displaying posts 651 to 675 of 1021
Pages (41): first .. 26 [27] 28 .. last
Author Subject: Harris' SC China Track Car attempt
Post #651
I think the bearing kit you'll need is part number 5132.62 (two off). - Best check that with someone in the know before you order though, i don't to be giving out wrong info. LOL
Then from a bit of looking on servicebox i think you'll need two of each of these:
5153.10
6963.10
6933.19
5153.11
5153.12
5174.03
5179.10
5179.14
5154.10
5154.09
I can supply you with both 6963.10 and 6933.19 since they only came in packs of 20, and i don't intend to rebuild my beams another 9 times. Laugh
Posted 21st Feb 2013 at 18:00
Post #652
So a bit of an update..
I have started stripping that rear beam I have, getting there slowly. Have bought some bilt hamber deox-c in an attempt to clean it all up a bit. I will post progress when there is some Laugh
Recently bought some GrpN engine mounts in an attempt to stop the engine moving so much.
I assume this is ok? No cracks etc, just seems a bit strange theres no paint there?
Also unsure about the clear bit of plastic, half of this was broken too. I assume this isn't OE and was done by a previous owner?
Now onto the gearbox mount..
And back together again, all good.....
Or not..
Car decided that it wouldn't start and had no power. No dash, no lights, nothing..
Connected up on the battery pack and got this..
Think moving the wires in front of battery box upset it. So pulled the apart, tidied with electrical tape, cleaned up connector and batter terminals and now it's fine again. f**king thing Laugh
So nervously I get in the car to take it for a quick test drive. The mounts have done an awesome job. Car feels so much better on the gear changes and can now change into second at more than 3k revs! Smile (anyone who came out in it at pugfest will know how bad it was)
So, may be slow progress, but getting there.
Posted 25th Feb 2013 at 19:50
Post #653
Now I'm no expert, but it would appear someone's nan has repaired your engine mount in the past.
Posted 25th Feb 2013 at 19:54
Post #654
Laugh my ass off
I was thinking similar myself, but to be honest don't care too much as it feels so much better than before Smile
Posted 25th Feb 2013 at 20:03
eddy_gti6
Post #655
Have you still not got your relocation kit on! Boy you take your time Laugh my ass off
Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url &amp; =
Posted 26th Feb 2013 at 13:00
Post #656
Nope Laugh my ass off
Its been on the list to do, but seems as soon as I touch/move any wires something breaks, so I've not trusted myself/the car yet Laugh
Posted 26th Feb 2013 at 13:02
aaron6
Post #657
Yeah, that mounts a repair job. Looks like a large washer gas been stitch welded on. But if its okay, crack on. Smile
The cars looking good. Smile
Posted 26th Feb 2013 at 13:18
Post #658
Thanks Smile
Yeah its different to what I have seen on here. Am I right in thinking it is ok to leave for the time being as it hasnt cracked the cradle?
Has helped no end changing the mount, had loads of engine movement before I was fully expecting to see the cradle in bits to be honest.
Posted 26th Feb 2013 at 13:22
Post #659
Got myself some Deox-C to aid in cleaning up my rear beam and parts ready to be built into a shiny new beam. The stuff really does work wonders.
5 minutes with a wire brush, then left for a few days in a weaker than suggested formula.
From this:
To this:
Just need to get time to finish taking apart the beam so I can give the same treatment to the rest of the parts.
Posted 5th Mar 2013 at 10:48
Post #660
Deox-C is amazing stuff, you'll want to get them sprayed up sharpish before any surface rust starts appearing though, doesn't take long.
Posted 5th Mar 2013 at 10:58
Post #661
Yeah getting it done asap.
Still unsure on whether to paint myself (rattle can or hammerite?)
Or get them done at the local powdercoaters?
Posted 5th Mar 2013 at 11:01
Post #662
Powdercoating will look infinitely better and will last longer, but cost more. I did mine myself and they're fine, depends how good you want it to look. Not exactly a part you see all that often.
Posted 5th Mar 2013 at 11:05
Post #663
Exactly, I couldnt care less if I'm honest. A friend of mine knows a powdercoater and rekon my beam parts will be about £40 - £50.
If I do it by rattle can, its not going to be much cheaper than that, and means me doing the work myself. If powder coating is going to be that cheap, may as well get it done.
Posted 5th Mar 2013 at 11:15
Post #664
Also, thanks Owain Thumbs up
I have ordered my "man up kit" (parts to remove my ABS). Just need to get a bias valve, but unsure which to get at the minute.
Posted 5th Mar 2013 at 11:16
Post #665
Ah good man. Just do be careful of the bias valves, make sure they come with adapters to make them M10 fitting as many aren't as standard.
Yeah if you don't already have primer and paint, get them powder coated. I bought loads of primer from Bilt Hamber a couple of years ago, so it wouldn't be any new outlay to spray up any new parts, but if you need to buy it all then you don't save nearly as much money.
It's good fun having no ABS, especially on a wet day at Rockingham. I had my slowest ever "crash" through some cones coming up to the last hairpin, the marshall was looking in my direction and I was looking at him as I locked up about three times, and just slid forwards knocking a cone flying.
He had the look of "thanks you bas**rd, I have to go get that now" and I had a face of "yeah, sorry about that. Worst crash ever."
Posted 5th Mar 2013 at 11:27
7057sam
Post #666
Chris man up and do them yourself LOL
Nice update, im currently in the process of cleaning my engine bay.Wondering whether to buy a steam cleaner.
Put up a link of the abs fit you getting
Team rallye,built for track
Rallye dead Sad
Secret Team Astor...
Posted 5th Mar 2013 at 12:37
Post #667
They don't rust Wink
  • Posted 5th Mar 2013 at 12:39
    Post #668
    Okay, don't bother painting them at all then, slap them on as they are Thumbs up
    Posted 5th Mar 2013 at 12:41
    Post #669
    I would do but..
    a. you may of seen earlier on in the thread, my spraying isnt exactly good
    b. I dont have the paint to do it myself, probably cost me like £40 for all the primer, paint and lacquer
    Posted 5th Mar 2013 at 12:42
    Post #670
    Posted 5th Mar 2013 at 12:45
    Post #671
    What are they made of?
  • Posted 5th Mar 2013 at 12:52
    Post #672
    Steel?
    Post #673
    I thought Jsoulman said they were ali.
    As you were LOL
  • Posted 5th Mar 2013 at 12:54
    Post #674
    You'd happily drive around knowing your entire rear beam was attached to the car by a bolt through 2mm ally? LOL
    Passive rear steer FTW, until metal fatigue drops your rear beam on a roundabout.
    Posted 5th Mar 2013 at 12:56
    Post #675
    I am going to have to say yes aren't I.
  • Posted 5th Mar 2013 at 12:57
