displaying posts 1026 to 1050 of 1309
Pages (53): first .. 41 [42] 43 .. last
Author Subject: Daveyboy's Rallye Race car
Post #1026
Thanks Karl Razz
Posted 26th Jun 2011 at 19:22
Post #1027
Full seam welding gives bugger all extra over stitch welding tbh (full brazed seams are nice if they fit well enough though), for the extra time and weight it's better to stitch and avoid as much heat/distortion in the chassis.
And if you are forest rallying and crack a weld from flex, then it stops at the end of the stitch, rather keep creeping down the weld.
But, if you do as Jim has and move around to keep the localised heat down, it'll be fine.
Posted 27th Jun 2011 at 03:48
Post #1028
The other thing is I want to stop water getting into all the joints as now it's welded all the zinc coating is gone from the seams I've welded so if water gets into any open seams the rust will have a field day Smile
Posted 27th Jun 2011 at 19:42
Post #1029
Here we go, more stuff for the pile...
And these are the louvres, I've not done the passenger side one yet but it will be the same...
Sausage fingers enter stage left...
Fire up this and...
Back together so I can f*ck off home for a beer...
Posted 27th Jun 2011 at 23:00
Post #1030
i like that grill idea
Posted 28th Jun 2011 at 01:18
Post #1031
I'f I end up in a forest it'll only be because I have seriously misjudged a braking point. In that case a cracked chassis will probabaly be the least of my worries! LOL
Posted 28th Jun 2011 at 16:36
Post #1032
Had a nice parcel arrive from Torques today...
Posted 30th Jun 2011 at 01:57
Post #1033
"What, put shiny car parts on the floor Shock Get me a leather cushion to sit them on" Laugh
Posted 30th Jun 2011 at 02:06
Post #1034
Nothing but the best for my 'Pugsley', spoilt b*tch! Dry LOL
Posted 30th Jun 2011 at 02:09
Post #1035
Meanwhile, friends and family members are being made to sit on the floor Yes
Post #1036
F*ck em! There is a strict pecking order in my house, and new goodies must be lovingly fondled, salivated over, photographed and then put back in their boxes. Then, and only then is the furniture made available for the use of others LOL
Posted 30th Jun 2011 at 02:13
rallyeash
Post #1037
nice collection! thats a few pennys worth
309 3dr K20 Type R
Posted 30th Jun 2011 at 03:04
Post #1038
Certainly was, I'm just glad I got given the advice to use Torques instead of Goodridge or Aeroquip. That has saved a fortune, and as all of it will be hidden in a closed box (regulations stipulate all fuel system components to be enclosed) it does'nt matter that the finish is'nt quite as good as the other two more expensive brands. Cool
Posted 30th Jun 2011 at 03:16
Post #1039
Should hopefully have my new rods in the next week or so, so I can then get started on the engine build, I'm dying to hear this thing run.
Posted 30th Jun 2011 at 03:27
rallyeash
Post #1040
yeah i got a few bits off torques, will use them again in the future also. so you planning on finishing it and get some testing done for a good season next year then?
309 3dr K20 Type R
Posted 30th Jun 2011 at 03:52
Post #1041
That was the plan but I've pretty much run out of funding now as the contract I was working on ended early, this has left me a little way short of what I needed to get it finished. I can't afford to compete a full season anyway so I'll get it done when it's done and just pick up the odd round of DMN or Tin Tops here and there Smile
Posted 30th Jun 2011 at 04:07
clen666
Post #1042
You running two pumps just incase one fails?
Team 'unintentional rat look'
Posted 30th Jun 2011 at 04:16
Post #1043
Yeah, I dare'nt risk running lean at 12.5-1 CR, and as I heard that the Walbro pumps are'nt that special when it comes to reliability I thought I'd get two. The only reason I went for Walbro at all is because I had been donated one already by a friend who had an unused one for his kit car, and as money was tight I figured get another one the same and I should be ok. I'll wire them up on separate switches so I can run one then the other to listen if they are still running. I also have the option to show fuel pressure with a warning if it drops below a presetable threshold on the Stack digi-dash I have. What with that, the AFR guage and my ears I should have advance warning of any fuelling problems.
Posted 30th Jun 2011 at 04:36
clen666
Post #1044
Sounds sensible!
When you mentioned the fuel lines are going to be enclosed, what are you going to do for this?
The msa blue book only states that lines are protected and I believe that braided lines are classed as 'protected', but I could be wrong?
Posted 30th Jun 2011 at 05:02
Post #1045
clen666 wrote:
Sounds sensible!
The braiding counts as metal enclosed or protected, but weirdly the pumps, filters and swirl pot need to be in a box, bit gutted really as there is £600 worth of cool bits that nobody will ever see once done Roll eyes
Posted 30th Jun 2011 at 05:10
clen666
Post #1046
Ah I see.
Yes that is, indeed, a bummer!
Do you know where that is stated? Not that I don't believe you, I'm just curious Razz
Posted 30th Jun 2011 at 05:17
Post #1047
clen666 wrote:
Ah I see.
Actually I don't but everyone with a car in DMN that I have spoken to all told me and theirs are all boxed in. Maybe I need to dig out the blue book or phone the MSA before I do any potentially uneccessary work?
Posted 30th Jun 2011 at 05:20
Post #1048
Yep, weird ain't it?
You can run the hose through the car but not the pump/filters or tank..
Posted 30th Jun 2011 at 05:32
clen666
Post #1049
I would check, you can view the book on the msa website if you can't find yours.
I had a brief look and couldn't find anything in the fuel systems part, unless it's stated somewhere else?
Edit: it's mentioned under the chassis/body section, 'driver compartment isolated from.....fuel system components'
Oh well
Posted 30th Jun 2011 at 05:55
Post #1050
It's fair enough I suppose, if a union fails i don't really want 5 bar of fuel gushing out at me!
Posted 30th Jun 2011 at 05:49
