displaying posts 26 to 50 of 98
Pages (4): 1 [2] 3 .. last
Author Subject: 309 project
bobdylan_55
yeah it fit nicely Smile worried about the wastegate hitting the silicon joiner on turbo though, will get too hot i think and melt the silicon.
309 GTi6-T
Posted 8th Oct 2009 at 20:04
binkagti
Just a word of warning mate, those hoses will pop off straight away, even using mikalor clamps, also will be very laggy because of the lengh of the pipes and how many bends there are. Just my opinion but have done this all ready on my car. Mine looks like this:
TEAM Supercharged Rallye
Posted 9th Oct 2009 at 03:08
bobdylan_55
the clamps im using are 20x stronger than jubilee crap, they will be ok otherwise they wouldnt be used by everybody for turbo conversions.
as for the lag, im expecting it to be laggy anyway due to the size of the turbo, but ill be sorting that out in due time.
309 GTi6-T
Posted 9th Oct 2009 at 03:11
binkagti
Cool beans mate
Posted 9th Oct 2009 at 03:18
bobdylan_55
stainless steel for exhaust im fabricating Smile
309 GTi6-T
Posted 15th Oct 2009 at 18:31
306andy
Excellent work so far chap. Keep it up.
One question though: Aren't the branches of the exhaust manifold supposed to be of equal length? As it seems that #2 & #3 are considerably shorter than that of #1 and of #4. Am i completely wrong here?
TEAM 205 GTi-5
TEAM Phase 1 GTi-6
xbox Live tag: SilverGTi6
Posted 16th Oct 2009 at 01:05
rallyeash
may sound like a scooby then....
309 3dr K20 Type R
Posted 15th Oct 2009 at 19:22
bobdylan_55
it depends. if you get them equal then it gives smoother faster spool under load, but if theyre different lengths then you get random pulses down the pipes, so the turbo keeps spooling a little when you let off, so when you put foot back down its already half spooling. might be a complete eric fail, but if it is i can write about that in my assignment and then fix it for next years project Smile
scooby maybe, eviler hopefully Smile
need a backbox to weld on which has a 3" bore cant find one anywhere
309 GTi6-T
Posted 15th Oct 2009 at 20:23
Huh?
Surely the scooby bwarp sound is due to the flat four config?
Posted 15th Oct 2009 at 20:45
smegal
Post #35
These do a few 3" back boxes.
Ex SC-6
Now in a Megane R26
Posted 15th Oct 2009 at 21:19
bobdylan_55
Post #36
perfect Smile
309 GTi6-T
Posted 15th Oct 2009 at 21:25
ken
Post #37
looking good mate! nice work
Team Black Rallye Big grin
xbox live - Xx 7 kenny 7 xX
Posted 16th Oct 2009 at 19:28
Post #38
It would be a good idea to get a bead swaged into the ends of all your tubes to help the hoses stay on under pressure. Plain tube ends will be unlikely to hold your hoses in place for long.Wink
Posted 16th Oct 2009 at 20:28
aaron6
Post #39
Can he not just pop it to a welder and get them to run a raised weld round it and jubilee clip after that? may be cheaper than suaging.Smile
Posted 16th Oct 2009 at 23:40
rallyeash
Post #40
cjm_harris wrote:
Huh?
thats what alot people believe, the reason for there sound is due to the unequal length exhaust manifold, fit an aftermarket equal one and sound completely different
309 3dr K20 Type R
Posted 17th Oct 2009 at 01:11
pugheaven
Post #41
what he said, boxters have same flat four design and doesnt sound the same as a scoob.
Posted 11th Apr 2010 at 20:53
bobdylan_55
Post #42
i seriously cant see them pipes coming off under only 15psi boost. maybe if i up the boost, but they are pretty smug fit and the clamps seem damn hardcore.
309 GTi6-T
Posted 27th Oct 2009 at 03:14
bobdylan_55
Post #43
exhaust piping cut and welded, and new back box clamped on. Needs hangers welding on still, and also a tip connecting to it to make up the length. Also going to get started on downpipe at weekend.
309 GTi6-T
Posted 10th Nov 2009 at 19:02
alastairmoore
Post #44
pugheaven wrote:
what he said, boxters have same flat four and doesnt sound the same as a scoob.
Boxsters are flat 6!
00 306 GTi 6 48,000 miles
92 205 GTi 1.9 88,000 Miles
91 205 GTi 1.6 28,000 Miles
94 405 Le Mans 75,000 Miles
95 306 Roland Garros Cabrio
Posted 10th Nov 2009 at 19:08
Post #45
lol, Boxsters are flat 6.
Posted 10th Nov 2009 at 19:12
dommo
Post #46
rallyeash wrote:
cjm_harris wrote:
Huh?
Sounds completely different, ie, crap Razz
That's why most modern Group N/WRC impreza's sound just like any other rally car, and the original mcrae style WRC impreza's sound awesome (in my opinion anyway)
'99 306 Meridian TD with Bosch fuel pump - Cheap veg oil motoring
'99 Xantia Activa turbo - not cheap veg oil motoring Sad Goes around corners well though
Posted 10th Nov 2009 at 19:32
harvey01
Post #47
its the headers that make them sound like that ive had two subarus a 2005 sti that i spent a bit of cash on and put equal length headers on and then it sounds like any other turboed 2.0L . and a track wrx ra and i did the same to but striped it in a big way and it weighted 1100kg with half a tank of fuel.
harvey01
Posted 10th Nov 2009 at 22:37
bobdylan_55
Post #48
long time no update, but ive started cracking on again and this time hopefully will be the last stint until its fully done.
engine out again
Turbo oil feed didnt fit with standard fittings i got in the oil feed kit, so had my dad make me an adapter up at work.
Titanium shaft Wink lol
also brought a clutch and cable gear selector to suit the ml5t gearbox i have, unfortunately i got send the wrong size clutch release bearing, so if anybody has one that fits xu10j2te gearboxes gimme a shout Wink
cheers
309 GTi6-T
Posted 12th Mar 2010 at 03:40
bobdylan_55
Post #49
more updateyness
flywheel skimmed up like new by father Smile
new pedal box
then i stripped out the car to get to the pedals etc, and found this
after a good clean
doesnt look too bad, mostly surface rust, so get it cleaned up and sprayed jobs gooden Wink
engine is also basically finished, new ml5t gearbox bolted on with clutch etc and also purchased a thermostat adapter for the standard top hose and rad.
set up of the pedals for correct height positioning etc
resevoirs added for trail fitment Smile
309 GTi6-T
Posted 3rd Apr 2010 at 03:36
bobdylan_55
Post #50
pedal box has been fitted Smile
took a fair bit of work and welding which my bro helped with.
basically welded in a rail and a plate and sat the box on the plate which allowed it to sit a few inch further back meaning seat position can stay relatively normal Smile
pics
309 GTi6-T
Posted 5th Apr 2010 at 21:23
