Team Supercharged Gti-6™
| Author | Subject: Wilwood brakes |
davedgti6
Seasoned Pro Location: whiston, prescot Registered: 28 May 2006 Posts: 1,651 Status: Offline |
Post #501
Its exactly the same, as you still use a 283mm standard disc, although it may be a few mm further out than the standard setup as Welly has had the brackets made so that the pad sits right at the outer edge of the disc,________________________________________ Team Supercharged Gti-6™![]() |
vts_tibi
Seasoned Pro Location: Nuneaton Registered: 27 Apr 2007 Posts: 1,194 Status: Offline |
Post #502
I think even 2-3mm would kill my project... I'm gonna make a picture soon to show.________________________________________ VTSbest 60' : 2.272 best 1/8 ET : 9.375 @ 74.42mph best 1/4 ET: 14.603 @ 97.047mph Team Trackday™ |
Post #503
davedgti6 wrote: Its exactly the same, as you still use a 283mm standard disc, although it may be a few mm further out than the standard setup as Welly has had the brackets made so that the pad sits right at the outer edge of the disc, But the top of the caliper should be shallower than a Gti6 item? ________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
davedgti6
Post #504
phillipm wrote: davedgti6 wrote: Its exactly the same, as you still use a 283mm standard disc, although it may be a few mm further out than the standard setup as Welly has had the brackets made so that the pad sits right at the outer edge of the disc, But the top of the caliper should be shallower than a Gti6 item? ahh i understand his question now, i thought he was asking about disc sizes , he's asking about how far the wilwood caliper is from the centre compared to the standard gti-6 setup, Will measure mine ________________________________________ Team Supercharged Gti-6™![]() |
davedgti6
Post #505
Roughly 160mm centre of wheel to outside of caliper, ________________________________________ Team Supercharged Gti-6™![]() |
Post #506
That's not bad then really, my 307 calipers are 150mm on 266mmm's________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
Post #507
isn't it the distance the caliper sticks out from the disc itself that's the killer? how far is that dimension?________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Post #508
welshpug! wrote: isn't it the distance the caliper sticks out from the disc itself that's the killer? how far is that dimension? "and there's load of space outwards" ________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
Post #509
ook?! why the use of spacers?________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Post #510
He's using different wheels.________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
vts_tibi
Post #511
davedgti6 wrote: Roughly 160mm centre of wheel to outside of caliper, thanks for that! gonna make a picture soon (when it'll stop raining )________________________________________ VTSbest 60' : 2.272 best 1/8 ET : 9.375 @ 74.42mph best 1/4 ET: 14.603 @ 97.047mph Team Trackday™ |
garry
Regular Location: Crowland Registered: 13 Feb 2005 Posts: 305 Status: Offline |
Post #512
Right, I have just spoken to Rally design and the calipers are now ________________________________________ 205 GTI6 S |
SteviePut
Seasoned Pro Location: Down south Registered: 20 Oct 2005 Posts: 13,637 Status: Offline |
Post #513
I gave mine some stick last night on the way home and they were fine. I treated them to around 5 fairly harsh applications from quite high speed and they seemed fine. Trouble is it's not what they have to cope with on a track tho I'm thinking about going for the 'A' pads when these are worn out. Trouble is Gary the car doesn;t get driven much so it could be a couple of years yet!!!![]() ________________________________________ My old man wrote me a letter from prison once. It said if you don't want to end up in here, stay away from crime, women and drugs. Trouble is, that don't leave you much else to do, does it? |
vts_tibi
Post #514
garry wrote: Right, I have just spoken to Rally design and the calipers are now
smegal
Post #515
At the moment 15% VAT________________________________________ Ex SC-6Now in a Megane R26 |
midlife
Seasoned Pro Location: Colne, Lancashire Registered: 13 Mar 2006 Posts: 7,544 Status: Offline |
Post #516
15% too slowThought with you being abroad you shouldnt have to pay our VAT ![]() ![]() ________________________________________ Get used to seeing the yellow one !!!![]() ![]() ![]() ![]() ![]() Team 330™ ![]() Team "no front end or engine" Team "LIMITED EDITION" I live for the 306 sticker ![]() Team 0-60 in 6.44 & standing qtr in 14.808 @ 94.55mph all with std engine ![]() 203bhp Corolla T-Sport daily driver stealthier than Kwai Chang Caine |
Post #517
LIke I said Garry, we use them on the front of the buggy and they bite as well cold as OEM pads - they just get better and better with a couple of stops.________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
vts_tibi
Post #518
midlife wrote: 15% too slowThought with you being abroad you shouldnt have to pay our VAT ![]() ![]() unfortunately I have to... and it's even worse when something comes from outside of the E.U. from the U.S.A. for example! I have to pay out the price there + VAT, and when it arrives to Hungary they put our own VAT (20%) on the top of the total price including shipping, and then I have to pay custom duties after that amount so this means it's double taxed ________________________________________ VTSbest 60' : 2.272 best 1/8 ET : 9.375 @ 74.42mph best 1/4 ET: 14.603 @ 97.047mph Team Trackday™ |
garry
Post #519
phillipm wrote: LIke I said Garry, we use them on the front of the buggy and they bite as well cold as OEM pads - they just get better and better with a couple of stops. Which ones Phil? The smart pad or the 'A' class racing pads? Thanks ________________________________________ 205 GTI6 S |
Post #520
The 'A' class pads________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
smegal
Post #521
Will the wilwoods fit over OZ Superturismo wheels in 15"?________________________________________ Ex SC-6Now in a Megane R26 |
psjunkie
Seasoned Pro Location: Halifax Registered: 31 Aug 2007 Posts: 1,565 Status: Offline |
Post #522
should think so. fit over my comps with no spacers________________________________________ 1997 P1 Gti 6 Charged |
smegal
Post #523
How come you're selling up?________________________________________ Ex SC-6Now in a Megane R26 |
SteviePut
Post #524
smegal wrote: How come you're selling up? Bike licence I think ![]() ________________________________________ My old man wrote me a letter from prison once. It said if you don't want to end up in here, stay away from crime, women and drugs. Trouble is, that don't leave you much else to do, does it? |
smegal
Post #525
Shit. I remember reading that in the for sale thread. Didn't take it in them posted up here.________________________________________ Ex SC-6Now in a Megane R26 |
