displaying posts 51 to 56 of 56
Pages (3): 1 2 [3]
Author Subject: braided brake hoses
smithers
Post #51
Well my fronts were totally rusted so just rounded off, ordered some brake lines and unions. Im just going to put the join in the wheel arch as well to save me having to run the line all the way through the engine bay :thumsup
1997 Black GTi6
smithers205 at hotmail.com
Posted 23rd Jan 2010 at 23:22
Post #52
was wondering earlier what the original pipes were made from, they look steel, and they also look narrower than the copper pipe like above on iplay`s car.
if it is steel then it may be trouble using the smaller flaring tool on it.
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 24th Jan 2010 at 01:00
skinnyman76
Post #53
yip oe are steel mate good luck.. mine are done same as iplay with the original hose split over the braided at one end and squeezed tight rubber at the other
pug power !!!
i got the need for a 6 speed!!!
Posted 24th Jan 2010 at 07:17
smegal
Post #54
The original ones are steel. You will not do steel with either of the tools you linked to. The Sealey one is really easy to use and can be used with the pipe on the car (copper or cupro-nickel).
Ex SC-6
Now in a Megane R26
Posted 24th Jan 2010 at 07:33
Post #55
yeah ive done mine the same as neil also, keeping all the original springs and rubbber bits. ill post a pic up.
i removed the union nut from the braded pipe yesterday by puttting the mole grips between the shock and the innerwing/bulkhead, the change of angle got a better griop and cracked it undone.
looks like i will have to change the whole pipe then.
Posted 24th Jan 2010 at 13:33
iplay
Post #56
I forgot the original ones are steel ... guess that was the reason i had to cut it out in 3 sections.
Posted 24th Jan 2010 at 18:09
Pages (3): 1 2 [3]
