displaying posts 1 to 25 of 195
Pages (8): [1] 2 3 .. last
Author Subject: £50 Prize! *updated*
willygti
[b]First things first - i will honestly give
Team Ducati 748
2003 Subaru Impreza STi
Posted 13th Mar 2009 at 04:30
What condition are the engine/gearbox mounts in?
And dop the quickshift linkages off to help with the diagnosis - quickshift linkages + knackered engine mounts = exact symptom you're describing.
The variable clutch pedal doesn't fit with that though, were any bits carried over from the old gearbox whilst refitting?
What gearbox oil have you used?
Posted 19th Feb 2009 at 23:58
birk
Have the gearbox shaft bearing things been replaced or greased up
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 19th Feb 2009 at 23:59
drew o
thrust bearing or the fork arm that holds it on all ok?
306 GTi-6™ In Moonstone FTWBig grin
Team Speedline Turini
PS3-Drew_o
Posted 20th Feb 2009 at 00:00
willygti
Phil: Group N gearbox mount put in by myself, make of linkages unkown as fitted by previous owner. Peugeot 75/80 oil used. And only the clutch arm and pin were used from the old box.
Birk: Yes fork bearings replaced with new and greased up.
Drew: Thrust bearing replaced with clutch change last time round.
Team Ducati 748
Posted 20th Feb 2009 at 00:05
Gear box was sweet and only thing that it needed was the clutch cable arm - I'd try some std linkage and check the ball joint thingy on the sub frame ?
cosmic spanner
Moral objector
I swear that read
Democracy is two wolves and a lamb voting on what to have for lunch..
..Liberty is a well-armed lamb contesting the vote.
Project é - my 306 project thread.
Posted 20th Feb 2009 at 00:06
remove the quickshift even if its just to eliminate it from the probs list
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
willygti
Yeh i'm in no doubt the box you sold me is sweet matey Thumbs up
By balljoint do you mean where the main gear linkage pivot bolt bolts into?
Team Ducati 748
willygti
cosmic spanner wrote:
I swear that read
Team Ducati 748
Posted 20th Feb 2009 at 00:07
Eliminate rods from the prob I reckon
willygti
How can dodgey linkages/rods cause the clutch biting point to drop? Crazy
The peddle even physically drops a slight bit when this all starts happening.
Team Ducati 748
Posted 20th Feb 2009 at 00:11
Just thinking that myself but hey its french dude ???
Posted 20th Feb 2009 at 00:12
willygti
True, but this just takes the p*ss. Never heard anyone else with this problem and searched this forum high and low for similar problems Angry
Team Ducati 748
Posted 20th Feb 2009 at 00:14
fletch
Track Head
Non gti clutch or defective or damaged flywheel imo
i didnt say it could, i said remove it to eliminate it from the probs, because the biting point isnt the only thing you mentiomned.
why ask for peoples opinions and then question them trying to make them look wrong, wtf all that about????
Posted 20th Feb 2009 at 00:17
willygti
andy+katie wrote:
i didnt say it could, i said remove it to eliminate any probs, because the biting point isnt the only thing you mentiomned.
Why all the aggression.. i only asked a quesiton - i need to be sure what the problem is before i start chucking even more money at the problem Wink
And fletch how would the flywheel cause this, Ash mentioned it earlier and is a new one on my list of possible problems Hmm
Here's my pics of the clutch i fitted up against the clutch removed. Can someone check the part numbers for me (ordered from GSF):
Team Ducati 748
Posted 20th Feb 2009 at 00:20
davidmartin
You may have more than one problem causing different faults will.So a process of elimanation seems to be your only way forward.
pet hate, the cat
Posted 20th Feb 2009 at 00:18
take us a picture of the area on the clutch arm where your cable fits.
willygti
Doing it now...
Team Ducati 748
Posted 20th Feb 2009 at 00:22
lol isnt it funny how the wordings on the internet can be misleading into what people mean/are getting at!!!!
Posted 20th Feb 2009 at 00:25
midlife
The car is haunted, get an exorcistDevil
The
Team 330™Cool
Team "no front end or engine"
blu
Has the Release bearing been put on right?
Or something might be jammin' the cable up..
... Process of Elimination ...
Posted 20th Feb 2009 at 00:29
willygti
By the release bearing do you mean the one that sits on the friction plate?
This?
Team Ducati 748
Posted 20th Feb 2009 at 00:40
blu
Release bearing/Thrust bearing = same thing
Posted 20th Feb 2009 at 00:41
