Ph2 Black GTI 6!EX black 6 owner
| Author | Subject: Hybrid & 30mm ARB's |
Seasoned Pro Location: Reading/parts for sale Registered: 21 Nov 2008 Posts: 4,311 Status: Offline |
Post #351
also if you could drill a hole in the end and tap it it would be great........not sure if im the only one but my end plates come off way to easy,im alway checking they are still their haha________________________________________ Ph2 Black GTI 6!EX black 6 owner But now a Black caged rallye owner Hunting for Go faster bits! SEARCH click here |
marksorrento205
Seasoned Pro Location: Airborne in the lanes Registered: 26 Aug 2008 Posts: 2,228 Status: Offline |
Post #352
cooper666 wrote: arrived today great piece of engineering Mine has arrived too Cheers Ash!!________________________________________ How to do a clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
karoshi
Junior User Location: Sydney Registered: 07 Mar 2010 Posts: 60 Status: Offline |
Post #353
Pm'd________________________________________ CheersBill |
beez_neez_gt
Post #354
daveyboy wrote: I have the 30mm ARB and thats fine on the road I have to disagree with that. Ive not read the whole thread but the larger ARB's can be a bit skittish over the bumps on the road surface rather than the flat track type. Also the larger ARB's make the car worse in the wet but brilliant in the dry. Also whats the best way of taking the end plates off without having to take the TB out ? Would copper grease be a good idea when refitting them so easier to take off at a later date ? ________________________________________ Pug fee`ver,Pick a Bogey, buy a Pug. Black 306 GTI 6 Standard, was 60k mileage, bargain!! Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
ash
Six Addict Location: Chelmsford Registered: 25 Mar 2003 Posts: 7,520 Status: Offline |
Post #355
I wouldn't recommend the 30mm ARB for a road car, but the Hybrid makes the car considerably safer especially in the wet.Use a well greased head bolt with an impact gun if possible. |
superchargedblack1997gti6
Post #356
1.306/Xsara Hybrid aussiexsara2.306/Xsara 30mm ARB - ikitson1. 3.306 30mm ARB bellcp306td 4.306/Xsara Hybrid - Vetch 5.306 hybrid ARB Ross supercharged1997gti6 6.306 hybrid ARB Ross supercharged1997gti6 7. 8. 9. 10. ________________________________________ Super high boost Completed, destroyer of gearboxes and 160mph club |
karoshi
Post #357
superchargedblack1997gti6 wrote: 1.306/Xsara Hybrid aussiexsara 2.306/Xsara 30mm ARB - ikitson1. 3.306 30mm ARB bellcp306td 4.306/Xsara Hybrid - Vetch 5.306 hybrid ARB Ross supercharged1997gti6 6.306 hybrid ARB Ross supercharged1997gti6 7.306 hybrid Karoshi 8. 9. 10. ________________________________________ CheersBill |
ash
Post #358
As long as everyone is ready to pay I just need one more interested party and I'll get them made. |
Post #359
I may be up for a hybrid item, any idea on the spring rate though?Weighing up whether to up the torsion bars and stick to 24mm arb, or go hybrid (already on 21mm as its a ZX) ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
gti-dan
Regular Location: Yorkshire Registered: 03 Jan 2010 Posts: 461 Status: Offline |
Post #360
Ash is there any chance u can get hold if / make some 23.5mm tb's? Why is there such a shortage of them?!? Plenty if people seem to want them! |
bellcp306td
Regular Location: Bedlington Registered: 10 Aug 2009 Posts: 166 Status: Offline |
Post #361
Ok here is my problem I was under the impression that the 30mm was ok for road use but as said its not. I have a hybrid ARB all ready and was planning to change to a 30mm one when I have rebuilt my rear beam witch I have done (Arm tubes have been made bigger for the 30mm bar). my rear beam has 21mm Tbars and Spax PSX adjustable shocks.Do I get the 30mm and just use it on track 1 to 2 times a year or do I ask for a 28mm one? will the 28mm one be better then the Hybrid but not as harsh as the 30mm? Help Please Chris ________________________________________ Where did the road go!Chris |
Post #362
scoobydoo, as nobody has ever answered the several requests for the spring rate of the Hybrid item, its difficult to be specific.Harshness will not come from the ARB though, Try some better dampers. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
birk
Seasoned Pro Location: Doncaster Registered: 24 Oct 2005 Posts: 7,032 Status: Offline |
Post #363
When can the hybrids be made up and sent out ash ?Im interested. ________________________________________ Dimma + Gt35 turbo =![]() Solid rear beam mounts £130 07889376885 Dan |
bellcp306td
Post #364
The ride is fine but people say the 30mm make the car bad when wet and real bumpy roads.If i had the answer to your question i would tel you but i am not that clever. hope you find out. Chris ________________________________________ Where did the road go!Chris |
ash
Post #365
I've used a 29mm ARB and found it very good but the 30mm better on track. Bear in mind that I run 25.4mm TB's. I can get any size ARB made from 25.4 - 30mm same price but do not get TB's made, sorry. Could everyone please confirm that they are ready to pay and how and I'll pm you with Paypal or Bank details. As soon as I hear from everyone I'll get them made; they will be sent out approximately two weeks later. If you miss this batch there will only be another batch made when there are ten definite buyers again. |
birk
Post #366
1.306/Xsara Hybrid aussiexsara2.306/Xsara 30mm ARB - ikitson1. 3.306 30mm ARB bellcp306td 4.306/Xsara Hybrid - Vetch 5.306 hybrid ARB Ross supercharged1997gti6 6.306 hybrid ARB Ross supercharged1997gti6 7.306 hybrid Karoshi 8.306 hybrid Birk ________________________________________ Dimma + Gt35 turbo =![]() Solid rear beam mounts £130 07889376885 Dan |
Post #367
1.306/Xsara Hybrid aussiexsara2.306/Xsara 30mm ARB - ikitson1. 3.306 30mm ARB bellcp306td 4.306/Xsara Hybrid - Vetch 5.306 hybrid ARB Ross supercharged1997gti6 6.306 hybrid Karoshi 7.306 hybrid Birk Sorry Friend who wanted the other one has pulled out sorry guys. ________________________________________ Super high boost Completed, destroyer of gearboxes and 160mph club |
triky_6y
Junior User Location: Addlestone Registered: 12 Jun 2008 Posts: 94 Status: Offline |
Post #368
superchargedblack1997gti6 wrote: 1.306/Xsara Hybrid aussiexsara 2.306/Xsara 30mm ARB - ikitson1. 3.306 30mm ARB bellcp306td 4.306/Xsara Hybrid - Vetch 5.306 hybrid ARB Ross supercharged1997gti6 6.306 hybrid Karoshi 7.306 hybrid Birk 8.306 hybrid triky_6y . ________________________________________ B-Road bomber |
r.a.m. 106
Junior User Location: Ballina Registered: 04 Nov 2007 Posts: 60 Status: Offline |
Post #369
1.306/Xsara Hybrid aussiexsara2.306/Xsara 30mm ARB - ikitson1. 3.306 30mm ARB bellcp306td 4.306/Xsara Hybrid - Vetch 5.306 hybrid ARB Ross supercharged1997gti6 6.306 hybrid Karoshi 7.306 hybrid Birk 8.306 hybrid triky_6y 9.306 30mm arb r.a.m. 106 |
karoshi
Post #370
Pm sent________________________________________ CheersBill |
bellcp306td
Post #371
1.306/Xsara Hybrid aussiexsara2.306/Xsara 30mm ARB - ikitson1. 3. 4.306/Xsara Hybrid - Vetch 5.306 hybrid ARB Ross supercharged1997gti6 6.306 hybrid Karoshi 7.306 hybrid Birk 8.306 hybrid triky_6y 9.306 30mm arb r.a.m. 106 I have had to drop out after much deliberation the car handles really well i dont want to upset that. thanks Ash for all you help! ________________________________________ Where did the road go!Chris |
jammapic
Senior User Location: Manchester Registered: 11 Jun 2010 Posts: 778 Status: Offline |
Post #372
1.306/Xsara Hybrid aussiexsara2.306/Xsara 30mm ARB - ikitson1. 3. 4.306/Xsara Hybrid - Vetch 5.306 hybrid ARB Ross supercharged1997gti6 6.306 hybrid Karoshi 7.306 hybrid Birk 8.306 hybrid triky_6y 9.306 30mm arb r.a.m. 106 10. 306 hybrid jammapic ________________________________________ HDI Engine Tuning / Remapping Services - https://www.facebook.com/dervtech306 GTi-6 Track Car - 200+ hp all N/A! 306 DTurbo Track beasty - 209.9hp - RIP |
bellcp306td
Post #373
Nice one JP you will not regret getting one________________________________________ Where did the road go!Chris |
ash
Post #374
1.306/Xsara Hybrid aussiexsara2.306/Xsara 30mm ARB - ikitson1. 3. 306 hybrid jammapic 4.306/Xsara Hybrid - Vetch 5.306 hybrid ARB Ross supercharged1997gti6 6.306 hybrid Karoshi 7.306 hybrid Birk 8.306 hybrid triky_6y 9.306 30mm arb r.a.m. 106 10. 306 hybrid (available: please overtype) 11. 306 hybrid (available: please overtype) 12. 306 30mm (available: please overtype) I'm going to finally order the above bars this week so they will be available in about two weeks from now. I don't want any deposits or payments yet but please add "paypal" or "bank tfr" after your name and I will send you the details when I want paying. Price is £180 as previously mentioned, including delivery to UK Mainland only, by Paypal. I am happy to take £170 by Bank Transfer or £160 cash on collection from Chelmsford as long as you turn up when you say you will first time! I still have two 25.4mm 106 ARB's which I will sell for (each) only £120 Paypal, £110 Bank Transfer or £100 Cash on collection as per above. This will undoubtedly be the very last batch I ever get made hence why I am getting a spare 30mm bar made as some one will always want it even if not straight away. |
birk
Post #375
1.306/Xsara Hybrid aussiexsara2.306/Xsara 30mm ARB - ikitson1. 3. 306 hybrid jammapic 4.306/Xsara Hybrid - Vetch 5.306 hybrid ARB Ross supercharged1997gti6 6.306 hybrid Karoshi 7.306 hybrid Birk - Bank Transfer 8.306 hybrid triky_6y 9.306 30mm arb r.a.m. 106 10. 306 hybrid (available: please overtype) 11. 306 hybrid (available: please overtype) 12. 306 30mm (available: please overtype) ________________________________________ Dimma + Gt35 turbo =![]() Solid rear beam mounts £130 07889376885 Dan |
