle to believe the E48 is irrepairable but still onwards and upwards... Is there a difference in the Loom connector of will it fit straight on??
Team Running Engine again!
Team Negative Camber!
Posted 28th Aug 2015 at 05:57
Post #575
different plug, will work fine on that loom though.
robably irreparable due to age and lack of available spare parts, also cost of new .
Posted 28th Aug 2015 at 06:53
