displaying posts 101 to 125 of 195
Pages (8): first .. 4 [5] 6 .. last
Author Subject: £50 Prize! *updated*
knightrider684
Post #101
Oh and that sport spring is there to assist the pressing of the pedal and removing it usually only fixes the stuck down pedal problem.
Posted 21st Feb 2009 at 20:50
willygti
Post #102
Thanks for the reply Smile
I was inclined to think it was something cable related as the biting point would drop on the clutch when the car was in its spazz out mode.. but had a look at it all today against another fully functional 306 gti and it seems fine. We even drove each others cars and came to the conclusion its my linkages. The longer linkage on mine is adjustable, and i adjusted it to make it shorter and its defo reduced the problem.
Team Ducati 748
2003 Subaru Impreza STi
Posted 21st Feb 2009 at 20:51
knightrider684
Post #103
Oh ok, Its just I can't see how linkages could affect your biting point. I know if it were mine Id lose the self adjusting cable anyway as they arent very good, Anyhow best of luck!
Posted 21st Feb 2009 at 20:59
willygti
Post #104
Yeh that was my thoughts originally until today.
What manually adjustable clutch cable can be used on the 306??
Team Ducati 748
Posted 21st Feb 2009 at 21:00
knightrider684
Post #105
the early ones had manual cables so if you were to take yours off, GSF should match one up for you. Out of interst what kind of mpg are you getting? I only came on here because theres a Rallye I know of which Im thinking of getting soon as I know what fun they used to be when I worked with them
Posted 21st Feb 2009 at 21:18
willygti
Post #106
Are you sure, i'm pretty certain all gti cables are self adjusting Wink
27mpg is about avg
Team Ducati 748
Posted 21st Feb 2009 at 21:21
knightrider684
Post #107
It doesnt have to be a Gti one m8, the Turbo Diesels used a similar set up. Thanks for that.
Posted 21st Feb 2009 at 21:26
willygti
Post #108
I thought the td's used exactly the same (self adjusting) cable??
Team Ducati 748
Posted 21st Feb 2009 at 21:34
davedgti6
Post #109
My old 309 had a manual adjuster on the clutch cable and from memory was a similar set up except for the adjuster on the end of the cable, (effectively lengthed and shortend the cable)
Dont know if it could fit a 6 but maybe you could compare them side to side at gsf or somewere Dunno
Posted 22nd Feb 2009 at 00:27
willygti
Post #110
I'll bare it in mind mate Thumbs up
Team Ducati 748
Posted 22nd Feb 2009 at 00:28
knightrider684
Post #111
sorry I meant to say Ive never actually swapped a gti cable, however when faults like this came along on the DTurbos, we'd replace the cable with a manual one from the earlier 306's (parts dept. sorted this bit out lol) but am not sure which model as I say, if the guys at GSF are helpful they should just match one up
Posted 22nd Feb 2009 at 00:34
blu
Post #112
You can buy a Universal Cable kit... They dont have the adjuster on the cable.
But IIRC there poo.
Posted 22nd Feb 2009 at 16:46
willygti
Post #113
I'm waiting for my shiney new gear linkages to arrive from miles before i spend anymore.. if there's no change after they're fitted then i'm going to go down the manually adjusting cable route Thumbs up
Team Ducati 748
Posted 22nd Feb 2009 at 22:15
willygti
Post #114
OK, so replaced all linkages with the standard setup and its still f*cked - yet more money thrown at it with no solution Doh
Next move is to look at the cable - i'm going to try spacing it out and see if that makes a difference.
Team Ducati 748
Posted 28th Feb 2009 at 18:08
smegal
Post #115
I'd check the pedal and remove the spring on the pedal.
Ex SC-6
Now in a Megane R26
Posted 28th Feb 2009 at 19:19
iplay
Post #116
did you spray some wd40 under the clutch lever arm?
Posted 28th Feb 2009 at 20:05
willygti
Post #117
Yes LOL
the clutch arm is moving as it should Yes
Team Ducati 748
Posted 28th Feb 2009 at 20:09
willygti
Post #118
OK, replaced the clutch cable with a genuine pug one as soon as got back from my ski. Still no luck Wink
Removed the spring from the peddle - again no change - just made the peddle feel really slack/gay.
Anyone Dunno
Team Ducati 748
Posted 12th Mar 2009 at 23:13
Post #119
warped flywheel!!???
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 12th Mar 2009 at 23:56
Post #120
and
willygti
Post #121
Ash you may well have just suggested wampy hoses Doh
Team Ducati 748
Posted 12th Mar 2009 at 23:58
willygti
Post #122
If it were a warped f/w surely the problem would be occuring non stop??
Team Ducati 748
Posted 13th Mar 2009 at 00:01
Post #123
you would of thought so mate yes.
but it is french
Posted 13th Mar 2009 at 02:58
hman205
Post #124
Mine is also doing this exactly as you have described My only guess so far is checking that the engine and gearbox is not twisting in the shell.
is your top engine mount to the chassis leg ok not cracked or have any play in it?
Lower mount both the large Round mount and the on on the other end of the fork?
Gearbox mount centered properly and not got play?
does you car have a Slight exhaust blow by any chance?
Another Broken one
Posted 13th Mar 2009 at 04:15
willygti
Post #125
Umm, the top engine mount has cracked / been re-welded by former owner. I've fitted group n mounts all round and the engine is seriously solid - zero movement.
Manifold to downpipe isn't blowing.
What are your exact symptoms then matey, reasurring to know someone else is in the same boat as me (not meaning to sound selfish)?
Team Ducati 748
Posted 13th Mar 2009 at 04:20
