displaying posts 76 to 98 of 98
Pages (4): first .. 2 3 [4]
Author Subject: 309 project
rallyeash
Post #76
good work Smile
309 3dr K20 Type R
Posted 13th May 2010 at 12:57
rallyestyle
Post #77
jjrossi636 wrote:
Is that you in the Sainsburys outfit?
Not unless he has turned into a woman LOL
Looking smart Cool
Just Drive It
Posted 13th May 2010 at 20:56
smegal
Post #78
Looking good. Hope you got it in ok. (It was me with Bryce in the computer room)
Ex SC-6
Now in a Megane R26
Posted 15th May 2010 at 02:08
bobdylan_55
Post #79
14/05 got some more done last night. Managed to get the downpipe welded (very shabby but was in a rush) and got the megasquirt loom in with a few connectors wired up. clocked the turbo so could get the correct angle on the oil return and then fitted the return and feed. then the wheel fell off lol so had to fix that (ball joint had fell out) then i made a small tip for the backbox, then i went scrap yard and got some random coolant pipes, one for the thermostat housing to rad, and one for rad to water intake on back of block, but with an added t piece for header tank (as my water intake only has 2 ports in and out, not header tank)
15/05 i was out today and managed to get all the oil lines and oil cooler installed, and the exhaust tip on, and downpipe connected to exhaust
ok so heres the pics
for those who havent seen it (cant remember if i posted pics yet?) heres the gear selector and mounts. Looks a bit shabby but it needs welding still at the front and then ill spray it to match.
and heres a better pic of the custom gearbox mounting point. Its 4mm steel and also is doubled up (theres another piece underneath that bends down. aint going nowhere trust me Smile
can also see some of the megasquirt loom (still being wired in)
oil cooler fitted and oil lines etc. Just waiting for my ally catch tank to come for the 2nd port on the cam cover. If im quite honest im worried about how little air the radiators going to get because of the intercooler and oil cooler but if it is a problem ill address it at a later date.
New shortened 406 driveshafts were rebuilt today and just fitted them. They fit well or so it seems and im happy with them especially for the £50 i paid to get them done. (many thanks goes to paul simmons from 205 drivers)
309 GTi6-T
Posted 17th May 2010 at 22:32
binkagti
Post #80
Nice work mate
TEAM Supercharged Rallye
Posted 17th May 2010 at 23:33
peder_306
Post #81
Looking forward to see this start up.
Good luck mate
Peugeot 306 Dimma CoupƩ.
Posted 18th May 2010 at 00:25
peder_306
Post #82
How's it going sir?
Did you change the bore or does the s16 pistons fit without modification?
Regards Peder
Posted 2nd Jun 2010 at 23:16
pugheaven
Post #83
Couldnt find any info on previous pages, what injectors, map sensor,fuel pressure reg are you using?
Are you using gti6 cams and have you left the inlet manifold standard?
Posted 2nd Jun 2010 at 03:42
bobdylan_55
Post #84
sorry for no reply, just found yours.
s16 pistons fit bores as theyre the same.
injectors are bosch 403's that flow 503cc/min
map sensor is a 250kpa one fitted in megasquirt
fuel pressure reg is the standard one for now.
Gti6 cams and standard inlet with the plastic bit modified with a metal bung as it exploded lol
heres a vid
http://www.youtube.com/watch?v=AQw1lMX9uak
309 GTi6-T
Posted 19th Jun 2010 at 19:40
bobdylan_55
Post #85
have been working on this, just not updated the thread. Havent done a terrible lot, but heres a few pics.
made a custom bracket for the gear cables. They now clear the downpipe nicely. No pics, but also has to weld to the gearbox arm and extend the ball joint (make it higher by about 3 inches)
also started painting my spare set of alloys matte black
ive also started putting the front end back together, ie grill etc, (not bumper yet) to makesure it all fits around the oilcooler and intercooler. so far so good. Now that the gears are connected up, just need to finish making the hydraulic hose up for clutch, and then figure out how to bleed it, and then i can get it on the rollers Wink
309 GTi6-T
Posted 20th Aug 2010 at 23:05
bobdylan_55
Post #86
well the front end is basically back together now. Few problems which ill go into later, but heres the pics
As you can see im after a left hand indicator (ph1 if they are different?). The left hand headlight also does not fit correctly as the rad was moved across slightly and i didnt think about the fact that it needs to go in at an angle (measurements were wrong basically) so ive got to take off the ball mount and custom fab another mount for the light lol.
The bonnets not shut in the pics because it wont at moment (header tank is in way) but will shut fine when new header tank is fitted.
Also repaired the leak from the oil return from the turbo. Hydraulic hose and fittings for clutch still havent arrived grrr, so couldnt do that today.
good news. Finally got a part that my dad made for fitting the hydraulic line to the master cylinder. All i gotta do now is bleed it somehow (has no bleed nipple on the slave cylinder cause peugeot are idiots) and then it should technically move....
some pics, not very good tho
slave cylinder and hose
mastercylinder and hose and custom adapter.
hose routing.
309 GTi6-T
Posted 16th Sep 2010 at 23:43
bobdylan_55
Post #87
long time no seabass. Car was finally in a driveable condition (ish) no MOT tax etc so trailered it down to a track which i rented for 2 hours (£55 bargain) and had a little play. heres a vid i took
http://www.youtube.com/watch?v=R1XcAMcGGGo
could someone please linky it.
unfortunately the clutch pedals gone a bit wierd again and wont disengage fully (after about an hour of driving) so either an air leak or a shite clutch plate. Plans are to get rid of the slave cylinder and fit a different type of the newer 406 with bleed nipple on.
Track was also very icy so couldnt really get much speed, and also brakes for some reason wouldnt bite (despite feeling pretty solid ) so i need to look at them. apart from that all went well.
309 GTi6-T
Posted 28th Nov 2010 at 18:29
Posted 29th Nov 2010 at 02:08
rallyeash
Post #89
how come its misfiring so much? or is that the map?
309 3dr K20 Type R
Posted 29th Nov 2010 at 02:34
bobdylan_55
Post #90
just not mapped right yet. was hard to get it mapped cause of the ice.
309 GTi6-T
Posted 13th Dec 2010 at 13:40
zxturbo400
Post #91
what power you expecting pal? and what boost?
Posted 22nd Dec 2010 at 05:45
bobdylan_55
Post #92
around 300bhp hopefully and around 15psi
309 GTi6-T
Posted 22nd Dec 2010 at 14:22
zxturbo400
Post #93
Ah that sounds cool, Have you ever thought about using a gt2871?
Dp engineering have those running around 330-340 at 1 bar
cheers
Posted 22nd Dec 2010 at 19:02
bobdylan_55
Post #94
i had a budget and them turbos are about £1k each where as mine was less than half of that. after some calculations my turbo should be 78% efficient anyway, and theoretically should run 350bhp at 21 psi, so at 15 id hope for about 320 really. 300 is being safe (if it doesnt make 300 ill be turning the boost up and up and up until it either reaches 300 or blows up)
309 GTi6-T
Posted 22nd Dec 2010 at 23:32
zxturbo400
Post #95
haha fair play bud, i actually had the intention of using a to4e but i found a gt2871rs copy for £230(bit more that a to4e) so that fits the bill, dp say their kits with gt2871rs's make 320-340 at 1 bar, so at 1.2 bar i should make the region of 350+
Posted 29th Dec 2010 at 01:26
Post #96
Good interesting project, top effort Thumbs up
Posted 29th Dec 2010 at 02:23
bobdylan_55
Post #97
mmm
New refurbed rear beam can go on now aswell
309 GTi6-T
Posted 14th Jan 2011 at 18:45
mattgti6phase2
Post #98
bobdylan_55 wrote:
mmm
i have this exact same suspension kit!
i highly recommend it. my car handles beautifully with this kit. love this thread well done so far EPIC MACHINE!!!!!!
Guns
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 15th Jan 2011 at 01:40
