displaying posts 726 to 750 of 1021
Pages (41): first .. 29 [30] 31 .. last
Author Subject: Harris' SC China Track Car attempt
Post #726
I just bought a load of fine pitch nylocs from ebay, Pretty sure the big ones are M14x1.5 and the smaller ones are M12x1.5, i bought them to replace the nuts you are on about, and conveniently the M14 ones will fit my coilovers ready for when i slap some new topmounts on. Big grin
Posted 7th Mar 2013 at 19:46
Post #727
Cheers Steve, will have a look on ebay.
Managed to get an hour or so free time on saturday so thought I would attack some more of the beam.
Half of the work was cleaning it up, and trying to de-rust some of the nuts etc. Got the brakes off, but the disc protector bolts are corroded to s**t, not idea how im going to get them off
hmm rusty
So I moved on to try and get the torsion bars out. Now, I dont have a slide hammer and Im not keeping these bars as I am getting new thicker ones, so I decided to just smash them out with a hammer Laugh my ass off
This worked fine for one, but the other didnt seem to want to budge. Sprayed a load of WD40 on it, and left it for another day.
As I am keeping the trailing arm shafts, can someone confirm this looks ok? Seems fine to me, but I dont really know what Im looking for.
Posted 11th Mar 2013 at 10:22
Post #728
RE the disc protectors, I wouldn't worry too much about corrosion. My 309 beam looked like it had been dredged from a canal but they aren't tightened to 200lbft so should come out fine with the appropriate bit knocked in and undone. Or if that fails, vise grips around them.
As for the trailing arm shafts, I've recently had 3 beams apart, all of which were camber free and none of the shafts are perfect if you want to be fussy. If you clean that grease off and there's any pitting to the shaft from the needles - you're best to replace them. People do press them out and twist them around, but for the sake of £100 for a new pair is it worth potentially reducing the life of the new bearings? Do it once, do it right.
  • Posted 11th Mar 2013 at 10:47
    Post #729
    Pretty sure that shaft is knackered looking at the rusty bearing marks where the outer bearing sitsThumbs down
    Posted 11th Mar 2013 at 21:27
    Post #730
    Oh tits!
    Well, ive decided that I am not going to build the beam myself, just going to take a box of parts to someone who knows what they are doing and get them to put it all together, and they can be the judge if bits need replacing.
    Also, what machining needs to be done to fit a bigger ARB?
    Posted 12th Mar 2013 at 09:04
    Post #731
    There are a few deals on shafts at the moment. Neat do a pair for around £100 I think it is.
    If you buy a bigger ARB the splined ends should be the standard dimensions to fit in your current end plates.
  • Posted 12th Mar 2013 at 09:10
    Post #732
    Really?
    I thought that the hybrid was the biggest you could fit without having to modify something? I am getting a 30mm ARB.
    Posted 12th Mar 2013 at 09:18
    Post #733
    You need to have the trailing arms drilled out to get the ARB through I believe, it's too thick to fit through the normal hole.
    Posted 12th Mar 2013 at 09:26
    Post #734
    You sure? Always heard it referred to as "machining" so assume it would of been something more complex Unsure Laugh
    Posted 12th Mar 2013 at 09:30
    Post #735
    Well they're massive and cast iron, so you can't exactly just get out your Black and Decker and have a bash, they need to be done on a proper milling machine, so yes they do need doing by a proper place Yes
    PS I've never had this done, so don't assume it's what you have to do
    Posted 12th Mar 2013 at 09:33
    Post #736
    What size torsion bars are you fitting?
  • Posted 12th Mar 2013 at 09:47
    Post #737
    Ah fair enough, that makes sense Smile
    23.5mm torsion bars, why do you ask?
    Posted 12th Mar 2013 at 09:48
    Post #738
    I did mine in a lathe not a mill and used a 31.5mm drill bit. Did the job nicely but I could only drill about halfway from each end as the drill wasn't long enough to reach all the way through from one end meaning I had to take the tube out and turn it around to be able to drill the full length but it was no big drama.
    Posted 12th Mar 2013 at 09:51
    Post #739
    Curiosity.
    I believe going above 23mm torsion bars means that if you wish to remove the bars after to change the height the trailing arms will need to come out as the torsion bars wont fit through the holes as they are thicker than the splined ends. Just something to note if you hadn't thought of it.
  • Posted 12th Mar 2013 at 09:54
    Post #740
    So basically you love making things difficult for yourself, looking forward to another two years of updates on this thread before the car rolls again.
    Posted 12th Mar 2013 at 09:55
    Post #741
    Cheers for the heads up Dan Smile
    I hadnt thought of it, but hopefully shouldnt have to change the height once its set (he says). And if I do, hopefully it will come apart a lot easier than this time if most of the bits are new and not a corroded rusty state.
    Posted 12th Mar 2013 at 09:56
    Post #742
    Wouldn't have it any other way Whistle
    And it will be seeing a track this year, and like I said, it does still move. Going to be using it this weekend Smile
    Posted 12th Mar 2013 at 09:57
    Post #743
    COPPER SLIP EVERYWHERE
    Post #744
    cjm_harris wrote:
    Oh tits!
    Just buy my beam? Whistle
    Posted 12th Mar 2013 at 11:38
    Post #745
    I could do, but I wont be using most of it Laugh
    Posted 12th Mar 2013 at 11:53
    Post #746
    You can get some trailing arm shafts that already have a bore big enough fit a 30mm arb through.
    I got a pair of Febi Bilstein ones for around £108, my 30mm arb went through fine. Smile
    Posted 12th Mar 2013 at 18:53
    Post #747
    But you could sell the fancy bits and then you have a rebuilt beam muchos cheapos Wink
    Posted 13th Mar 2013 at 09:01
    Post #748
    So, planned to do some work on the car this weekend, but instead spent my time driving it instead. Went out for about an hour or so to remind me that in some cars the pedal on the right actually does something (I drive a NAD 306 daily...)
    And sticking with the ongoing theme of using it breaks it, my new issues are:
    - Odeometer has stopped working. Trip has reset to 0 and doesnt add any miles to that or total mileage.
    - Brake lights now constantly on.. not good!
    Any ideas? I will try and check out the brake light switch up behind the dash if I can find someone with girly arms that can reach it Laugh
    While I was out, had a quick "wet acceleration test" on a closed industrial estate. Not great at all, but took a video of it anyways Laugh
    and a picture of my pimping driveway Laugh my ass off
    Posted 18th Mar 2013 at 11:31
    clen666
    Post #749
    Lowest mileage 306? Should hold on to that one
    Team 'unintentional rat look'
    Posted 18th Mar 2013 at 11:56
    Post #750
    Thats just the trip, the odeometor is nearly 140k, but it might not get any higher Whistle
    Posted 18th Mar 2013 at 12:16
