displaying posts 51 to 75 of 98
Pages (4): first .. 2 [3] 4
Author Subject: 309 project
rallyeash
Post #51
you going to run a hydraulic clutch with a slave cyclinder? Where did you get that box from?
309 3dr K20 Type R
Posted 6th Apr 2010 at 23:38
bobdylan_55
Post #52
yep hydraulic clutch as the ml5t box uses one as standard so i just need to get a pipe made up that goes from standard union to the poxy standard fitting. the box is from compbrake and i know how w*nk comp brake are surposed to be, but its not to bad tbh.
309 GTi6-T
Posted 7th Apr 2010 at 02:42
306andy
Post #53
Good to see you cracking on with this Smile If you need a hand with owt, i'm in Derby too so fire over a PM and i'll see what i can do
TEAM 205 GTi-5
TEAM Phase 1 GTi-6
xbox Live tag: SilverGTi6
Posted 10th Apr 2010 at 03:11
Post #54
bobdylan_55 wrote:
i seriously cant see them pipes coming off under only 15psi boost. maybe if i up the boost, but they are pretty smug fit and the clamps seem damn hardcore.
They won't stay on, trust me, first dyno run, they will blow off, and you will have wasted your time and cash booking the session. A local race team or anyone that makes ally radiators etc should have the swaging machine and they would only charge beer money to put the swages in as it takes no time at all. Just a thought, but bear in mind that when the hoses warm up they soften, oily air will work its way under the rubber and act as a luricant, and they will work loose as the engine moves. Something to think about thats all.
These boys are local, if they don't have the tool I bet they could put you in cotact with someone nearby that does.
Not a clicky:
http://www.derbyperformancehose.co.uk/contact-dph-silicone-hose.html
Thumbs up
Posted 10th Apr 2010 at 15:31
Post #55
Be good to see how it goes, I was thinking of using their pedal box too. Did you go for their budget range of master cylinders? Only I've heard some horror stories about those. I was going to use a combination of their box, but with Girling or AP master cylinders.
Posted 10th Apr 2010 at 15:33
bobdylan_55
Post #56
the master cylinders they sent out with the boxes are girling (so it says) im sure ill have fun with them :O
Cost of dyno run is £0 as its at uni and free. Ill have a look into that swagging. x
309 GTi6-T
Posted 10th Apr 2010 at 16:29
chris with a pug
Post #57
I have a comp brake box on mine, it was a bit of a fiddle to gt everything to fit right, but not to bad quality to be fair
Posted 10th Apr 2010 at 23:20
smegal
Post #58
Dyno at uni? Is that the engine dyno? If so I wouldn't hold your breath.
Ex SC-6
Now in a Megane R26
Posted 11th Apr 2010 at 04:36
bobdylan_55
Post #59
no the rolling road, ive persuaded sean to let me use it if i come in when theres nobody using the rooms. 7PM FTMFW
309 GTi6-T
Posted 23rd Apr 2010 at 03:12
bobdylan_55
Post #60
p.s lol
small update
turned the inside of the adapter plate out with a boring tool as it wasnt big enough for the metal hose outlet that peugeot supplied me with.
Then today ive been out and made a plate and fitted the resevoirs for the front, rear brakes, and clutch.
309 GTi6-T
Posted 23rd Apr 2010 at 03:13
smegal
Post #61
We have a Rolling Road? God I am ill informed. I knew we had a [non working] engine dyno but not a rolling road.
Ex SC-6
Now in a Megane R26
Posted 23rd Apr 2010 at 03:32
bobdylan_55
Post #62
are you on drugs? lol there is a big silver panel over the floor in the main workshop hehe Razz
309 GTi6-T
Posted 23rd Apr 2010 at 03:35
smegal
Post #63
I've only ever been in the workshop a couple of times. That is mental, eventually an engine dyno and a chassis dyno too.
Do you drive a blue XSI?
Ex SC-6
Now in a Megane R26
Posted 23rd Apr 2010 at 03:42
bobdylan_55
Post #64
we have an engine dyno, apparently it works though? was using the head benchflow tester today aswell, seems to work nicely.
And yeah, just picked it up a few days back, dark blue 306 xsi with standard xsi alloy.
309 GTi6-T
Posted 23rd Apr 2010 at 03:45
smegal
Post #65
I saw you in the shell garage a bit ago I was in the black fiesta next to you.
Whenever I ask Steve about the engine dyno the deadline for it being ready seems to slip.
Ex SC-6
Now in a Megane R26
Posted 23rd Apr 2010 at 03:47
bobdylan_55
Post #66
i swear the person next to me was a OAP? LOL
but yeah that was me in the purple sainsburys uniform Sad
309 GTi6-T
Posted 23rd Apr 2010 at 03:59
bobdylan_55
Post #67
got the engine back in today, however the 406 gearbox uses a different design of mount and so was 10mm short of the hole :S its also higher mounted so the gearbox sits low. Ive modified as much as i can without weakening the mount, but still at an angle.
Does this look ok? all the mounts are in, so its just the driveshafts im worried about really. cheers
also heat wrapped the manifold in blue Wink
309 GTi6-T
Posted 2nd May 2010 at 01:00
rallyeash
Post #68
i wouldnt like to leave it like that tbh. looks a bit worrying and isnt going to do the driveshafts much good. cant you get a bracket/mount knocked up atall?
309 3dr K20 Type R
Posted 2nd May 2010 at 01:42
bobdylan_55
Post #69
It isnt going anywhere so to speak, im just worried about the driveshafts as you say and maybe oil starvation around corners.
I might make one out of some 4mm steel plate and then just space it to get the right height, do you think itll be ok to run on a RR like it though just until its mapped and got a power output for my uni project.
309 GTi6-T
Posted 2nd May 2010 at 02:04
peder_306
Post #70
Hello sir.
I'm going to turbocharge the dimma and i was wondering about your setup.
You're using the s16 pistons and crank in the xu10j2te engine block?
With the decompressionplate, what are the compression you think?
Regards
Peugeot 306 Dimma CoupƩ.
Posted 10th May 2010 at 22:02
bobdylan_55
Post #71
3mm decomp plate gives me 8.4:1 and yes s16 pistons in the j2te block
309 GTi6-T
Posted 10th May 2010 at 22:04
peder_306
Post #72
Can I ask why the j2te block?
What would the comp be on a standard s16 engine?
sorry mate, it's just so interesting Big grin
Posted 11th May 2010 at 01:47
bobdylan_55
Post #73
the compression would be exactly the same as its a common crank. Im using the block as its already from a turbo engine so has turbo feed and return ports, and hopefully should be a bit more sturdy.
309 GTi6-T
Posted 11th May 2010 at 17:46
bobdylan_55
Post #74
another update.
another gearbox mount has been fabricated so the engine sits straight now.
the intercooler and rad have been refitted and mounted properly
the wastegate is refitted and now fits under the bonnet and also has a small screamer pipe on Big grin the blow off valve is also fitted
the plumbing is done for the wastegate and blow off so they open when they should, and the extra slim fan is fitted 50mm Big grin
finally spent the night with my bro tacking this downpipe up Smile
cheers
309 GTi6-T
Posted 13th May 2010 at 04:26
jjrossi636
Post #75
Is that you in the Sainsburys outfit? ha, its looking good, will be a right beast when its all done.
Thumbs up Smile
Posted 13th May 2010 at 12:52
