displaying posts 301 to 325 of 394
Pages (16): first .. 12 [13] 14 .. last
Author Subject: AST Sportline I. coilovers!!!!! please read!
vts_tibi
Post #301
yep... and mine are the proper ones Big grin
VTS
best 60' : 2.272
Team Trackday™
Posted 11th Dec 2009 at 00:09
Post #302
PM sent
Posted 11th Dec 2009 at 00:13
byfx
Post #303
so how about pictures?
Posted 11th Dec 2009 at 03:48
Post #304
Give him time - its taken him a month to fit the buggers Razz
Posted 11th Dec 2009 at 04:03
vts_tibi
Post #305
Dry
LOL I made pics, but you can't even make out which one is the car and which one is a shock Whistle
VTS
best 60' : 2.272
Team Trackday™
Posted 11th Dec 2009 at 12:44
byfx
Post #306
have you checked the camera's manual?LOL
Posted 12th Dec 2009 at 02:28
vts_tibi
Post #307
yep and it's a cracking one
I'll have to replace the muppet operating it LOL
VTS
best 60' : 2.272
Team Trackday™
Posted 12th Dec 2009 at 02:47
Post #308
The car's that big metal thing with wheels on.
Posted 12th Dec 2009 at 02:53
vts_tibi
Post #309
Shock
VTS
best 60' : 2.272
Team Trackday™
Posted 12th Dec 2009 at 22:06
r*byb
Post #310
How much are these ? I had ASTs on my 182 and they were pretty good
Team Low Compression
Posted 15th Dec 2009 at 21:43
Post #311
its in the thread already Smile
ast suspension wrote:
here are the prices as promised,
sportline 1 kit
Posted 15th Dec 2009 at 22:11
mabgti
NV motors
Post #312
fook'n pricey that! and im sure the leve of adjustment will be aslong as the bodies dont rust!
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 20th Dec 2009 at 20:25
Post #313
They aren't cheap shit like Gaz matey...
Posted 20th Dec 2009 at 21:12
vts_tibi
Post #314
I would say they are better than KW V.2
Just look at what KW gives!
Same shocks for the 1020kg 1.4 75hp Xsara Coupe as the 1189kg 167hp VTS!!!?
And those are only the prototypes on Adam's car. The set I received is completely different.
Unfortunately no good pictures from them, but once I have the opportunity I'll show you some.
VTS
best 60' : 2.272
Team Trackday™
Posted 21st Dec 2009 at 00:01
Post #315
Stainless bodies have their own drawbacks tbh, why is why none of the race manufacturers use them.
Posted 21st Dec 2009 at 00:05
vts_tibi
Post #316
what is the reason Sir Oracle? LOL
VTS
best 60' : 2.272
Team Trackday™
Posted 21st Dec 2009 at 00:12
Post #317
which ones use a stainless body? afaik these are black Anodised alloy with orange powdercoated springs and orange anodised knobs.
have worked on Adam's car recently and they're standing up to British winter road conditions very well, has done several thousand miles since they were fitted.
Posted 21st Dec 2009 at 00:18
Post #318
The KW's, and:
1. Heat retention - they don't transmit the heat from the oil very well so the damper runs hotter and looses some damping effect when pushed hard.
2. Galvanic corrosion - stainless steel into a larger aluminium structure are fine - small aluminium fittings (spring pans) onto large stainless bodies are not connected by a large surface area (very fine thread) so the spring pans are just as likely to stick as a normal zinc-plated steel body is anyway.
But they are shiny for a while LOL
To be honest, so long as you wax a steel damper occasionally (which is normally part of your warranty if you read it), they should be fine for years.
Posted 21st Dec 2009 at 00:20
vts_tibi
Post #319
ahhh... so really suited for those who like to look at their cars and don't use them properly LOL
I guess non-of the ASTs use stainless steel body.
VTS
best 60' : 2.272
Team Trackday™
Posted 21st Dec 2009 at 00:21
Post #320
It's not a huge difference, but it muddies the waters when deciding to choose a stainless bodied damper or a steel one.
Posted 21st Dec 2009 at 00:22
vts_tibi
Post #321
what product would you suggest for the shock bodies Phil?
VTS
best 60' : 2.272
Team Trackday™
Post #322
For the front struts? Coated steel or titanium to keep the flex to a minimum, given they take side loads - for the rear, ideally alloy bodies that are internal coated with a multi-element or diamond-LC coating on the inside, but that's pricey, hard-anodised ally can last a while but can start to wear a little faster if the oil isn't changed when it starts to go slightly acidic.
Posted 21st Dec 2009 at 00:27
vts_tibi
Post #323
wax for the bodies I mean LOL
VTS
best 60' : 2.272
Team Trackday™
Post #324
LOL
Autobalm is quite good and fairly cheap.
Posted 21st Dec 2009 at 00:29
Post #325
What about Nivea Hand Cream - got some of that kicking about? Think CUJ left it behind the other day. Unsure
I have no idea what mine are made of, but they actually aren't much different from yours Tibi. The rear adjustment and a tad more rear damping are the only things I can think of Razz
Anyway I don't care - they still work very well...
Posted 21st Dec 2009 at 02:17
