displaying posts 476 to 500 of 563
Pages (23): first .. 19 [20] 21 .. last
Author Subject: Wilwood brakes
Post #476
Nowhere near as cheap as the Wilwood pads though Sad No
Posted 5th Mar 2009 at 21:35
smegal
Post #477
This the sort of pressure bleeder to make wilwood fitting easier?
Ex SC-6
Now in a Megane R26
Posted 5th Mar 2009 at 22:36
davedgti6
Post #478
i used a pressure bleeder on mine (not as good as that one though) and i found i still could not get all the air out, i think what happens is that air bubbles still cling to the sides of the pipes and calipers and the pressure bleeder wouldn't shift them,
What i did is to use a pressure bleeder (so that the fluid level cant go too low) combined with a normal one way valve bleeder tube on the nipple,
I then got the missus to pump the brake pedal while i watched for air bubbles, i was amazed at the amount of air that came out as i had bled it twice already with the pressure bleeder
Pedal feels nice and solid now, although i am going to give it one last bleed at the weekend
Smile
Posted 5th Mar 2009 at 23:51
Post #479
That's the way I normally do it, shifts any small bubbles clinging to the internal surfaces then.
SteviePut
Post #480
I'm still not 100% convinced about mine either TBH. I still think there maybe a wee bit of air left in there. Although every time I do bleed them they get betterSmile
Posted 5th Mar 2009 at 23:53
Post #481
Wedge the brake pedal down overnight and then bleed them the morning after, sometimes helps shift the air up to the master cylinder so it comes out the res.
Posted 5th Mar 2009 at 23:56
SteviePut
Post #482
What are these other pads you speak of Phil? What's the heat range like? Good from cold?
Posted 5th Mar 2009 at 23:58
Post #483
100~900*c....Whistle
Probably need a stop just to get them warm but after than should be fine, they're quite a soft pad so not too bad even when it's freezing (downside is they do dust a fair bit because they're soft...)
Just sit down before you ask about the price Yes
Posted 6th Mar 2009 at 00:54
SteviePut
Post #484
I'm sitting . . .
Posted 6th Mar 2009 at 00:56
Post #485
Posted 6th Mar 2009 at 00:58
Post #486
Have you got back up off the floor yet?
Posted 6th Mar 2009 at 01:01
davedgti6
Post #487
Posted 6th Mar 2009 at 01:04
Post #488
Indeed, they worked out about
Posted 6th Mar 2009 at 01:12
smegal
Post #489
Phillip any news on making up some spacers?
Ex SC-6
Now in a Megane R26
Posted 6th Mar 2009 at 01:16
Post #490
No, I haven't been up to the main workshop for a fortnight, been repairing a few family cars!
Posted 6th Mar 2009 at 01:23
smegal
Post #491
I know its cheeky but could you look at some drawings that I have done to make sure that i have done them right then so I can crack on with getting some made.
Ex SC-6
Now in a Megane R26
Posted 6th Mar 2009 at 01:24
mr swampy s16
**BAD SELLER**
Post #492
The pagid rs4 blue pads i use are
Posted 6th Mar 2009 at 02:07
SteviePut
Post #493
Sorry Phil, My lovely girlfriend (She's watching me type thisLOL) placed a plate full of food in front of meLaugh my ass off
Well they're expensive compared to the pads I'm using just now. IIRC the smart pads come in at ~
Posted 6th Mar 2009 at 02:11
SteviePut
Post #494
Posted 6th Mar 2009 at 02:12
Post #495
Posted 6th Mar 2009 at 04:04
mr swampy s16
**BAD SELLER**
Post #496
No im still useing the standerd s16 calipers.
They stop me as good as i need.
Posted 6th Mar 2009 at 12:04
scib4
Post #497
Can you give any more details Phil??
I used to run Carbotechs XP8's on my Rallye, Brilliant pads, so good in fact i now run them on my S2000!
Mike
08 BMW 320d M-Sport touring (Superchipped Spec)
11 VW Transporter Kombi T5.1GP LWB (Bi-Turbo spec)
Yeti DJ (Jump spec)
Specialized SX Trail (DH spec)
Specialized Pitch (XC spec)
Posted 6th Mar 2009 at 18:21
Post #498
Bit higher operating temperature range than XP8, high friction level too, probably not quite as easy on discs though.
I was looking at XP8's to run with my 266's, what are they like compared to 1144 and 2500?
Posted 6th Mar 2009 at 20:39
vts_tibi
Post #499
sorry if this was covered later, but I just can't be arsed to read back 25 pages...
so, the distance I marked on the picture - how different is that compared to the original brake setup?
As today I've investigated my brake caliper and wheel clearance, and there's load of space outwards, but nothing between the caliper and the wheel (Tecnomagnesio TM Light 15')
VTS
best 60' : 2.272
Team Trackday™
Posted 7th Mar 2009 at 00:04
vts_tibi
Post #500
anyone?
VTS
best 60' : 2.272
Team Trackday™
Posted 9th Mar 2009 at 00:09
