displaying posts 851 to 875 of 1021
Pages (41): first .. 34 [35] 36 .. last
Author Subject: Harris' SC China Track Car attempt
Post #851
Nifty, also just used up my year's bandwidth allowance on my phone.
Posted 13th May 2013 at 13:11
Post #852
Old redundant towels are just bloody brilliant aren't they Smile
  • Posted 13th May 2013 at 13:15
    Post #853
    Don't just bolt all the cables together and cover them in tape you bodger, get an M8 double sided rubber bobbin and drill a hole to mount it, then bolt all the cables to the top. Vibration free, insulated and tidy.
    Posted 13th May 2013 at 13:22
    Post #854
    How big is that? Looks like that engine mount of Geoffs Laugh
    Also, what is it called, and where to get one from? I swear I saw some form of junction box thing on CBS, will have a look later on.
    Posted 13th May 2013 at 15:09
    Post #855
    Double sided rubber bobbin, google is your friend, search under anti vibration mounts. Get a 25mm diameter one.
    Posted 13th May 2013 at 15:47
    Post #856
    Get hold of some heat shrink sleeving too, the adhesive on electrical tape is attacked by oils and grease and heat makes it unstick too. Look for Raychem stuff, its the dogs danglies.
    Posted 13th May 2013 at 15:50
    Post #857
    So I guess something like this?
    http://www.ebay.co.uk/itm/Anti-Vibration-Mount-Rubber-Bobbin-Mounting-M8-30x25mm-/290905361238?pt=LH_DefaultDomain_3&hash=item43bb4f8b56
    Then I can just drill a hole somewhere in the car, tap and die out the hole, mount that, and bolt the lives to that? Seems a bit of a mission Laugh
    And will that be ok to put lives to and bolt it to the chassis Unsure
    Posted 13th May 2013 at 15:53
    Post #858
    Yes. You probably have an M8 threaded hole already on that gearbox mount Roll eyes
    And yes, there is no metal between the two threaded parts, so it is electrically isolated. I run the same thing on mine.
    Posted 13th May 2013 at 15:59
    Post #859
    daveyboy wrote:
    Yes. You probably have an M8 hole on that gearbox mount Roll eyes
    Touche Laugh
    And 100% that is fine? Surely the rubber is only round the outside of that bobbin? Wont it just pass through that and "live" the whole chassis? Unsure
    Posted 13th May 2013 at 16:00
    Post #860
    cjm_harris wrote:
    Touche Laugh
    It wouldn't be an anti vibration mount if it was would it? LOL
    Posted 13th May 2013 at 16:02
    Post #861
    Buy two and cut one in half if you don't believe me. This forum needs a facepalm smiley.
    Posted 13th May 2013 at 16:03
    Post #862
    Laugh my ass off
    Yeah I believe you, but I would of thought that the M8 bolt there would go all the way through as one. It just looks like the mount above on Geoffs car, with a rubber casing Laugh
    And to be fair, the 2 hours sleep I got last night has left me somewhat clueless today, and its not exactly a mount specifically designed for what I want it to do, its just a mount Unsure
    Posted 13th May 2013 at 16:25
    Post #863
    Rubber mounts are exactly what they say on the tin, and it's tailor made for mounting electrics you want isolated. That's why fuel pumps come mounted on bobbins as they vibrate like hell and transfer noise into the cabin, but they also come with an earthing wire as the rubber mounts won't pass current.
    Posted 13th May 2013 at 17:00
    Post #864
    Thanks Jim, much appreciated Big grin
    Posted 13th May 2013 at 19:02
    Post #865
    Have booked myself on a trackday at Rockingham next month for a shakedown before Pugfest and need to get the car sorted out sharpish really. The trackday itself is a taster session. 20 minutes in the morning, and if you like it, you can book to do the afternoon session. My plan is to use the morning blast to make sure its ok, then book the full afternoon.
    Right, start of some progress.
    Finished off my battery relocation (Eddy_gti6 will be shocked)
    Not convinced on the earth, so will probably try and get something better sorted.
    Using the bobbin mount as Jim suggested
    Need to get some heatshrink, so just electrical tape for now.
    I am very pleased to report that it all worked fine (first use of the battery since I bought it about a year ago) Used the jump pack to start it. Need to get it properly charged up and make sure it can start the car on its own. Will take the jump pack round with me until I trust it though Laugh
    Bolted my cut down ECU box to the wing, and relocated the dual function relay (as I lost the pin thing on back of ECU box)
    Didnt really know what to do with my oil catch tank as it used to be bolted to the battery box. I decided to make this for the time being. Its a bit pikey, but on the plus side its 700g lighter Laugh
    Bit more room in the engine bay now with battery and ABS gone.
    Oh and now Eddiebeano has got rid of his, I can put my red tow stickers on.
    Still need to fit my red TRS tow strap.
    Posted 25th May 2013 at 22:10
    Post #866
    Question..
    I have removed this negative battery terminal and it earthed to top of gearbox and wing.
    Now, I have the battery earthed in its new location, but do I need to now run an earth cable from gearbox to wing?
    Posted 25th May 2013 at 22:17
    Post #867
    Manged to remove the last of the brake pipes today too. The ABS sensors can f**king do one though. No idea how you get them out Doh
    And another question for those of you in the know. I bought a bias valve from Jorg on here, already had adaptor fittings in (I hear wilwood use funny ones) but I dont think I need them? I bought the pipe and fittings from what Owain bought (in fact, im copying his whole setup for the brake stuff) and the ends for the pipe, seem to go straight into the valve Dunno
    As I bought it
    With pipe and fitting mocked into place
    Thoughts? Smile
    Posted 25th May 2013 at 22:21
    7057sam
    Post #868
    They's a small gap with bolt hole in it where you can put your trs, for some reason I had 2 tow bars on the front of mine.If also got rid of the spare wheel and cage as I carry no jack or wheel brace so they really no point LOL
    Carl did the relocation bits for me but I swear we earth on to the battery plate and in the car chipped away at the floor plan and bolted to that, he also ran a postive through the fuse box.
    Team rallye,built for track
    Rallye dead Sad
    Secret Team Astor...
    Posted 25th May 2013 at 22:32
    Beagle_Hound
    Post #869
    Nice, it's moving faster than mine at the moment. You might want to consider mounting your catch tank against the firewall like this.
    On a bracket similar to this
    You can then mount your ECU on a bracket that is mounted to the original battery box mount. I fabricated a bracket that mounts to the original fittings using rubber bobbins.
    And one of these for the positive terminals.
    Posted 25th May 2013 at 22:33
    Beagle_Hound
    Post #870
    You have to smash the sensors out form the hubs. A lot of effort for a couple of grams. You might want to get rid of the inertia switch before you run the curbs at Rockingham. If its anything like the S16 you just cut and connect the two wires.
    Posted 25th May 2013 at 22:37
    eddy_gti6
    Post #871
    Mate you need to earth the engine/box to the chassis. i would just either leave that cable on or make a new one.
    As for your bias valve that setup should be fine without the origional ends that came with the valve.
    Cars coming on well there mate
    Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url &amp; =
    Posted 25th May 2013 at 23:08
    Post #872
    Bit more done on the car, getting there slowly.
    Firstly cut off the negative battery terminal and wire, to create an earth lead from gearbox to chassis rail.
    Went to fit it and on gearbox end, the bolt went tight before it was fully done up, then one turn later it snapped the head off it Angry So now I need to find a way of earthing the gearbox to the car. Joys!
    Recruited my mate to help me with the new brake lines (I say help, I mean he did it for me)
    Passenger side front
    Drivers side front
    MC, front outlet to T piece for the front brakes, rear outlet to the rear T piece
    Front T piece
    Line ran down to bulkhead to bring out in passenger footwell.
    Into the car here
    Will probably look at getting some pipe padding just to make sure in case it gets kicked etc.
    And to the bias valve
    Thats as far as we got, will hopefully get it finished this week Smile
    Also made a start on fitting the polycarb windows. removed the old glass and rubber seals. Drilled holes randomly to rivet to (didnt care much as I have the black border sticker to go on, and will paint the rivet heads black).
    It seemed it eas going to be a pain in the arse to try and line up hole with holes cut in polycarb, so decided to just hold window in place, drill one hole, then rivet and go from there. Worked fine except I had to rivet to the inner part (which is recessed back from where the window sits) so as a result, it pulls the window in a bit and is not flat. Its a track car though, and dont care for imperfections such as that Laugh
    Just need to fit the border sticker, and use some clear bathroom sealant or something to make it water tight.
    More on this in the week if the rain f**ks off Smile
    Posted 28th May 2013 at 12:26
    eddy_gti6
    Post #873
    You can earth the box or engine to the chassis, doesnt really matter what one asling as there is something there
    Posted 28th May 2013 at 18:10
    Post #874
    More progress today, not much more to go now Smile
    Got the brake lines finished but hit some problems with the bleeding. One rear caliper is missing the bleed nipple (not sure how..) and one of the little sleeved joints connecting to the bias valve has a damaged thread so its leaking. Need to get a new caliper fitted and a new joint and hopefully will bleed up with no more issues or leaks.
    Will get them all clipped in when its confirmed as finished.
    Got the rest of the windows out and the polycarbs fitted.
    Used silicon sealant round the rear windows to waterproof them and stop wind noise
    Glass out. Didnt know how to remove the green clip so I cut it off Laugh
    Motor, runners and other gubbins removed.
    Fitted in place
    Riveted in and borders on (these are a c**t to do!! And as I stuck it over the rivets, still need to cut away border and sort it out.
    Sorted out the battery earth as wasnt happy with just the self tapper. So drilled a hole, and cleaned up the surfaces with wire brush (including underside, underseal removed etc) and bolted the earth on.
    Also fitted the earth from gearbox to wing, and cleaned up all the contacts the same way.
    Just over 9kg of crap removed from the car.
    Was nearly 2.5kg for rear window change and forgot to weigh the front Doh Got to be another 20kg loss including battery change etc. Need to get it weighed again really.
    Bought some new disc protectors to fit to the new beam.
    New vs old
    These are being painted so pics up when done.
    Hopefully pick up the new beam in the week, So just need to fix brakes issues, fit beam and get an MOT, then its all ready for Rockingham Smile
    Also when I had done with stuff today, decided to give the engine bay a bit of a cleanup, so heres some pic whorage..
    Just noticed I need to cable tie my catch tank back on.
    Posted 1st Jun 2013 at 22:16
    Post #875
    You harp on about weight saving but put the disc covers back on?? LOL
    Posted 2nd Jun 2013 at 01:10
