displaying posts 51 to 75 of 563
Pages (23): first .. 2 [3] 4 .. last
Author Subject: Wilwood brakes
Welly Forum Admin
Post #51
phillipm wrote:
Pretty sure the 307 285mm discs have more offset though, certainly mine have quite a lot more than a gti6 disc.
They do, but they are way more expensive and bloody heavy
Vrs power!!
Posted 21st Aug 2008 at 04:46
Post #52
Well, I can solve the latter, but not the first LOL
Posted 21st Aug 2008 at 04:47
psjunkie
Post #53
does this mean you could in theory run these with no spacers? would the bracket have to be different then ?
edit! even with 7mm spacers you wont be able to tell. i would stick to that
1997 P1 Gti 6 Charged
Posted 21st Aug 2008 at 04:49
Welly Forum Admin
Post #54
Not quite, i can't find the sizes. I do have them somewhere.
The other factor is that the 206 discs are thicker too.
They won't fit into a wilwood caliper. And the offset is only about 4mm so not enough anyway. You would still have to run a spacer albeit a smaller one
Vrs power!!
Post #55
Yes, bracket would need altering, and I think you still need a shim.
Posted 21st Aug 2008 at 04:50
psjunkie
Post #56
im sure welly will come up with the best comprimise
im excited about this wilwood adventure haha LOL
will the spacers be an optional extra in the pack welly?
Posted 21st Aug 2008 at 04:51
damien
Post #57
Welly wrote:
snap Big grin
Posted 21st Aug 2008 at 13:31
rallyestyle
Post #58
Good work Welly Thumbs up
So am i right in thinking they will need spacers to fit under cyclones? Unsure
Just Drive It
Posted 21st Aug 2008 at 14:18
SteviePut
Post #59
I'm really interested in this Welly but I have few questions for you or PhilSmile
1: Will running spacers on the front only have any detrimental effect to the handling of the car? I know it's only going to be ~10mm but even so. Or should you run the same spacers all round?
2: Will said spacers have a detrimental effect on the longevity of the wheel bearings? As they will be under more load
Posted 21st Aug 2008 at 14:37
Welly Forum Admin
Post #60
I'll let Phil answer those fully, but i run 25mm hubcentrics already.
Not quite as cut and dry as that ias you'll need longer bolts too
Vrs power!!
Posted 21st Aug 2008 at 16:25
Post #61
The effect of 10mm spacers on wheel bearing life will be negligable, there will be some effect, but nothing worth worrying about.
Handling-wise, well it'll make the rear spring rate ever so slightly harder in roll, the extra track width will reduce roll, but you'll notice a touch less high-speed stability and brake imbalances will be more noticable (not that you should have any really but...), but the car will feel more responsive on initial turn in instead, and a bit more neutral under power on the way out.
Steering will be a touch heavier as the tyre doesn't roll so much but rather twists on the contact patch.
A touch more torque steer(not that's there's much anyway) over bumpy tarmac, compensated by the steering being a bit more benign over those same bumps.
Worth noting that the effects will be very subtle though.
I've actually been running at ET9 myself for 4 years as I've a touch more camber on the front, so it sorts itself out, no trouble.
Posted 22nd Aug 2008 at 16:33
SteviePut
Post #62
Would it be ok to just run the spacers on the front? What effect would that have? I'd imagine make the rear a little skittish??
Posted 21st Aug 2008 at 17:18
Post #63
It wouldn't make a huge amount of difference really, spacers on the rear have the effect of reducing the rear roll, but spacers on the front have the effect of softening the front suspension slightly, but with the caveat that the extra track width counteracts any extra roll effect.
If anything spacers on the rear would make the back a touch harder, whereas on the fronts would leave the overall balance much the same.
To be honest, there'll be bugger all in it, mines still on a negative scrub radius.
Posted 21st Aug 2008 at 17:27
SteviePut
Post #64
Cheers PhilThumbs up
Posted 21st Aug 2008 at 17:32
richie_h
Post #65
I could be very interested in these, is the disc offset the same on the late xsi as the 6?
Keep us posted on when they are going to be availableCool
Posted 21st Aug 2008 at 18:15
Welly Forum Admin
Post #66
It's a std off the shelve gti 6 disc. It's just a caliper upgrade
Vrs power!!
Posted 21st Aug 2008 at 19:44
Welly Forum Admin
Post #67
Welly wrote:
To work braking force out, you need to measure 1 side of a caliper.
To work out the square inch of overall piston size:
57mm = 2.24"
Radius = 1.12"
Piston area = Pi*R² or 3.14*1.12² = 3.93²"
35.1 = 1.38"
Radius = 0.69"
Piston area = Pi*R² or 3.14*0.69² = 1.49²"
2 pistons so 1.49 x 2 = 2.98²"
As i said you only work out one side of the caliper
Thumbs up Read here
Welly wrote:
suffolkpaul wrote:
standard is 2 x 57.1mm pistons
wilwood is 4 x 35.1mm pistons an extra 22%ish think
Ok this is how it brakes down.
You need to work out the square inch of the calipers piston area. (one side of the caliper only)
Std Gti6 is 3.93 square inch.
Powerlites is 3.54 square inch
Midilites is 4.8 square inch
Brembo is 4.93 square inch
By moving over to the powerlites your reducing your piston area by 10% over std calipers
By moving up to Brembo's your going up 25%
By moving up to Midilites your going up 22%
Vrs power!!
Posted 23rd Aug 2008 at 03:10
psjunkie
Post #68
how are the brakes holding up welly?
Posted 23rd Aug 2008 at 17:50
stilly
Post #69
hi welly... these brackets, have you heli-coiled where the bolt goes through to hold the caliper to the bracket... or you using a nut and bolt system...???????
deaf in 1 eye blind in 1 ear Crazy......
307 136bhp daily drive.....
306 rallye stripped out and charged.....
lee_gti6 also known as "the tit".....
stan_306gti6 also known as "stan the dick".......
Posted 23rd Aug 2008 at 19:54
psjunkie
Post #70
pretty sure he's heli-coiled them pal.
Posted 23rd Aug 2008 at 22:15
Welly Forum Admin
Post #71
Currently haven't done anything to them
They are still sat on my desk.
Vrs power!!
Posted 23rd Aug 2008 at 22:34
psjunkie
Post #72
LOL
Posted 24th Aug 2008 at 00:07
Welly Forum Admin
Post #73
Well they are on.
Only gunna give a brief run down now and a full one later.
Hoses made, bolted them on and away we went. Simple. Still need another bleed yet to make them 100% and pads all but bedded but slowly getting there.
Feel just like the brembosBig grin
Vrs power!!
Posted 31st Aug 2008 at 00:53
Welly Forum Admin
Post #74
The hose ends i am using are goodridge 600 series. Easy enough to make up and cheap enough
The Car end
After the original hose comes
Empty hub
My lovely assistant.
New hoses on
Disc, caliper with hose attached
Fitted and road tested
Check out the heat gone into them buggers
Vrs power!!
Posted 31st Aug 2008 at 02:34
Rich E Forum Admin
Post #75
What sort of price are you looking at for calipers and brackets?
Posted 31st Aug 2008 at 02:53
