displaying posts 176 to 200 of 503
Pages (21): first .. 7 [8] 9 .. last
Author Subject: Hybrid & 30mm ARB's
Post #176
I cant wait! Hyper
Posted 29th Apr 2009 at 13:41
simonjames
Post #177
Ash i'm not desparate for mine so if needed i can wait
MY EBAY ITEMS
07943066306
Posted 29th Apr 2009 at 18:33
acos205
Post #178
1. smighall - Hybrid - Cash
Posted 3rd May 2009 at 05:33
ash
Six Addict
Post #179
Posted 7th May 2009 at 00:28
condieboy
Post #180
I pity the DHL van driver LOL
Ecosse Dyno Day 31/10/09
175.2Bhp & 149lb/ft Big grin
Posted 7th May 2009 at 00:29
Post #181
Thanks Ash - let me know if they are long + bend enough Ninja
Posted 7th May 2009 at 01:03
ash
Six Addict
Post #182
There's a bottle of wine waiting for her!
Took over an hour to book these collections on line, not to mention the time taken to wrap them or the 150kg in my boot when I collected them.
Posted 7th May 2009 at 11:26
mabgti
NV motors
Post #183
any spare bars?
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 7th May 2009 at 11:51
Post #184
Cheers Ash - got mine today and it will be on in about 16 hours time!!
Posted 7th May 2009 at 21:32
ash
Six Addict
Post #185
mabgti wrote:
any spare bars?
I need list of another 10 to do them for
Posted 8th May 2009 at 14:13
james_geldart
Post #186
Anyone want to knock up a quick detailed guide for fitting this? Blush
cheers
Recommends:
'mechanical_repairs' - Leicester
'miles' for suspension & Grp N/A goods
Baker BM Mounts
Posted 8th May 2009 at 15:07
condieboy
Post #187
mabgti wrote:
any spare bars?
I cant see another 16 people being up for this for a couple of months, which will give me time to get the cash together. Smile
Posted 8th May 2009 at 15:18
drew o
Post #188
i got mine today the missus said so shall have a good look when i get in Big grin
306 GTi-6™ In Moonstone FTWBig grin
Team Speedline Turini
PS3-Drew_o
Posted 8th May 2009 at 17:08
tobeski
Post #189
cheers
Basically take the rear wheels off, undo the smaller bolts holding the arb end plates to the trailing arms. Then get an M12 bolt and wind it in to one of the end plates so it comes off, then just pull the end plate on the other side and the whole bar will come out. Easy as that, 20 mins max. Put one end plate back on the thicker end of the new ARB, push the bar back through (Will only fit from one end), refit other end plate and bolt evertything up and refit wheels
Look at nwphoto's FAQ for lowering the rear as it's included in the process
Now rollin' in a 182FF
Posted 8th May 2009 at 17:14
Post #190
make sure its an M12 x 1.5 bolt not a standard 1.75 thread.
Posted 8th May 2009 at 17:17
anderoo
Post #191
Received mine earlier. Big grin
The delivery man looked a little confused. LOL
Pics of my 6
My 6 on Google Video thanks to coxy306Xsi
Posted 8th May 2009 at 23:19
drew o
Post #192
well i came through the door and the missus said am i auditioning for gladiators lol looks great though nice 1 ash Big grin
PS3-Drew_o
Posted 9th May 2009 at 00:03
Trigger
General Trig
Post #193
Got mine today thanks Smile
Posted 9th May 2009 at 00:18
ash
Six Addict
Post #194
cheers
Use a Head Bolt, if you need one I can post you one, if I have enough I'll send one with each future bar.
Don't forget that one end has 31 splines and the other 32 splines; this is to allow almost infinite alignment between one end and the other. Trial fit both ends gently on the garage floor or other flat surface to see if you are lucky and the ends line up first time; if not then rotate both ends one spline and try again until they line up perfectly. Now trial fit on the car as many cars are not perfectly aligned; if not, you have a choice: either align them perfectly with the car, or get an assitant to lift the relevant trailing arm until it does line up - although this doesn't sound particularly accurate, imagine the forces of the suspension when it's on the road!
Also when trying to get the first lever end off, loosen the 13mm bolts but initially don't remove them fully or the bar will spin. If one side won't come apart easily then try the other; usually the passenger side is worse as all the crap from the kerb gets thrown up this side. If you cannot get the second lever end off, bolt the M12 bolt up tightly and then use a blow torch on the lever end. Failing this you may need to use a hydraulic press; the car is driveable without the ARB but the handling will be appauling and unpredictable so drive slowly!
Posted 9th May 2009 at 14:27
Post #195
I've used a head bolt like Ash said, one thing to bear in mind is the shape of the end of the bolt, it needs to be flat so you may need to cut it off or grind it down.
If you have a smaller tapered section on the end of the bolt as manu do have, this can damage the end of the M8 thread in the end of the Anti roll bar.
The Right hand end plate (drivers side in the uk) is the one that is intended to be removed when disassembling, the left hand one is drawn fully onto the splines, hence why its easier to pull the R/H one off Wink
I dont know if Ash has had it incorporated into his bars, but o.e bars have a cutout on the Left hand fixed end that you align with the bracket retaining hole, tap the end plate/lever onto the splines carefully, then draw it on fully with an M8 bolt and large washer, then fit the ARB through the beam, align the end plate and draw it on with a long bolt nut and washer, simply beating it wont suffice, you need a 1mm clearance overall (0.5mm each side)
Posted 9th May 2009 at 15:26
clen666
Post #196
Got mine yesterday thanx ash Big grin
now need to pull my finger out and get it fitted.....
Team 'unintentional rat look'
Posted 9th May 2009 at 18:08
Post #197
Its not that bad actually, just a bit rolly. Whistle
Posted 9th May 2009 at 22:44
clen666
Post #198
told our missus am building my own kebab grill LOL
Posted 9th May 2009 at 22:47
Post #199
What are you going to kebab? A whole cow?!LOL
Posted 9th May 2009 at 22:54
clen666
Post #200
well I do like a good bbq!
Posted 9th May 2009 at 22:57
