displaying posts 51 to 75 of 195
Pages (8): first .. 2 [3] 4 .. last
Author Subject: £50 Prize! *updated*
pinkfloyd
Post #51
I would change to a genuine clutch cable too, I had a load of problems with a Euro parts one.
Liverpool Motor Club Sprint champion 2017
Longton & District Motor Club Sprint champion 2017
Liverpool Motor Club Sprint champion 2016
Liverpool Motor Club Sprint champion 2015
Lancashire & Cheshire Speed Championship
Winner 2014
2nd 2013
Winner 2012
2nd 2011
Winner 2010
Winner 2009
Winner 2008
Winner 2007
2nd 2006.
Posted 20th Feb 2009 at 03:15
Post #52
midlife wrote:
puglover wrote:
quickshits is my bet Yes
or a bent folk or arm.
Mine too, does that mean we get
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 20th Feb 2009 at 03:18
willygti
Post #53
In regards to the cable, i'm sure most people on here use GSF ones right?
I've used three different cables and had exactly the same troubles every time - i can't believe no one else buying them has had the same problems and i get three duff ones in a row? Crazy
Team Ducati 748
2003 Subaru Impreza STi
Posted 20th Feb 2009 at 03:38
willygti
Post #54
puglover wrote:
or a bent folk or arm. Or something to do with clutch cable too tight.
In regards to the fork arm, it looked straight as you like and it would also seem a bit unlikely both my old fork arm and bigbadbowens fork arm from his box are bent?
but yes the clutch cable is where im focussing my attention - as i put a spacer on last time (cut a section of nut out and added it on the end of the cable) and it made a slight difference in helping reduce the frequency of the problem.
Team Ducati 748
Posted 20th Feb 2009 at 03:42
Post #55
i had a feeing theres somthing with the end of your cable hence the photo request.
Posted 20th Feb 2009 at 04:07
willygti
Post #56
I did try getting a photo, however its obviously too dark.. so this weekend i'll get back under and over the car to get some pics of where my cable is routed. But as far as the connection goes to the gearbox - thats all as it should be Thumbs up
Team Ducati 748
Posted 20th Feb 2009 at 04:09
willygti
Post #57
I've got a few things to look at at the weekend. If it is the cable then we're looking so far at a 3 way split of the 50 quid Hmm
Team Ducati 748
Posted 20th Feb 2009 at 05:09
Post #58
Only ever used a proper pug clutch ????
Posted 20th Feb 2009 at 05:12
willygti
Post #59
Clutch or cable, or both mate?
I have a valeo clutch from GSF, and the cable (don't know the make) is also from GSF
Team Ducati 748
Posted 20th Feb 2009 at 05:15
mugen_power
Post #60
Shit, did it not fix the problem? Sad
It is quite annoying, I have lost count of how many times we've been stuck at a junction trying to get your car in gear LOL
rikky wrote:
there are no pictures of breasts or meatwallets anywhere so it is bringing nothing to the table, so to speak
Posted 20th Feb 2009 at 05:23
willygti
Post #61
Nope, exactly the same!
Practically 4 days of my life covered in grease, over
Team Ducati 748
Posted 20th Feb 2009 at 05:25
smegal
Post #62
I'd look at the pedal inside the car to see if it is moving in ways that it shouldn't.
Then check that your linkages are all ok and not slack.
Ex SC-6
Now in a Megane R26
Posted 20th Feb 2009 at 05:35
blu
Post #63
Keep Lookin. More than likely be something simple.
But if its what i said.......Hmmmm
Posted 20th Feb 2009 at 05:44
robthe6
Post #64
is the gear shift throw rod loose or ball worn. not hard to check, remove centre console and gater and see if there is any slack when pulling up on the shaft or pushing down on it. could be worn an slipping in and out, keeping u out of gears. as for the cable that could something diffrent. also have u checked if the chassis any bent since the prang?
1997 ph1 bianca GTI6 - The looker
1996 ph1 Sigma GTI6 - Dead Sad
1999 Red Rallye - The Daily
2005 Nissan Navara D40 - Family car
1968 Mustang Coupe - The dirty little secret
Put ya foot down, put ya foot down we'll loose em easy!
mugen_power
Post #65
Posted 20th Feb 2009 at 06:12
willygti
Post #66
Interesting about the centre console.. not thought of that. But as discussed i'm mainly focussed now on the clutch cable as you can feel the clutch drag when it starts Wink
had the whole engine out over the summer and the legs were fine - it was obviously only a light hit as the bonnet is only slighlty bent
Team Ducati 748
Posted 20th Feb 2009 at 06:15
willygti
Post #67
Team Ducati 748
Posted 20th Feb 2009 at 06:13
mugen_power
Post #68
Good job I didn't come round then LOL
Posted 20th Feb 2009 at 06:17
captaink
Post #69
Apologees, but I haven't read the entire page through.
My 205 GTi6 conversion had problems putting it into gear and you had to sometimes force it into some of the gears. The biting point was also low down to the floor. Got Sandy to adjust the adjuster for the biting point of the clutch to move it "higher up" and now its much better (well, except I keep stalling it or revving it like a chav as I'm not used to the new bite point LOL)
When I got home last night, my G/F demanded that I take her somewhere expensive - so, I took her to a petrol station.
1993 L reg 205 with GTi6 engine and GTi6 brakes
1995 M reg FTO GPX manual
Posted 20th Feb 2009 at 18:27
willygti
Post #70
Does yours use the 6 speed box mate?
Any ideas how he did that? Put a spacer on somewhere to 'stretch' the cable a bit more?
Team Ducati 748
Posted 20th Feb 2009 at 18:32
captaink
Post #71
Nah, standard 205 1.9 GTi BE3 box on it. There is a very tiny "adjuster" thing on the gearbox somewhere I believe. IIRC I think it needs a really tiny allen key to turn it. I didn't see exactly where it was, but it was in the gearbox area between the throttle body and the thermostat area and easily reachable from the top.
If all elese fails, PM Sandy and see what he says. Smile
Posted 20th Feb 2009 at 19:01
willygti
Post #72
Yeh the 6 box doesn't have this (i don't think LOL)
Just uses a self adjusting clutch cable - i'm going to try and space it out to see if it helps Geek
Whats sandy's username, is it just 'sandy'?
Team Ducati 748
Posted 20th Feb 2009 at 19:05
captaink
Post #73
Yeah, either "sandy" or "sandybrown" or "sandy205". I forget which as I know him on a few forums.
Posted 20th Feb 2009 at 19:11
willygti
Post #74
Cool, just sent him a pm Thumbs up
Team Ducati 748
Posted 20th Feb 2009 at 19:12
gingec
Post #75
Long shot and probably miles off but have you removed the 'sporty' spring from the top of the clutch peddle? After my clutch change this caused a load of problems that were immediately fixed with the removal of the spring. i.e. hard to get into gear, slipping clutch, moving biting point and a sticking peddle.
Posted 20th Feb 2009 at 20:11
