displaying posts 326 to 350 of 485
Pages (20): first .. 13 [14] 15 .. last
Author Subject: My Rallye - V6 install page 3
Post #326
just a thought Adam, how were you checking it?
with the ECU unplugged from the TDC sensor plug to earth? I dont think you'll get a circuit that was as its inside the ECU that the earth circuit is made AFAIK.
need to check from TDC pin 3 to ecu pin 24 I think, even though the diagram shows it as being connected outside Doh
Posted 28th Feb 2010 at 00:45
Post #327
Ok i'll plug it in and check tomorrow. Pin 24 is an earth anyway isn't it? Obviously the 406's ecu was plugged in earlier when I tested that.
Posted 28th Feb 2010 at 00:51
Post #328
yeah it is, I think its one continuous black cable from the crank sensor plug to the ecu.
Posted 28th Feb 2010 at 00:53
Post #329
okey dokey. Anything else I should check whilst i'm at it? I'm going to bung the crank sensor back in, reconnect the lambda and then try the immobiliser.
When thats failed I shall probably give it a wash with my tears of unhappiness.
Posted 28th Feb 2010 at 01:04
Post #330
Wouldn't use your tears as saltwater will rust her even more. LOL
Posted 28th Feb 2010 at 03:32
Post #331
Been looking into it again - crank sensor shield earth is fine and changing over the immobilisers makes no odds either. There is power to both coilpack and injectors, but no signal. The wiring to them is all fine. Looking like the ECU is blown somehow.
Really wierd!
Posted 28th Feb 2010 at 19:17
Post #332
Is it unlocked / have an immobiliser?
I'm borrowing a friend's unlocked ECU on tuesday to try it. I'm also wondering if its not 2x buggered double relays somehow...
Posted 1st Mar 2010 at 00:28
Post #333
doubt it, as they work fine if you swap them over don't they Hmm
I had fun ripping apart a 306 earlier, even attacked it with a grinder Devil
Posted 1st Mar 2010 at 00:36
Post #334
PM sent as you know!
Tomorrow am going to try an unlocked ECU, a different front coilpack and some other relays. Should be interesting! Smile
Posted 1st Mar 2010 at 21:04
Post #335
My money is on the coilpack - they aren't great by all accounts... will see later on!
Posted 2nd Mar 2010 at 14:27
Post #336
Hyper
Posted 2nd Mar 2010 at 17:57
rallyestyle
Post #337
Hyper
Does it work then? Unsure
Just Drive It
Posted 2nd Mar 2010 at 18:00
Post #338
dunno!
Posted 2nd Mar 2010 at 18:30
Post #339
Nope, wasn't the coilpack (unless the one we tried was no good too) and George hadn't had time to get the unlocked ECU so no go there either. His 205 CTi and new V6 are now in my unit so hes back tomorrow - no way was that engine/box/shafts/pedalbox coming out of the van with only 2 people to lift it.LOL
Had a thought which i'm going to try out in a bit...
Posted 3rd Mar 2010 at 17:03
Post #340
Got fuel, but no spark.
Been mucking about with it a tad more and the plugs are nice and fuelly. That'll do until more spares turn up tomorrow
Posted 3rd Mar 2010 at 18:31
Post #341
fuel?! Shock
Posted 3rd Mar 2010 at 18:44
Post #342
Whats so shocking about that?
Farking cars are doing my head in - the 406 broke down 5 miles from work so i've had to walk back and get another battery to get it back. (dead mobile as well). Angry
Lush sunny day though Smile
Posted 3rd Mar 2010 at 21:28
Post #343
I thought we had nada LOL though couldnt check properly with a dead probe Doh
If you have fuel you should have earth pulse for the coilpack too, if the ECU is not deid.
Does the Fuel Pump work now?
what died on the 406? Alternator?
Posted 3rd Mar 2010 at 21:42
Post #344
Yeah alternator on the 406 - looks the same as the 306 one. If its not its going on there anyway. Big hammer and an angle grinder time Angry
Fuel pump doesn't work, no idea on the earth pulse - how do I find that out? When I try to start it all of the 'signal' earth wires to the coilpack are always earthed all the time. Thats what the multimeter says, but no idea how good that is.
Posted 3rd Mar 2010 at 22:22
Post #345
either by taking the fuel rail and seeing if fuel squirts out, which is a PIT on this engine, a power probe on the injector to ecu wire, or a thing called a "noid Light" which you plug into the injector wiring plug, it flashes when it sees the signal.
not sure what else would work fast enough to show it.
Alternator might have been that crunchy noise Doh
Posted 3rd Mar 2010 at 22:34
Post #346
Alternator was that crunchy noise - bearings are fooked along with the rest of it. PAS pump and the tensioners are fine.
The plugs on the front bank were all smelling and wet with petrol after i'd turned if over for about 30secs. I'm afraid I don't have a power probe!
Anyway George is back tomorrow with the unlocked ECU, relays, coilpack etc etc. Theres a spare V6 in the unit now as well - might as well chuck it in the boot Shifty
Posted 4th Mar 2010 at 01:11
Post #347
I aint stripping another V6! LOL
Posted 4th Mar 2010 at 01:21
Post #348
Do you need a 306 alternator? Laugh I know where one is Whistle
Posted 4th Mar 2010 at 01:25
Post #349
No thanks i've got one on my 406 Wink
Calm down dear! Its the engine/box etc on a pallet ready to go Ash. Smile
Posted 4th Mar 2010 at 03:30
Post #350
GET THE f*ck IN!!!!!!
Big grinBig grinBig grinBig grinBig grinBig grinBig grinBig grinBig grin
One unlocked ECU and we have life! Oh and the fuel pump works as well.... Yaaaaaaaayyyyyyyy!!!!
Shame it p*ssed a load of oil out of a cam cover, but thats now fixed. I even drove it 10 foot.
Fair bit of fettling to be done but finally bloody works!
Posted 5th Mar 2010 at 00:09
