Post #1071
chris with a pug wrote:You should of got Rob to make your dash bar at least then you know it would of fit, and I have some gusset plate here if you want it
I had a few reasons for not getting Rob to make it, he needed a sample for the bend radius and he only sets up his bender when he has enough work to make it worth it. I can make the CC one fit easily enough myself. As for the gusset plates I got the triangular ones that strengthen up the door x-bars.
Right, progress report.
Made a little headway tonight on the sump baffle kit, space is really tight so I've had to revise my initial plan slightly (Make it up as I go along
) This involved cutting the sides off the box and welding on some new ones that fitted the shape of the sump base a little better, this will allow me much more room for a nice free flowing trap door arrangement to bring oil to the pickup on righthanders. I have a plan for how to get it to work for lefthanders but you will have to wait and see that. Anyway, here are a few shots of my contraption.
The oil pump is screwed to the wooden baton to get it to sit at the right height more or less for the mock-up.
There is a protrusion on the oil pump body just in the wrong place that fouled the box, so I had to let in a corner piece.
Fitted much better after...
There is also a dogleg section that drops away on the sump floor, this created quite a gap in the corner of the box which could allow too much oil to escape away from the pickup under cornering, so I covered it up with the addition of this plate. It has a drain hole right in the corner so it won't hold any cruddy oil when the time comes to change it.
Still have to make dividers and gates etc. but it's coming along, what with that and this Accusump I think oil issues should be the least of my worries. Paranoid much? I think so!
Lastly, here are the new rods, sure you've all seen them before but I think they are worth a second, third and fourth look
They must be about 2/3 the weight of a standard rod and the finish is outstanding
