displaying posts 51 to 75 of 113
Pages (5): first .. 2 [3] 4 .. last
Author Subject: Wayne, don't look, shiny things.
vts_tibi
Post #51
AST will do remote res if you ask nicely Wink I think Curtis will be putting the rear dampers back on Adam's 306 on tuesday
they even list it for the Xsara, but if I were that rich I wouldn't drive a Xsara... ain't? LOL
VTS
best 60' : 2.272
Team Trackday™
Posted 5th Sep 2009 at 02:28
Post #52
Yes
I'm not gonna advise either way 'cause I've been in a few cars with AST's and they are very nice Yes
Posted 5th Sep 2009 at 02:48
Post #53
I don't know how much they are, probably about the same price as some of these, they are black and orange.
never understood how the shim stack and valving works properly, it does look strikingly familiar though as I've got a Fox Air shock in Anodised black on my bike, 3 way adjustable and lockout :p
Posted 5th Sep 2009 at 03:13
Post #54
The discs deflect to allow fluid flow.
The shape, size and the top clamp on the stack as well as the thickness of each shim in the stack, the size and shape of the port, it's position on the piston, and the width of the valve seats, all contribute to the size and shape of the damping curve, along with many other factors.
Most of the money in more expensive shocks goes into external adjustablity and getting those adjusters as independent from one another as possible, as well as one way check valves in the bleeds, etc. (don't need those 'cause we're getting away without any bleed holes)
Posted 5th Sep 2009 at 03:31
Post #55
ahhh ko Thumbs up
and the reservoir gives higher oil capacity to reduce overheating which could lead to cavitation as well as having the pressurised section on top?
Posted 5th Sep 2009 at 03:33
Post #56
Yes, which also allows me to create some spring assitance pressure - without overheating the damper.
It also shifts the floating piston outside of the damper body which allows for more travel/shorter body for the same travel.
And in my case it holds some secondary valving in the form of a rotary barrel bleed valve and a digressive blow-off shim/ports for the adjuster.
Posted 5th Sep 2009 at 21:49
midlife
Post #57
Crazy
Team 330™Cool
Team "no front end or engine"
Posted 5th Sep 2009 at 05:11
Post #58
= ooh shiny bits
Posted 5th Sep 2009 at 05:14
dr-evil
Post #59
Good to know i wasn't the only one excited by these sexyful little beasties...now i have to find something to clean up my drool Big grin
Cad Monkey will work for chocolate biscuits....I'm not kidding
Posted 5th Sep 2009 at 05:32
Post #60
I'm excited I finally got there in the end, 's only took 9 months.... Black eye Blush
Posted 5th Sep 2009 at 05:34
midlife
Post #61
And the rest Jean LucLaugh my ass off
Cool
Team 330™Cool
Posted 5th Sep 2009 at 15:36
Post #62
Now to crack on with the rest of the work for the fronts....Mellow
Posted 5th Sep 2009 at 16:00
Post #63
Spring rate assistance, (graph in the bottom left corner), the preload is variable from the gas pressure, the assist rate they have to come back to me to change, but it's only a 5 minute job:
Posted 6th Sep 2009 at 16:02
clen666
Post #64
Blink
Team 'unintentional rat look'
Posted 6th Sep 2009 at 16:30
Post #65
24lb/inch extra rear spring rate, and 32lb of preload from the gas (ever noticed that putting Bilstiens on raises your car up a little, that's the preload from the gas pressure - the difference between the two lines).
What you'd get with a normal gas-pressurised monotube damper then (Bilsteins/AST/Proflex/etc, etc), would be a virtually flat line at 32lb of force - well, the force levels would differ depending upon the gas pressure and the shaft size, but it'd be flat anyway.
Not so interesting for those of you with uprated torsion bars, but for everyone else, this means you can have 25-35% more rear spring rate without spending
Posted 6th Sep 2009 at 18:33
Post #66
Hmmmmm verrrrry interesting!
Yeah should be getting the rears back on tuesday with a new ball joint. Will then finally be able to test things properly.
(Thats Adam B talking not Meirion btw)
Posted 7th Sep 2009 at 14:49
Post #67
Cool More shiny things!
Posted 6th Sep 2009 at 18:36
clen666
Post #68
that is interesting indeed!
these are looking very promising....now more pics of shiney things!!! Cool
Posted 6th Sep 2009 at 18:48
Post #69
Well, it'll probably take me another year to get the pennies and develop, but these'll be your matching shiny fronts...with some alterations to the mountings...
3 ways....Whistle
Posted 6th Sep 2009 at 19:14
clen666
Post #70
Shock
surely they aren't the
Posted 6th Sep 2009 at 21:35
Post #71
Those ones are rather more expensive, but if you don't spec. the adjuster tubes they'll be about the same price as the rears Smile
Posted 7th Sep 2009 at 02:24
clen666
Post #72
so would they still be pretty similar, remote res. etc., just without adjustability?
I think I'd just end up messing up the settings anyway
Posted 7th Sep 2009 at 03:15
Post #73
Yes, same bodies as those.
Posted 7th Sep 2009 at 03:16
clen666
Post #74
clen666 has attached the following image:
Posted 7th Sep 2009 at 03:41
jimmy_boy
Post #75
puglover wrote:
Shock are there any dust boots? cannot harm the precious
Laugh (In a smeagol fashion)
GTI-6 & Rallye
Rallye gets sideways in the wet at Snetterton Ninja
Posted 7th Sep 2009 at 03:44
