displaying posts 76 to 100 of 158
Pages (7): first .. 3 [4] 5 .. last
Author Subject: 205 GTi6 'S' - Project build diary
rich_w
Post #76
No worries, glad the ECU is OK Thumbs up
Contact Details:
07732 822546
Posted 9th May 2008 at 23:12
sarthe82
Post #77
Hope you have a trouble free journey and keep her safe round the 'Ring mate! Thumbs up
Steve Big grin
Posted 10th May 2008 at 05:19
mabgti
NV motors
Post #78
Good luck...
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 10th May 2008 at 17:03
matsoki
Post #79
Holy f*ck..... didnt see that you were straight off to the ring!!! RTFT....
Good luck with the trip, let us know how you got on... Pics Pics!!!
Built on 25th November 1998... That was a Wednesday..... Thank God it wasn't a Friday!
RIP - Pete Sims
Posted 12th May 2008 at 21:19
garry
Post #80
Monster Post Warning!!!
What an eventfull fortnight I have had getting the bloody thing running!
The entire build was based on going to a Spa trackday I had booked back in January for May 12th, there seemed plenty of ‘float’ in the build programme at the time, about right then that I ended up finishing the car hours before setting of for Dover!
So, the weekend starting May 3rd, I had planned to have the car running this weekend, this would give me the week to run around in it to make sure everything was Ok.
My brother, Matt came up to help with the wiring. Some of the sensors needed extending as the throttle body had moved about 100mm towards the supercharger.
We wired up the second fuel pump via a relay, the trigger for this was the live feed from the in tank pump, that way the two pumps would run in sync. I had thought about running the second pump of a switch in the cabin, but was advised not to by the helpful people at Simtek UK, as if there was an accident the pump could not be easily shut down.
I completed the coolant pipe work, as you can see there isn’t much clearance between the charger drivebelt and the bottom hose!
Over the past few weekends I had noticed that I was missing the top coolant pipe, but I had convinced myself I must have put it in the shed or in the loft. So after turning the place upside down I still couldn’t find it, I was pretty stressed at this point as I couldn’t run the without it. I made a call to the guy that had changed the cambelt for me, after half an hour he called back to say he had found it, problem was he was near Southampton! I was determined to get the car running so me and the wife jumped into the beemer to go and get it, the perfect car for this sort of thing. 8 hours later we were back home with the pipe, here it is, only cost about £100 in fuel!
So on Sunday night we were ready to start it up for the first time, I filled the car with fluids, checked all of the fittings and all was ready. I turned it over a couple of times but it wouldn’t fire up (the reason for this will found later). We looked under the car to see my new expensive Silkolene oil pouring onto the drive, on close inspection the oil sandwich plate was fitted the wrong way round! I had put the threaded nut on backwards:
The nut you can see should be furthest from the block, resulting in the sandwich plate sitting some 10mm clear.
As a result I had to take the whole front end off, intercooler, boost pipes, radiator etc:
This is how it should be fitted:
So again, Monday morning I tried to get the thing started, but it still wouldn’t start. I wasted Monday and Tuesday fiddling around with everything trying to get it to go.
On Wednesday I returned to work, I was browsing a forum and some people had suggested I had the fuel rail plumbed in backwards, and Dr Sarty on the 205 drivers forum said it should be 10mm feed 8mm return, the opposite of what I had done, having read it on the 306 forum! I felt sick and embarrassed having wasted everybodys time, I knew what was wrong straight away.
I took Thursday and Friday off.
Thursday morning I swapped the pipes over and she fired up first time! This was it, I was going to make it!
I spent the rest of the day tidying up and fiddling with things;
Wiring tidied
I made a metal guard to protect the oil cooler from road debris that could flick up:
With the car now running I also noticed that the silicone hoses I had were collapsing under vacuum, I had some spare alloy tubing which I used as a replacement:
The 76mm to 51mm Silicone reducer was also being sucked into the manifold, as a quick fix I held the pipework back with some able ties:
So here we are finally ready to go:
This was on Thursday night, I was booked into DES at 12 on Friday for the new exhaust to be fitted.
On Friday morning I was up at 6 loading up the car and fitting the bumper and bonnet back on, fitted the 25mm arb. I started the car at 8.30 to check it and it was only running on 2 cylinders!
Again, I did my now well practiced fault finding sequence, ie plugs, injectors, pumps, power. But all was in order. I checked the ECU and the multi pin plug that goes into the top was wet. In my wisdom I have moved the ECU into the footwell to keep it safe form engine heat and to create room for the Swirl pot. What I hadn’t counted on was coolant running down the cables and into the ECU.
I took the ECU apart to find a couple of teaspoons of coolant in there, see bottom right:
So with some cotton buds, WD40, the wifes hairdryer and some very small screw drivers I cleaned up the circuits which now had some crystals forming on them. I plugged the ECU back in and all was well again, but I had missed my time slot at DES.
I took the car to my local garage who Mig welded the hole in the exhaust.
So I finally set off for Slough at 7pm on Friday, where I was stopping over night before Dover and ultimately the ‘ring and Spa.
205 GTI6 S
Posted 17th May 2008 at 21:02
fletch
Track Head
Post #81
Good effort Garry! How did you get on withe Spa and the ring?
Posted 17th May 2008 at 22:34
garry
Post #82
The weekend was a bit of a disaster, too much too soon to be honest.
We got there ok, I somehow lost my oil filler cap on the Friday night so we had to stop off at a pug garage in Folkstone before catching the ferry to get a replacement.
The weekend was very busy, we had to queue for 2 hours just to get on the track! I managed half a lap and this happened:
The oil cooler feed pipe burst going into Breidsheid bridge (Adenau bridge). Luckily I could get straight of the track. It was a very unpleasant experience though, there was a swarm of people looking all over my car which was now covered in oil. What was worse I had to sit and wait to see if anybody had an accident on 'my' oil knowing I would be accountable for the consequences! Blink
Luckily nothing happened and I got away with a 20E fine.
After that I didn't go on track again and didn't go to Spa, I decided to quit whilst I was ahead and head home.
205 GTI6 S
Posted 19th May 2008 at 16:45
barry.rs
Post #83
Gutted for you Gary Sad
Posted 19th May 2008 at 16:56
cosmic spanner
Moral objector
Post #84
harsh luck Mellow
But you still have a big Thumbs up for pulling out all the stops, getting it running and trekking straight over there - and if it's any consolation, as you know if it could have happened anywhere while on the lap right by Breidscheid has got to be the "least bad" place..
Focusing on the positives: what was it like for the half a lap up til that point? Superman I'd imagine! Big grin
Democracy is two wolves and a lamb voting on what to have for lunch..
..Liberty is a well-armed lamb contesting the vote.
Project é - my 306 project thread.
Posted 19th May 2008 at 17:18
dave
Post #85
Gutted, so close!
Back to the garage for some repairs and then head off again mate for attempt number 2.
As said above good effort and amazing levels of commitment with this project Thumbs up
Posted 19th May 2008 at 17:26
garry
Post #86
I am not bitter about it, I did the 'running in' in one swoop. And as you say it was the best place for it to happen!
It was absoultely flying before it went though! The most noticeable benefit with so much power on tap is the grip generated, just turn in and it just drags you round, with little if any understeer.
205 GTI6 S
dean.skerratt Banned!
Post #87
do you not have any vids
Team sc'd
Posted 19th May 2008 at 21:15
garry
Post #88
Not of half a lap, no.
205 GTI6 S
Posted 19th May 2008 at 22:24
dr-evil
Post #89
You and everyone involved have done an awesome job of wedging a quart into a pint pot - good luck with the shake down and hope to hear it at fcs
Cad Monkey will work for chocolate biscuits....I'm not kidding
Posted 20th May 2008 at 01:12
mechanical_repairs
Post #90
Gutted for you mate, at least you never had an accident or killed the engine.
Carl
Posted 20th May 2008 at 05:16
rich_w
Post #91
Garry,
Any news on why the oil cooler pipe split / oil-filler cap blew off?
How's it running now?
Sorry your trip was a bit of a waste of time - I guess things were all a bit last minute - it would have been nice to do a few hundred road miles to make sure she was 110% before going to Germany.
Glad to hear it's flying though - when you're next down around Slough I'll come up for a ride in it! Big grin
Contact Details:
07732 822546
Posted 20th May 2008 at 17:07
garry
Post #92
No answers yet.
Compression test on Friday morning before going to DES to get the new exhaust.
I will go back to the supplier with the hose and show them, see what they say.
I have bought 2 new oil filler caps, one will be a permanent spare attached to the key ring!
I don't want to go through that again!
I fixed the speedo at the weekend and fitted some bonnet pins.
There is a bit of a squeak coming from the charger belt and a bit of belt dust too, maybe I have it too tight? I will try slackening off one of the top pullies to see if it helps.
It spins up in second and struggles a bit in third too. You really have to hang on as the diff fights for grip! Speedo flies round though!
Next outing is Croft on the 21st June and then back to the ring and Spa in July.
I am also looking into some modified 406 drive shafts (probably similar to the 306) as they are much thicker than the 205/309 ones.
205 GTI6 S
Posted 20th May 2008 at 18:05
sarthe82
Post #93
Fantastic effort mate, real p*sser you couldn't get more track time, roll on July 'eh! Thumbs up
Steve Big grin
Posted 20th May 2008 at 19:25
gti6loon
Post #94
Sorry to hear about your bad luck garry. I'll be looking forward to seeing your 205 over here in july though.
I know what you mean about the Q's onto the track at weekends. For anyone who's got a weekend planned for the summer, i'll give you a heads up that it is busier this year than ever before. Nurburgring gmbh are now running a 3rd ticket barrier for cars out on the track, on the other side of the fence to the existing barriers, in order to cope with the amount of vehicles at the weekends. Most of you will know that the barriers act as a natural 'choking' point to limit the amount of cars on the track. Obviously with the extra barrier there is a greater amout of cars on the track basically resulting in more overtaking, or being overtaken, more accidents and generally a bit less fun.Sad
Take heed, and to anyone who is planning a trip but not yet booked, i would honestly say you would get more laps done on either a monday or friday half session, combined with a nice quite evening session on the tuesday or thursday, than you would get over a weekend with the current volume of weekend visitors.
Steve
Steve
Planning a ring trip? Why not stay at Hotel Burgstube
Posted 20th May 2008 at 20:01
dangerous dave
Post #95
10 out of 10 on the hero status, though you are mental!
TBH, I'm not sure how it would have come out if someone had spun on your oil, it would have surely gone down as "bad luck matey" as the flags would have been out to warn people, you'd done the right thing and stopped + told the marshals
When it's all sorted that will be one epic car
You didn't see anything. Right?
Posted 20th May 2008 at 20:03
garry
Post #96
I am not so sure Dave, as far as I see it the rules are quite simple, cause and effect. I dropped the oil, they crashed, end of!
They wouldn't actually flag it either as they said it was too dangerous!
There was a brit jag later on in the day that dropped oil, 4 cars and 4 bikes come off. The driver was arrested!
You REALLY need to think about these things, its big boys rules out there. Something we are not conditioned to here in the UK.
205 GTI6 S
Posted 20th May 2008 at 20:47
rich_w
Post #97
Garry;
I can't see compression being a problem.
If it was suffering blow-by severe enough to blow the oil cap, it wouldn't idle, it would be pouring blue smoke out the arse-end, and it would be emptying copious amounts of shite into your 'catch-tank' [which would also be heavily pressurised].
You have none of the above.
My betting is you left the oil cap off, or it had a weak spring in it, and as for the oil pipe, I think that must have had a defect or been damaged during the installation.
Watch the belt dust build-up - this is an excellent indicator of belt slip and belt alignment.
You always get a little dust though.
Excessive dust could mean the belt's over tensioned [remember you get 'belt orbit' at high speeds, a process where centrifugal forces make the belt take a longer route], you have excessive belt slip, or the is mis-alignment somewhere.
Try slackening it off slighty, but watch it.
Also check the alignment. I've found the PAS hardest to align - on some cars we have to shim the brackets with washers to correctly align it with the belt. This isn't due to my w*nky engineering skills - it's due to the fact the sump isn't located on dowels - and it's position can vary from one car to the next. Were only talking 1mm or so, but it's enough to upset a belt at 7,500 RPM.
The reason you don't get this problem with the A/C pump on the sump is because it has a 'shouldered' pulley. Also the loads on the belt are a lot less without the SC.
The car sounds like a complete animal though! Looking forward to a ride. Although it lights up the wheels, what is the driveability like with a bit of throttle control? I would imagine it could be tamed.
Do you think we'll be able to convert many of the 'traditionalists' from 205gtidrivers away from there Mi16's, S16's and TT conversions towards the Rotrex SC conversion??
Are you happy with the end result?
When Dave Potter [easypug] pulls his finger out and puts 350-400hp of SC'd power in his 205 it should be interesting!!
That thing will be suicidal Devil Ninja
Contact Details:
07732 822546
Posted 20th May 2008 at 21:06
gti6loon
Post #98
I would have actually told the marshalls to f-off, and gone running back up the track waving a red and yellow flag anyway. Imagine standing watching as a biker slides into adenau bridge on your oil spill.
Steve
Posted 22nd May 2008 at 00:09
*arctic*
Post #99
awesome project Garry ! congratulations ! Did you remap the ecu or running on std maps ????
306 Gti Imola Yellow
Dino run VDO
Posted 22nd May 2008 at 23:27
garry
Post #100
Thanks arctic, ecu has been remapped. It has to be to run the 440 cc injectors.
205 GTI6 S
Posted 23rd May 2008 at 00:40
