displaying posts 1 to 25 of 98
Pages (4): [1] 2 3 .. last
Author Subject: 309 project
bobdylan_55
hi, some of you may know i currently am doing a bit of a retoration/tuning on a 309 gti. Thought id upload the project thread so far onto here for you all to gander at Smile
Before
started the day just planning on taking the bumpers off to repair them. just after removing the front bumper, rajj decides to persuade me to rag the engine out lol
so here are todays pictures in order
[img]http://img21.imageshack.us/img2
309 GTi6-T
Posted 14th Sep 2009 at 23:06
MCH_GTi6
formerly mch
looks a cool project! I like it! keep us updated Smile
Team Moonstone� Ph3 GTI6
Team Rallye
Posted 14th Sep 2009 at 23:22
rallyeash
awsome project made, love it even more being in a 309. what power you hoping from it? should suprise a few peopleSmile
309 3dr K20 Type R
Posted 15th Sep 2009 at 13:34
bobdylan_55
looking for 350bhp ish, but as it only weighs about 950kg with driver and the bigger 2.0 engine its going to be putting out more like 380bhp per tonne lol, thats more than some well known porsches etc
309 GTi6-T
Posted 15th Sep 2009 at 14:32
birk
On standard pistons and rods ? thought turbo's needed high compression?
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 15th Sep 2009 at 17:23
bobdylan_55
no it needs to be low compression as the turbo adds compression when under boost. standard s16 pistons and rods have commonly been used to reach 400bhp.
309 GTi6-T
Posted 15th Sep 2009 at 17:26
birk
Ahh i get you.
Interesting, wonder if could get away with a compression plate on my supercharged engine and use standard rods and pistons ?
07889376885
Dan
Posted 15th Sep 2009 at 17:29
bobdylan_55
maybe, but gti6 pistons are slightly different to s16 pistons, theyre 1mm taller iirc. id not recommend it if going above 300bhp.
309 GTi6-T
Posted 15th Sep 2009 at 17:36
birk
Thought there would be a flaw in my plan LOL ill stick with low comp forged pistons and rods when i get some dosh then Smile
I'll stop boycotting your thread now aswell LOL
Good luck with the build, looks cock on, cant wait to see the finnished outcome Thumbs up
07889376885
Dan
Posted 15th Sep 2009 at 17:46
rallyeash
i thought s16 ones were longer?
309 3dr K20 Type R
Posted 15th Sep 2009 at 18:20
bobdylan_55
think its the other way around so ive been told. gti6 ones are 1mm taller, rods etc are all the same.
309 GTi6-T
Posted 15th Sep 2009 at 19:27
allanallen
This looks an excellent project, nice work with the manifold. Its always nice to see people doing something a bit different/doing the work themselves.
whats the advantage of running the j2te block over the j4rs? and what CR have you gone for, looks to be a fairly thick de-comp plate. al
Facebook
Posted 15th Sep 2009 at 20:01
bobdylan_55
the j2te block has oil lines as standard for turbo applications, so no need for tapping into sumps or t-ing into oil lines, its also apparently very slightly stronger and can handle more compression (note apparently). the compression has been lowered to approx 8.4:1
309 GTi6-T
Posted 15th Sep 2009 at 20:29
allanallen
gottcha, that saves some mither then. How much was the de-comp plate if you dont mind me asking. cheers allan
Facebook
Posted 15th Sep 2009 at 20:37
c.a.r.
Isn't that turbo manifold pretty close to the brake lines? Is it already a plan to re-route them?
Looks smart, the fabrication work is always nice to see.
'99 1.8 XS - Sold
'00 GTi6 - Killed by armco
'01 Cabriolet 1.8 - Sold
'96 Eunos Roadster 1.8 Import
Posted 15th Sep 2009 at 20:47
bobdylan_55
the decompression plate was
309 GTi6-T
Posted 15th Sep 2009 at 20:53
mike rallye
some excellent work been done. nice to see a 309 been saved and not going to the crusher
Posted 16th Sep 2009 at 01:06
bobdylan_55
lol the actual car itself is a complete shed, everything on it is seized etc, but its going to undergo a full restoration as part of my uni course so all is good Smile
309 GTi6-T
Posted 16th Sep 2009 at 02:52
mike rallye
are you going to be re-fitting the timing covers or leaving them off?
Posted 16th Sep 2009 at 02:55
bobdylan_55
well the engine is coming out again at some point, but im not sure if ill be fitting them. my brother runs his 106 xsi (all speced up throttle bodies, cammed etc) without a cam cover, and thats used regularly on road and on track (sprints etc) and is fine. might do for reasurance though, also gives me something to paint Big grin
309 GTi6-T
Posted 16th Sep 2009 at 02:59
chicken_rallye
quality looking project i am impressed!
always had a soft spot for 309's proper retro and were slightly overlooked wih the 205
good luck and keep the updates coming Smile
tap tap....BOOM!!
Now singing sweetly thanks to a fistful of cash and a friendly Rich_w!
Posted 20th Sep 2009 at 15:45
bobdylan_55
been and made this gasket in the garage this morning. bit tatty around the edges, but it should do the job Smile
its for the exhaust flange on the turbo Smile
got my re-positioning adapter for wastegate aswell, just going to go trial fit, so pics in a min Smile
309 GTi6-T
Posted 6th Oct 2009 at 19:56
bobdylan_55
wastegate is still a no Sad stupid bonnet is in way, and head aswell lol
this is the most complete ive seen it since the gutting started about a year ago.
got radiator in minus the fan, and then moved it back about an inch and slid it across towards the passenger headlight. This gave me the room the the intercooler piping to go past it as you can see (the blue pipe) and the intercooler fits infront of it, the other pipe will go down near where the horns are and then under the chassis and back up. i have about 65-70mm clearance between rad and intercooler, so anybody know of a slimline in that size?
309 GTi6-T
Posted 6th Oct 2009 at 19:57
bobdylan_55
intercooler bracket made and fitted, pipe work also fitted, however ran out with one pipe left needed Sad only 20cm aswell lol.
309 GTi6-T
Posted 8th Oct 2009 at 19:54
rallyeash
pipe works tidy and out the way, nice work Clapping
309 3dr K20 Type R
Posted 8th Oct 2009 at 20:00
