displaying posts 26 to 50 of 113
Pages (5): 1 [2] 3 .. last
Author Subject: Wayne, don't look, shiny things.
Shaft size difference compared to a GAZ uprated rear damper....
LOL
Posted 2nd Sep 2009 at 19:19
Ah well, I've got them in pieces already again LOL
John, you want to try the flutter stack first in the dampers, or just the standard digressive tapered stack first?
Posted 2nd Sep 2009 at 20:52
puglover Banned!
explain to me again what a flutter valve is?
are you sure these will fit? are they standard mounting?
fast bump?
Posted 2nd Sep 2009 at 20:59
LOL
I'd hope so after 2 prototype sets Razz
They aren't standard mounting for yours 'cause you wanted the extra length - there's a bracket for the rear mount - but if you go back to standard length and sort the torsion bars out I can machine them to fit in the standard mount, same as everyone elses.
Flutter valve drops the damping force on small, sharp hits - expansion joints and the like, but it feels a bit different to normal damping, I'll stick a more conventional stack in first and if you want to try to other stack later on we can try a back-to-back test.
Posted 2nd Sep 2009 at 23:10
puglover Banned!
oh right erm id prefer to have them standard mounting then.
Ill sort my torsion bars out i didn't realise they were going to be so different just thought you would make a few tweeks.
Posted 3rd Sep 2009 at 00:56
Just a longer damper and a couple of steel brackets.
Just want a little lathe work to take them back to the normal length, not hard, take me a week or so to sort it out though.
Posted 3rd Sep 2009 at 01:29
clen666
dammit phill, why do you get these ready the week I find out my house could do with a rewire?! Sad
Team 'unintentional rat look'
Posted 3rd Sep 2009 at 04:34
Ah you're alright for a few weeks yet, John's been selected as forum crash dummy test pilot.
Posted 3rd Sep 2009 at 04:37
clen666
yes but what little money I have in the bank is going to be screaming at me to get spunked on shiney goodies, then I'll get wrong off the mrs
Posted 3rd Sep 2009 at 05:19
Post #35
Well, I might do a slightly cheaper set without the remotes if you're lucky, no adjusters on 'em though as you loose one of the blowoff valves from the canister.
Posted 3rd Sep 2009 at 05:24
clen666
Post #36
hmm, the bragging rights of the remotes may be worth the extra wedge tho LOL
Posted 3rd Sep 2009 at 05:47
Post #37
LOL
Posted 3rd Sep 2009 at 05:55
Post #38
nice and beefy if these are anything like the bike/motorcross ones you'll be having endless fun in the corners Hyper
Posted 4th Sep 2009 at 16:15
Post #39
Similar, but supersized LOL
Posted 4th Sep 2009 at 21:09
midlife
Post #40
WTFDunnoLaugh my ass off
Don't forget Jean Luc my name is on set No 2Wink
NinjaNinjaNinjaNinjaNinjaNinjaNinjaNinjaNinjaNinjaNinja
Cool
Team 330™Cool
Team "no front end or engine"
Posted 4th Sep 2009 at 23:41
midlife
Post #41
Oh by the way, anyone got any spare Kleenex, I've run outBlush
Cool
Team 330™Cool
Posted 4th Sep 2009 at 23:42
Post #42
LOL
Here's what the insides look like, told you I'd had them apart already Laugh my ass off
Posted 5th Sep 2009 at 01:20
Post #43
phillipm wrote:
LOL
Huh?
Posted 5th Sep 2009 at 01:46
Post #44
Hold your horses!
Step one, undo little lock screw:
Which lets you unscrew the wiper cap with a pin wrench:
Then you need to push the billet alloy main seal/shaft support down to expose the snap ring it holds against:
Prise that out with a tiny screwdriver and you can remove the shaft support and the 3 captive seals:
This is the bleed hole to purge air from the shock when rebuilding in case you were wondering.
Progressive rebound bumpstop, to prevent that horrible 'click' you often get with GAZ/Avo/Koni's at full extension:
And the main valving piston, complete with shims and high-speed circuit backstop so that you can go jumping over humpback bridges if you like.
The patina is the oil draining off in ripples, not muck Big grin
PTFE coated PEEK main piston band, stagger cut for less leakage, and main body circlip:
Main compression stack shims once the piston is taken apart:
Compression valving side of the piston:
Rebound side:
The original rebound shims stack:
My rebound stack:
Remote res. end cap - secured with a circlip the same as the main seal:
And the billet floating piston:
There a barrel adjuster and another set of valving behind that, but I was just playing with a slightly tweaked valve setup.
They're got to come apart again for a little machining, and a modified Penske piston fitting with a 2* dish on the face (Fox pistons only have 0.5*), so I might get some pictures of the barrel adjuster and the secondary base valving if I remember.
Posted 10th Sep 2009 at 02:35
Post #45
Love Splumf! Oh I'm sorry, I've just come! LOL
Posted 5th Sep 2009 at 02:07
Post #46
"Saw Phillip M's dampers and...Jizzed in my pants!"LOL
vts_tibi
Post #47
Clapping Laugh my ass off
now the question is: AST or FOX Crazy
(it was AST or KW back in time, but there are better options I think! Big grin )
VTS
best 60' : 2.272
Team Trackday™
Posted 5th Sep 2009 at 02:16
Post #48
And the new pistons:
Be back on Fox pistons eventually as they're gearing up to make me some bespoke billet ally ones atm, but the first few sets will probably be coming with these alloy Penske ones.
Posted 5th Sep 2009 at 02:20
Post #49
AST will do remote res if you ask nicely Wink I think Curtis will be putting the rear dampers back on Adam's 306 on tuesday
Posted 5th Sep 2009 at 02:26
vts_tibi
Post #50
Do you have a cutaway picture of a somewhat similar damper, so a dumb like me would understand what do those pistons do and how do they actually work?
VTS
best 60' : 2.272
Team Trackday™
Posted 5th Sep 2009 at 02:27
