displaying posts 176 to 200 of 388
Pages (16): first .. 7 [8] 9 .. last
Author Subject: Midlife's Rallye
midlife
Post #176
You can't beat rattle cans Dave!!!
Oh & look what arrived in the post todaySmile
Cool
Team 330™Cool
Team "no front end or engine"
Posted 13th Oct 2010 at 03:20
Post #177
midlife wrote:
chris with a pug wrote:
Did you check all ur ring gaps?
All I did was try a ring in each bore, there was a gap but I didn't measure itDunno
Guess I'll have to trust the machine shop..
Cool
NO! NO! NO! Rule Number one. Don't assume anything! The top ring gaps on all my Wossners were tight or butting together. Each ot the four needed hand filing to get the perfect gap and so did two of the second rings. If you don't have sufficient clearance when the engine fires they will heat up expand and scrape themselves against your bores destroying themselves at best and damaging your lovely expensive bores at worst.
Filing rings is tricky and time consuming but is a VERY important part of the block build proccess. If you rush it, you can very easily turn your expensive 'umper'that blows combustion pressure into the crankcase wasting power and blowing by really heavily through the crankase breather system.
Rings can be filed by had or if you have access to a ring grinder use that. File from the outside of the ring inwards, take care not to drag the file backwards accross the ring as the hardened finish on the rings outer edge can chip, if this happens you will more than likely need to buy a set as I bet you won't get an individual one. Regularly close up the gap and hold the ring up to the light to check you are filing dead square, you should'nt be able to see any light through the gap. When checking the gap with a feeler guage in the bore, use the top of a piston inserted in the bore to push the ring down square.
You may find that the ring gaps are all ok, but if they are it's down to luck and a total accident. I would'nt take that chance given the care and attention to detail not to mention expense you have demonstrated so far. Wink
Posted 13th Oct 2010 at 03:46
Post #178
Looking goodCool
While you have the pistons out to check ring gapsWhistle
Put the rings in correctly tooWink ring gaps should be at thirds on the piston,not dead oppositeSmile
If you put the first two opposite you end up with the third ring gap directly below the first ring gapWink
Posted 13th Oct 2010 at 04:02
Post #179
Just offset them slightly, less blow by with them opposite but you don't want the gaps overlapping.
Posted 13th Oct 2010 at 04:07
midlife
Post #180
I thought filing the ring gaps went out of the window 20 years ago????
If memory serves me right you should use a diamond file for this job.
WTF are Wossner playing at supplying rings that are the wrong size for the bores the pistons were designed to fit intoDunno
As for ring gap positions the top two are diametrically opposite, the two thin rings either side of the oil scraper ring IMO are not there to aid compression but to stop the scraper ring from waring the top & bottom of the ring groove as it rotates? Anyway the gaps have been installed 90 degrees either side of the gap on the second ring down.
f*ck me do I really need to take the pistons out & check all the gaps? I assume the gap needs to be approx 0.004" or 0.10mm working of roughly 0.001" gap per inch of piston??
Doh
Team 330™Cool
Posted 13th Oct 2010 at 04:32
Post #181
0.3 to 0.5mm for stock rings, dunno for Wossner ones, should say on the instructions Ninja
Posted 13th Oct 2010 at 04:49
Post #182
Are they bevelled or straight cut?
Personally I find clamping a dremel in the vice with a grinding wheel in makes a much easier job of sizing rings than a file, less chance of pulling an edge out too.
More like at least 0.004" and a little more for the second ring too. LOL
Posted 13th Oct 2010 at 04:58
midlife
Post #183
There were no insructions with the pistons!
I spent quite a bit of time trying to see if they were bevelled & gave up in the end because they looked straight, to be cautious though I installed all the rings with the markings uppermost.
I'm still struggling to believe that Wossner supply rings with undersized gaps!!!
0.3 to 0.5pm does sound a lot, when I tried my rings in my old block the gaps were 0.2mm which I thought was excessiveDunno
I struggled getting the caps off on the bench, it's going to be near on impossible on the crank!
Cool
Team 330™Cool
Posted 13th Oct 2010 at 05:03
Post #184
You might need a little bit more than that what with it being high boost to cope with the extra heat Dunno
Posted 13th Oct 2010 at 05:15
midlife
Post #185
You'd think that the required ring gaps would be common knowledge Dunno
Cool
Team 330™Cool
Posted 13th Oct 2010 at 05:21
Post #186
Suprised they weren't included in the instructions tbh, I'm sure they used to list them in the old catalogue.
Posted 13th Oct 2010 at 05:24
chris with a pug
Post #187
When we did Jims pistons some of them actually touched and had no gap at all. But Daves where ok so its very Hit and miss for some reason
Posted 13th Oct 2010 at 11:34
Post #188
Doh
They are purposely supplied with extra material so the engine builder (You) can finish them to the exact size required. It's not a failing or Laziness on Wossners part, it's so you can make up for any slight machining discrepancies in the individual bores. A fine carborundum stone works very well if a little slowly, thats why a ring grinder is a luxury, but they are expensive for a one use only tool, so I did mine the labour intensive way. Don't forget we are talking tiny ammounts of material bieng removed here.
Posted 13th Oct 2010 at 15:30
Post #189
According to my book, and you may need to adjust these as you are on the next oversize but as a guide:
Top ring gap 86.0mm Bore 0.36mm
Second ring gap 86.0mm Bore 0.30mm
If in doubt, try contacting PEC and see if they have any suggested figures.
Posted 13th Oct 2010 at 15:37
lewisdmz
Post #190
Just read through this from the start. Nice work, bet you can't wait to get it back on the road.
Posted 13th Oct 2010 at 17:49
Post #191
Right, I dug out the ARP instruction sheet that came with my rods.
Here is the highlights:
Use ARP rod lubricant on the threads and face of the bolt
ARP reccommends using the stretch method for torquing bolts. Follow instructions for using a stretch guage. Stretch bolts to .0058-.0062.
If you do not have a stretch guage, follow these steps using the ARP moly assembly lube. Aftre rods are installed into the motor, torque bolts up to 45 ft lbs. Loosen the bolts. Torque to 45 ft lbs again. Loosen the bolts and torque to 45 ft lbs for a third and final time.
A log should be kept of the original non-torqued length of each bolt. Bolts that have any permanent deformation or have increased in non-torqued length should be replaced.
Posted 7th Dec 2010 at 23:44
midlife
Post #192
Thanks for your advice ladsThumbs up
So were saying
Ring gaps, top 0,36mm, next one down 0,30mm.
ARP L19 conrod bolt torque 45 ftlbs
Does everyone concur?
Cool
Team 330™Cool
Posted 14th Oct 2010 at 02:37
Post #193
Double check with Rich, but it's usual to go another .05mm bigger on the ring gaps with boosted engines - and that's at less boost than you're running.
Posted 14th Oct 2010 at 02:40
Post #194
Sounds like 0.40 and 0.36 respectively would be about right then(But get confirmation first). You want the smallest gap you can safely get away with as radial wear will only cause the gap to get bigger over time. Obviously you want it to make good compression for as long as possible so the closer you can get to the minimum safe gap the better. Not that you will loose much power from a bigger ring gap, but every little helps.
Posted 14th Oct 2010 at 03:38
Post #195
It's the emissions that tends to suffer more than anything tbh.
Posted 14th Oct 2010 at 03:40
midlife
Post #196
I've found this
http://www.wiseco.com/PDFs/Manuals/RingEndGap.pdf
Using their calculation chart
86.5 bore = 3.4"
Moderate turbo/nitrous = 0.005"
so 3.4 x 0.005 = 0.017"
x 25.4 = 0.43mm for the top ring
Moderate turbo/nitrous = 0.0055"
so 3.4 x 0.0055 = 0.0187"
x 25.4 = 0.475mm for the second ring
I think that sounds more like it, I far prefer to see how the gap has been calculated!
Cool
Team 330™Cool
Posted 14th Oct 2010 at 04:20
Post #197
I thought the 2nd ring gap was supposed to be tighter tan the 1st?
Posted 14th Oct 2010 at 04:29
midlife
Post #198
According to the PDF the second ring gap should always be bigger than the top ring gap to help reduce top ring lifting & flutterDunno
Cool
Team 330™Cool
Posted 14th Oct 2010 at 04:46
Post #199
Peugeots own specs show the lower ring gap bieng tighter. My Guy Croft workshp manual suggests that bigger ring gaps for Turbo and Supercharged are unneccessary.
Have you thought of contacting Wossner directly to get a difinitive answer?
Posted 14th Oct 2010 at 05:44
Post #200
Cool
It's easy, undo the rod bolts about four turns, then tap them gently and evenly with a soft faced hammer and it will pop the caps off a treat Wink
Posted 14th Oct 2010 at 05:51
