displaying posts 301 to 325 of 485
Pages (20): first .. 12 [13] 14 .. last
Author Subject: My Rallye - V6 install page 3
Post #301
roland rat wrote:
i hate you! Angry
if your masks and alloys disappear dont blame me! Razz
Laugh my ass off
Neither would suit your current car anyway - i'll wrap it white or red for you if you want?Whistle
Nah its wouldnt be worth anything then,100 black ones and all that Roll eyes
Posted 22nd Feb 2010 at 02:41
marksorrento205
Post #302
What I could not get my head around, was the pump did not prime on the 2nd position of the ign key like the 205 / 306 does. So when I was testing / tracing it etc there was no power to the pump. However when I went to start the car, power went to the pump. Its like the fuel pump starts when you crank the engine. Strange and took some figuring out, but it works (well on the 205) and once the engine is started it carries on running untill you switch the ign off as it should. We have not fitted an inertia switch yet as we did not have one but its a quick job once we get hold of one Smile
Posted 22nd Feb 2010 at 02:47
Post #303
Ah now thats interesting. I'm not sure we tried starting it with the park switch connected at all.
Cheers Mark - that might sort out that headache completely Big grin
Posted 22nd Feb 2010 at 02:51
Post #304
I was thinking about wrapping mine black just for a laugh Ash. But really I think i'll go for something obviously wrapped next time. Its a lot of work though so it can stay as it is for the time being.
Wink
Posted 22nd Feb 2010 at 02:55
marksorrento205
Post #305
One thing that may be different is yours is an auto set up isn't it? Is that not just a case of joining the in and outs etc? Or is the 306 much more complicated?
Posted 22nd Feb 2010 at 02:56
Post #306
ecu/loom was off an auto, seemed to worked fine when the fuel pump was powered up directly, never tried to fire it up with the park/neutral switch earthed Doh thought they did prime but evidently not LOL
The main issue we have in figuring out what's stopping it from running the pump is that there's no data for what signal several of the wires give Roll eyes
Ade did comment that the ECU's were the same from manual to auto, but I haven't seen a Manual wiring diagram, and I know that there is a different part number for the manual/Auto ECU's.
Posted 22nd Feb 2010 at 03:14
Post #307
The ECUs are the same though apart from the park switch it seems. Does also seem to be just a case of joining the ins and outs yes. Well very nearly anyway...
Meirion/welshpug has done 99% of it so my understanding is limited. However I did look into the relay issue with him Smile
edit: too slow Doh
Posted 22nd Feb 2010 at 03:16
marksorrento205
Post #308
You not got autodata Mei? Thats what I used, that after a quick look at the wiring diagram on M@tts sig over on drivers. Whats the part no of the ecu you have and the one for the manual car. Daz has a spare ecu at mine that we have had his car running on so we know it works. I can check the pt no and see which one it is. I belive it came with the engine package which was a manual one. He may part with it but that would be between you and him, and if it made a difference???
As for the fuel pump wire, we only used one. It comes from one of the double relays. I dont do wire no's or colours so I can help that side of things. I have never found a pug wire that matches the dia so do the good old "bell the wire out" methord and use pin no's Smile
Posted 22nd Feb 2010 at 03:56
Post #309
yup, have autodata!
IIRC the ecu's part number ends in 234, can't remember 100% what the other part number I've seen is.
off ATP's listing the part number is 0 261 204 076 for the Xantia/406, and 0 261 204 407 for the Coupe, though its by no means an exhaustive and up to date listing.
fuel pump is wired to the relay fine, it ran when I gave it 12v up its ass at the relay!
just no power from pin 3 of the ECU to trigger that part of the relay for the fuel pump.
Posted 22nd Feb 2010 at 04:41
marksorrento205
Post #310
Should you be getting power from pin 3 of the ecu or should it ground it? Pin 3 from the ecu goes to pin 10 of the double relay. The other side in on the double relay (pin 2 ) is coming from the battery + or perm live is it not or am I missing something? I will see which part no ecu we have other the next couple of days
Teestuffs ecu part no that we have had his running on ends in 407
Posted 27th Feb 2010 at 03:44
Post #311
yeah, that's correct, perm + to 2 and 11, switching from the ecu between 10 and 3, power to the FP from Pin 1
not sure what kind of signal it needs exactly but Autodata says 11-14v on ignition, i.e as in for a prime, which is why I thought they did, but then much less Voltage when the engine is running for soe reason, enough to pull the relay on I guess.
Posted 22nd Feb 2010 at 04:44
marksorrento205
Post #312
Nuts and bolts anyday LOL
Posted 22nd Feb 2010 at 05:00
Post #313
Until you get to the sodding seat bolt Laugh my ass off
Posted 22nd Feb 2010 at 19:16
Post #314
Update:
Seat is in (gravel in the way doh).
PAS pipes now on, had to have one made up to fit.
Top mount padded out to try to reduce engine movement.
ECU and relays have been moved to the other side of the car to sit the 306 battery box.
Clutch cable fettled again
At some point we've picked up a wiring fault as it now won't start. Turns over fine, relays seem to be powering up but no starting. Got to go back over all the extended wires to check they are ok. If they are then its pointing towards the ECU stopping working for some reason. Still have the fuel pump relay issue as well.
Typical as it'd be on the road otherwise. Angry
Posted 25th Feb 2010 at 15:09
Post #315
Teething probs huh? Sad
Posted 26th Feb 2010 at 02:56
Post #316
bas**rd fecking wiring/ecu Angry
Posted 26th Feb 2010 at 03:07
Post #317
I think it might have p*ssed you off a tad Laugh my ass off
I'll go through everything again, check the immobiliser is correct as well - could be giving power as the key is right but not the right signal to the ECU.
Was also wondering if the alarm system had a hold on the ECU at all? Doubt it, but worth considering.
Posted 26th Feb 2010 at 03:40
Post #318
it is a bas**rd to swork out tho, i cant do wiring problems
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 26th Feb 2010 at 03:49
Post #319
I told you, they don't work unless they're in the middle! Razz
Posted 26th Feb 2010 at 05:15
Post #320
Well it did work.... Going problem-hunting sunday morning to see what I can find. Might be a buggered ECU or coilpack yet.
Posted 27th Feb 2010 at 03:19
Post #321
Thought you were good at the wiring side Mei, you could always let Mark help you out, he found it a doddle wiring up my v6 to be honest Smile
as adam said, we did get the bugger to start, and now it wont Angry
wiring is fine I think, as I said, it has started...
a manual unlocked ecu would help to trace the problem I think, the auto one wasn't wanting to play ball with the fuel pump relay but worked the other ones fine, i have a feeling something got damaged when we tried to get around the park/neutral switch.
we did spend several hours going through the loom buzzing through the modified wiring and checking live feeds etc, couldn't check to see if the injectors were firing as my power probe has died Sad
crank sensor is fine, we took it off and fitted it to Adam's 406 where it worked fine.
car is between Evesham and the nam Smile
Posted 27th Feb 2010 at 03:50
marksorrento205
Post #322
Is the part no listed on the previous page any help
Post #323
might be, I need to see what Goliath has on his, this one is a 234, I see Daz's is a Coupe ECU.
what confused me more is Ade's comment that all the ecu's are the same, and that Autodata shows the wires for the auto but no actual data for the signal/voltage req Doh
Posted 27th Feb 2010 at 03:53
Post #324
Finished this yet?
Posted 28th Feb 2010 at 00:24
Post #325
roland rat wrote:
Finished this yet?
LOL
Not yet no. Was attacking it with a multimeter earlier checking wiring. All good except the shield earth on the crank sensor isn't earthed. Unlikely to be the cause but will sort it out tomorrow and try it again. Will also swap immobilisers just in case.
Any replacement unlocked V6 ECU would be a fine thing to try! Smile
Posted 28th Feb 2010 at 00:32
