displaying posts 76 to 100 of 195
Pages (8): first .. 3 [4] 5 .. last
Author Subject: £50 Prize! *updated*
willygti
Post #76
Sporty spring? Crazy
Sounds hopeful mate, could you be a little more specific??
Team Ducati 748
2003 Subaru Impreza STi
Posted 20th Feb 2009 at 20:21
gingec
Post #77
Look 8 post down from the top in the transmission topic, shows the spring and where it is. My knowledge of these cars is small in comparison to most but it does sound like the cable is not endaging/disengaging fully.
Posted 20th Feb 2009 at 20:28
smegal
Post #78
The spring on the clutch pedal. That will give you a better 'feel' and can't hurt. Be careful when taking it off though it can fly off like a rocket.
Ex SC-6
Now in a Megane R26
Posted 20th Feb 2009 at 20:38
willygti
Post #79
Whats the spring there for though? To pull the pedal back up??
Team Ducati 748
Posted 20th Feb 2009 at 20:43
gingec
Post #80
The more I come to think of it (remember my situation) it got a lot worse as the engine got warmer, especially stop start traffic in town.
Don't worry about removing it, mines been off for over a year with no problems
Posted 20th Feb 2009 at 20:45
willygti
Post #81
Ok, is it simply pull/lever off or do you have to unscrew shit first?
Team Ducati 748
Posted 20th Feb 2009 at 20:46
gingec
Post #82
Carl's lad removed mine in about 20 seconds, I think he just used a pair of long pliers, just a couple of cir clips (or what ever they are called).
No need to remove any body work etc.
Hang on, it's still in my glove box, I'll go take a look.
Ball socket at one end (just pops off) and a clip at the other. Would take a pic for you but I have to be at work in an hour. Good luck.
Posted 20th Feb 2009 at 20:53
willygti
Post #83
Thanks mate, will give it a go when i get home Big grin
Team Ducati 748
Posted 20th Feb 2009 at 21:07
iplay
Post #84
take some wd40 and spray it under the clutch lever arm. the wd40 is just a temp fix to see if the arm is dragging.
i would buy a genuine peugeot clutch cable and grease up the gearlinkages.
my gear lever nylon ball was cracked in two when i replaced it. this can cause irregular gear selection.
Posted 20th Feb 2009 at 21:18
willygti
Post #85
I'm near certain this is not a linkage related problem Niel, all linkages look relatively new and i greased them all up when fitting the new box.
Clutch cable/peddle/arm are my main areas of concern now.
Team Ducati 748
Posted 20th Feb 2009 at 21:35
smegal
Post #86
The spring is to push the pedal down. mine feels so much better without. It can be refitted if you keep all the bits.
Ex SC-6
Now in a Megane R26
Posted 20th Feb 2009 at 23:21
iplay
Post #87
I am not talking about the linkages but the gear lever arm 'thingy' ... My hand is lying flat on the side of the battery case. 5cm above my finger under the black pipe is the pivot point. get some wd40 under that and take it for a spin. if it works then get some grease under the arm.
Posted 21st Feb 2009 at 00:31
willygti
Post #88
The clutch arm?
Team Ducati 748
iplay
Post #89
willygti wrote:
The clutch arm?
hmm yes ... bit wrecked atm ... so wrecked i was going to make a Welly type video Cheers
i think 90% of stiff clutches are down to this arm not being lubricated. I guess the real issue is the clutch lever arm bearing failiure or where the arm goes through the gearbox casing.
Posted 21st Feb 2009 at 00:35
willygti
Post #90
Laugh my ass off
need
Team Ducati 748
Posted 21st Feb 2009 at 00:36
iplay
Post #91
willygti wrote:
Laugh my ass off
need
Posted 21st Feb 2009 at 00:45
willygti
Post #92
You have to have the box off to change the bushes.. think they're mentioned on Welly's clutch/gearbox FAQ Thumbs up
Team Ducati 748
Posted 21st Feb 2009 at 01:13
sandy
Post #93
I would be keen to try a manual adjustment cable, but I'm not sure if there's one that fits straight on. Other than that, the symptoms sound like a loose/broken spring in the plate, but since you've changed the plate, it would seem unlikely.
Posted 21st Feb 2009 at 01:19
willygti
Post #94
Thanks sandy. The springs within the clutch plate are all as they should be, so i'll defo focus on the cable Thumbs up
Team Ducati 748
Posted 21st Feb 2009 at 01:44
willygti
Post #95
OK, so just been out with martin (davidmartin) and we've narrowed it down to gear linkages - makes sense as they're the only thing ive not replaced on the car since owning.
We adjusted the longest linkage (made it shorter) and it seems to have helped quite a bit. So i'm going to order a new set of linkages and go from there Big grin
Massive thanks to marty for his time - top guy! Thumbs up
Team Ducati 748
Posted 21st Feb 2009 at 19:24
davidmartin
Post #96
what was it like going back will?.
pet hate, the cat
Posted 21st Feb 2009 at 20:29
willygti
Post #97
A lot better.. still no where near as it should be though Wink
I'm on the case of buying a whole new gear linkage setup - going to go for miles' uprated ones Big grin
Team Ducati 748
Posted 21st Feb 2009 at 20:31
davidmartin
Post #98
Good,that burger you bought me was awfull by the way.LOL hope it sorts it for you.
pet hate, the cat
Posted 21st Feb 2009 at 20:36
willygti
Post #99
LOL at the burger!
Thanks again mate
Team Ducati 748
Posted 21st Feb 2009 at 20:42
knightrider684
Post #100
Hello m8, Ive registered specifically to put my reply to this thread, I used to work for a Peugeot main dealer and I would suggest your soloution is in your symptoms. The fact that this problem is here only occasionally and then rights itself says it can only be the self adjuster in the clutch cable as any other problem e.g.a bent arm or pedal box would be there all the time. Match a manually adjusting one up with GSF and I'd put
Posted 21st Feb 2009 at 20:44
