displaying posts 151 to 175 of 388
Pages (16): first .. 6 [7] 8 .. last
Author Subject: Midlife's Rallye
greenbelt
Post #151
puglover wrote:
phillipm wrote:
will these be same as standard?
They'd better be Dry
Standard Black 6
Black HBSC6 Smoke
Posted 6th Oct 2010 at 02:15
chris with a pug
Post #152
Do you have the links for that paint and te brembo stickers?
Posted 6th Oct 2010 at 02:29
midlife
Post #153
I got the engine enamel & caliper paint from a seller called usauto1997 on eBay. The iPhone won't allow me to copy links from the eBay ap.
The brembo stickers came from eBay too, I got 8 for about 3 quid delivered, I'm not 100% sure they are the right size but they look close
Cool
Team 330™Cool
Team "no front end or engine"
Posted 6th Oct 2010 at 02:53
h2xby
Post #154
Love the build thread! This is going to be awesome when it's finished! You have an eye for detail
Posted 7th Oct 2010 at 18:45
Post #155
midlife wrote:
Small update time...
I got round to lapping in the two new valves today & then stuck what I could get of it into my shiney new parts washer.
I then set about fitting the freshly bored replacement block on my engine stand.
I'm waiting for valve stem oil seals, water pump, race spec bearings, head bolts & Richw uprated head gasket to arrive in the post so I decided to paint the block.
WARNING SUNGLASSES REQUIRED.......
First off I masked up the block, any threads, mounting points, top & bottom.
This is what I got to paint it with.
Now I did say get your sunnies on didn't I...
Now my roots are in rallying & I was always taught that everything under the bonnet should be painted a light colour (normally White) so you can see problematic oil leaks more easily, I'll be able to see a dead fly on this fooker from a mile awayLaugh my ass off
It should be nicely cured next week for when I'll hopefully start putting it back together.
Cool
yeah!!!! team yellow
Posted 7th Oct 2010 at 18:51
rallyestyle
Post #156
I have a couple of cans of the yellow caliper paint in my loft, will be interesting to see how yours end up, might persuade me to use mine Yes
Just Drive It
Posted 7th Oct 2010 at 20:50
midlife
Post #157
Update time again.....
I took a few things to the garage today to make a start on putting the engine back together..
The main bearing caps were filthy so went in the parts washer.
First I fitted the oil spray bars
I then fitted the main bearing halves into the block, coated them liberally in assembly lube & put the crank in place.
All the main bearing caps are numbered 1~5 with number 1 at the flywheel end, this cap has a rubber seal at each end that looks like a hockey stick, £1.16 + vat each from the stealers.
When I stripped the engine there was a small oil leak from these seals so I put some RTV silicone rubber sealant on to help things a little.
All main bearing caps throughly cleaned, bearings fitted, plenty of assembly lube, caps fitted & torqued down.
There are also 4 shims that fit around bearing No2 to limit crank float, I didn't forget to fit them I was concentrating on putting them in properly & just forgot to take a picDoh
Now we get to the expensive bit....
Wossner low compression pistons & Max Speeding rods.
The tricky bit was fitting the spring clips, I was convinced I'd lose one, in this instance I was lucky, for once!!!!
Fit a spring clip at one side of the piston then with a little bit of assembly lube push the pin in from the opposite side.
Put the little end of the rod into the gap & push the pin through into the other side of the piston up against the spring clip, remembering to use assembly lube & the fit the spring clip in the other end to trap the pin.
Eventually after what seemed like ages they were all together..
Fitting the rings was easier than I remember in the past, there were a total of 5 rings to fit into 3 ring grooves.
Bottom groove, 2 very thin rings, 1 either side of the oil scraper ring.
Middle groove, thin ring.
Top groove, thick ring.
All fitted....
Now I'm ready to fit them into the block, I spec'd my rods to come with ARP L19 con rod bolts, my problem is I don't have any ARP lube to torque them up with, I now know what the torque setting should be though (thanks Meirion).
Looks like I'll have to source some ARP lube from somewhere.
Left it there, it was getting late & I didn't want to risk rushing to fit the pistons into the block & possibly f*ck the rings up!
I'm back in the garage tomorrow so I'll post another update then.
Cool
Team 330™Cool
Posted 10th Oct 2010 at 03:45
smighall
Smeg-all
Post #158
Looking good.
Oh and yellow Brembos FTW
Meh
Posted 10th Oct 2010 at 04:35
midlife
Post #159
smighall wrote:
Looking good.
Hehe, that looks bang tidyThumbs up
Cool
Team 330™Cool
Posted 10th Oct 2010 at 04:46
Post #160
Oh man, I'd kill to be able to do engine rebuilds, but seeing as I can't even remove and replace the ashtray without having bits left over I think it's probably not going to happen.
Keep up the good work matey, really good thread.
Posted 10th Oct 2010 at 15:06
midlife
Post #161
Another update....
Removed the ARP L19 bolts & split the first big end, made sure the piston ring gaps were opposite each other & fitted the piston ring compressor.
Then fitted the big end bearing half into the rod, assembly lubes up the bore & journal on the crank & carefully put the assembly into the block until it was resting on the ring compressor.
At this point make sure that the ring compressor is sitting perfectly flush to the block & tap the top of the piston with the end of the shaft of a BFH, the piston slowly slides into the bore. TFFT!!!!
Now tip the block on it's side & push the piston into the bore whilst guiding the end of the rod to fit snugly against the journal on the crank. Once in place fit the other half of the bearing into the end cap, coat with assembly lube, slot into place & fit the 2 bolts.
There is an arrow on the crown on each piston & fingers crossed they should point towards the front of the engine, before I split each rod I marked an arrow on each cap in the same direction as the one on the crown so it all went back together correctly.
Before long...
Now because I've not got any ARP lube yet I can't torque up the big ends so that means that I can't fit th oil pump etc & get the sump on so I finished off by bolting a few bits & bats onto the block. This is where the parts washer came into it's own, all the bits were covered in dirty oil & road grime, 10 minutes in the washer & a good going over with a toothbrush cleaned things up nicely.
This is where I'm up to now...
I've bought some ARP lube off eBay so hopefully if it arrives in time I can complete the bottom end next weekend.
I've got to go to the stealers again to pick up the bolts to hold the timing belt tensioner in place as it's mounted differently on the 137 tooth kit.
Cool
Team 330™Cool
Posted 11th Oct 2010 at 12:38
davedgti6
Post #162
looking smart Wayne Cool are you gonna use the 137 tooth cambelt setup then? thought everyone swayed towards the 136 tooth one nowadays Cool
Posted 11th Oct 2010 at 01:55
Post #163
If your assembly lube is a heavy moly fortified version it should do the job...
Posted 11th Oct 2010 at 02:00
midlife
Post #164
I'll give the 137 tooth a go, I'm sure Pug know bestDunno
I've ordered the proper stuff now Jean Luc, it will come in handy for the head bolts too.
Cool
Team 330™Cool
Posted 11th Oct 2010 at 02:04
Post #165
May as well wait then!
Posted 11th Oct 2010 at 02:09
Post #166
does that water dizzy block with the 2 outlets fit the other xu10 blocks? (or does anyone know?)
Posted 11th Oct 2010 at 04:29
chris with a pug
Post #167
Did you check all ur ring gaps?
Posted 11th Oct 2010 at 05:47
midlife
Post #168
All I did was try a ring in each bore, there was a gap but I didn't measure itDunno
Guess I'll have to trust the machine shop..
Cool
Team 330™Cool
Posted 11th Oct 2010 at 06:39
eddy_gti6
Post #169
Cool
i get the same ones but in white. how you painting your calipers? just spraying them or powder coating? i have mine to do but cand decide weather to go gray or red?
midlife wrote:
smighall wrote:
Looking good.
Cool
they look Cool
Posted 11th Oct 2010 at 12:14
midlife
Post #170
I've bought a spray can of yellow caliper paint off eBay.
Cool
Team 330™Cool
Posted 11th Oct 2010 at 12:36
puglover Banned!
Post #171
you sometimes have to cut the rings to fit. could be that they are out of tolerance No No
Posted 12th Oct 2010 at 19:07
midlife
Post #172
Well Jonathan from Adapt Engineering came into work today & took my ancillaries bracket away to sandblast it for me, 2 hours later he was back & what a good job he's made of it!!
Here it is masked up ready to paint
Sunglasses time!!!
Happy days, should be ready to fit at weekendThumbs up
Cool
Team 330™Cool
Posted 12th Oct 2010 at 23:40
rich_w
Post #173
Good progress sir, and loving the yellow theme!
Cool
Contact Details:
07732 822546
Posted 13th Oct 2010 at 00:15
midlife
Post #174
Cheers Rich!!
Fitting the roll cage nearly finished me off but I've got my motivation back nowSmug
The projects section certainly helpsThumbs up
Cool
Team 330™Cool
Posted 13th Oct 2010 at 01:40
davedgti6
Post #175
Your engine bay is going to look cool once its all done, wish I had time to get mine like that but my garage is too small and I have no compressor Sad , tis annoying as I can spray (used to spray joinery stuff in work) and I know I could get mine spot on,
Keep up the good work Thumbs up looking great so far Smile
Posted 13th Oct 2010 at 02:41
