displaying posts 1 to 25 of 56
Pages (3): [1] 2 3
Author Subject: braided brake hoses
ted
Finally got round to fitting my braided brake hoses.
For thoughs that have done it what did you do about the solid to flexi union on the fronts. The original has a splinded end that fits the little bracket in the wheel arch, where as the braideds' dont have the splines and so don't fit into the bracket. ?
Monkey see monkey do
Posted 16th Apr 2008 at 20:09
rallyestyle
Cable tie is the answer i believe you will get Yes Unsure
Just Drive It
Posted 16th Apr 2008 at 20:12
pedro_de_la_cruz
useful to know, im changing mine over later today Wink
*R.I.P Pete Sims*
Posted 16th Apr 2008 at 20:50
ted
well I'm fitting black diamond hoses and I'm not very happy with the fitment to be honest. Last thing i want is for the lines to move with the vibration of the car. The little bracket has little teeth in it which work well with the original splinded hose but not my crappy braideds Doh
Posted 16th Apr 2008 at 20:55
pedro_de_la_cruz
hmm mine are goodridge and dont seem to have any splines???
cable ties will have to suffice if fitment becomes a problem
*R.I.P Pete Sims*
Posted 16th Apr 2008 at 21:15
mankee
Do you not have a little spring clippy thing to hold everything tight?
Posted 16th Apr 2008 at 22:04
ted
thanks for the pic mankee.
heres my version.
the cylinder part of my hoses didn't fit through the hole Whistle so i couldn't use the clip.
How did you fit that hose at the bracket.
Sorry if its a bit of a newbie question
ted has attached the following image:
Posted 17th Apr 2008 at 00:10
mankee
The braided hose should fit from the bottom up into the bracket. It's a mega tight squeeze because the old flexi's splined bits have probably rusted to buggery!
You might need to file the hole a little bit. A punch and a few taps with a small hammer to help ease the braided line in will do the trick. And then you can fit the little springy thing as before. Smile
Posted 17th Apr 2008 at 00:48
ted
Thumbs up thanks mate
Posted 17th Apr 2008 at 01:14
miles
They do need a wiggle to fit thru but only having fitted the ones I make I know they fit, I know the Goodridge ones for the 205 still don;t fit after 20yr's of them making the thing's, Why they can;t get it right, who know's as it's not difficult at all.
www.pugracing.com
Posted 17th Apr 2008 at 06:37
iplay
is a special brake spanner required to remove this nut or can an open ended spanner be used?
Posted 17th Nov 2008 at 20:43
smegal
I'd recommend using a brake pipe spanner as its easier to round them off with an open ended spanner.
Ex SC-6
Now in a Megane R26
Posted 17th Nov 2008 at 21:16
ted
once its all lubbed up with brake fluid its easy to round them with a brake pipe spanner too Wink
Posted 17th Nov 2008 at 22:04
smegal
Must admit I've done that before Blush
Ex SC-6
Now in a Megane R26
Posted 17th Nov 2008 at 22:28
iplay
The passenger side nut was fine ... but the drivers side requires plan B Whistle
So what was plan B Dunno ... hacksaw out the rounded nut?
Posted 18th Nov 2008 at 02:02
mankee
Use mole grips on them to loosen them is what I'd do.
Posted 18th Nov 2008 at 15:23
ted
mole grips, or maybe file the edges down and use a smaller spanner ?
Posted 18th Nov 2008 at 16:55
does the clip thing come with these??
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 30th Aug 2009 at 23:29
mr swampy s16
**BAD SELLER**
Not normaly but i can supply with any kits supplied if required
Posted 30th Aug 2009 at 23:34
anybody know if its straightforward enough to change the front drivers side brake pipe from the flexi to where it ends??
Posted 4th Jan 2010 at 23:52
as in back towards the ABS pump? nope tis a right cnut as it goes behind the engine right across to the other side and round under the battery to the ABS pump.
Posted 5th Jan 2010 at 00:09
yes it looks like it goes back towards the abs pump via beahind the engine, but i thought it came back up and joined with a in line connector in front of the brake servo.
if that makes sense?
ive rounded the nut of big time, took me hours to remove the flexi, maybe id be better off just tightening it back up using molies.
Posted 5th Jan 2010 at 00:20
has anybody reused the other rubber part and the long spring thing, im just thinking it may give it more protection.
Posted 8th Jan 2010 at 01:41
im not sure wether to fit the long spring type thing and the other long rubber bit with the braided hoses.
Posted 9th Jan 2010 at 00:25
iplay
Yes
Posted 18th Jan 2010 at 03:40
Pages (3): [1] 2 3
