displaying posts 676 to 700 of 1021
Pages (41): first .. 27 [28] 29 .. last
Author Subject: Harris' SC China Track Car attempt
Post #676
Yes you are.
Posted 5th Mar 2013 at 12:58
Post #677
Pretty much sure the little bracket on the left hand side of this is for the brake compensator valve.
I dont need this so attacked it with the angle grinder.
Posted 5th Mar 2013 at 14:22
Post #678
I will have to try that Deox-C.
I've been doing much the same preparing a 309 beam. Although I put it on hold after cleaning up a disc protector with a wire knot wheel on my angle grinder held between my patented feet-vice. I must have caught an edge badly as it flung the protector to the back of the shed and the grinder into my leg. Luckily it was the body of the grinder that hit me.
This gel sounds like a safe choice.
  • Posted 5th Mar 2013 at 16:22
    scotzman
    Post #679
    quote:
    There are 2 types Deox-C and Deox Gel, the Deox-C comes as a powder and you mix it with water, this works the better of the 2 but if its something too large to soak in the solution you will have to use the gel.
    Posted 5th Mar 2013 at 16:26
    Post #680
    Lucky escape Dan Shock
    And yeah I bought some Deox-C powder and Deox-C gel. Anything that is small enough to be submerged in water use the powder solution, if its not, used the gel. The gel will also be handy cleaning up under the car/boot floor area Smile
    Post #681
    Scotzman beat me to it Smile
    Posted 5th Mar 2013 at 16:27
    scotzman
    Post #682
    Razz
    Stuff is awesome though, I recently did a set of calipers, they came up really well.
    Posted 5th Mar 2013 at 16:30
    Post #683
    Yup, this is how my ARB fixings came up with a soak in some deox-C:
    Magic stuff.
    Posted 5th Mar 2013 at 16:48
    Post #684
    Yup, not only is it good at its job, the best thing is it requires f**k all work from us Laugh
    Posted 5th Mar 2013 at 16:50
    Post #685
    It's exactly my kind of stuff, throw it in and come back to it a day later and it's done all the hard work for you. Get in.
    Posted 5th Mar 2013 at 16:56
    Post #686
    Is it available on the high street at all?
  • Posted 5th Mar 2013 at 17:13
    Post #687
    Not that I know of mate, I wouldnt know where to look round my way, sure Halfords etc wont have it Laugh
    I bought mine from Opie oils and made use of an offer they had on.
    Posted 5th Mar 2013 at 17:14
    Post #688
    I think I'll go for the powder. Got a small cat trespass issue so this may eradicate more than rust if I leave something outside soaking in a bowl.
  • Posted 5th Mar 2013 at 17:17
    Post #689
    buy it direct
    http://www.bilthamber.com/
    Posted 5th Mar 2013 at 17:19
    Post #690
    Contact Bilt Hamber Laboratories directly:
    01277 658899
    Thumbs up
    Posted 5th Mar 2013 at 17:21
    Post #691
    Edit: beaten to it by the Welshman.
    Posted 5th Mar 2013 at 17:22
    Post #692
    It also makes quite a big difference if you use warm water, just make sure you get rid of any loose rust then leave it to soak. I ordered all mine from Bilt Hamber direct, along with a load of their Etchweld primer which is also pretty good.
    Post #693
    cjm_harris wrote:
    I'd have ground off the rest of the bracket, and probably drilled some holes too...
    I need to get out more.
    Posted 5th Mar 2013 at 17:26
    Post #694
    Yeah I used warm water too, but from the looks of the guide sheet that came with it, just helps with dissolving the powder in the first place?
    Post #695
    Pfft, its going under the car, its lucky I even cut that off Laugh
    Posted 5th Mar 2013 at 17:28
    Post #696
    Warm water will become cold in an hour, it's just nicer to work with initially, especially this time of year.
    Posted 5th Mar 2013 at 17:30
    Post #697
    I did mine all inside the house and left them near a radiator, doesn't make a world of difference but every little helps.
    Posted 5th Mar 2013 at 17:48
    Post #698
    Question guys..
    The bolts that go through the brackets shown above were pretty corroded, and the nuts seemed fubar'd. I went to buy a couple of new ones today and the place I tried to buy them from couldnt get them to fit properly and said it was probably due to the thread being slightly damaged.
    Bought some new bolts and nuts from them, but they have a shorter shank on them, will this be a problem?
    They were cheap enough so worth the punt, but want to check if they will be ok.
    Corroded thread on original bolt
    Old vs new
    Also, does anyone know what tensile strength the original ones should be? The new ones are 8.8
    Posted 7th Mar 2013 at 15:12
    Post #699
    The new nuts wouldn't fit because the thread pitch is different.
    Posted 7th Mar 2013 at 15:15
    Post #700
    Laugh
    Yeah I know that.
    Should of mentioned, I didnt buy the other nuts, but they measured the thread pitch of the bolt I gave them and tried a nut with the same pitch. It didnt fit, so they sold me the pictured nuts and bolts instead.
    Posted 7th Mar 2013 at 15:20
