displaying posts 151 to 175 of 643
Pages (26): first .. 6 [7] 8 .. last
Author Subject: Project PUG
chris with a pug
Post #151
So left the head in the solution for a few days and it cleaned up all the waterways and stuff very nicely.
We then took it to Daveyboys workshop and he started to work his magic.
First off, matched the ports to the gasket, only a few mil was needed to be taken off.
Then the dye grinder came out and the ports had a good smoothing and sorting.
Threw myold Exhuast gasket out so couldnt really do much on the those ports, but ordering one tomorrow I think and then can finish this off.
Then will be sending it to get cleaned and skimmed and can then put it back togther.
Also ordered the rest of my fuel pipe and can fit that one night this week
Posted 28th Oct 2008 at 17:52
Post #152
Head will be finished by the weekend mate. Did you get a quote for replacement guides yet?
Posted 29th Oct 2008 at 22:53
chris with a pug
Post #153
No, will just send it to banda,did you get the gasket set then?
Posted 30th Oct 2008 at 03:48
alfiebaldwin
Post #154
Looking awsome! wish i had the money to do this kind of thing!
keep the pictures coming
alfi baldwin
Posted 9th Nov 2008 at 00:00
Post #155
You can just see the dent in the head Chris managed to put in it,getting the valve guides out! (Right on the edge of the combustion chamber) Doh!Razz
Posted 20th Nov 2008 at 23:58
fletch
Track Head
Post #156
I'm coming to the conclusion that you should step away from the car Chris! Laugh
Posted 21st Nov 2008 at 05:34
chris with a pug
Post #157
Its fine, all the work I have done and thats two mistakes, both easily fixable, will update this thread when I get home from Hull
Posted 21st Nov 2008 at 16:34
chris with a pug
Post #158
So Spent a day on the car today, first off I raised it up further on its axel stands so I can get underneath it to underseal it and fit the p clips I got from pertex for the new fuel pipes.
Next I started removing the dash, half way through so wish I never started, but after a lot of swearing and finding all the litttle screws. finally got it out.
But I unbolted the heater box too, does anyone know if all none a/c boxes are the same?
or do I need one off a rallye?
Posted 8th Dec 2008 at 22:48
Post #159
my dash did my f*cking head in. i've had it out twice and the third time i can't f*cking remember what to remove on the driver side corner to get it to release! think it's that big multiplug, i forget
Posted 8th Dec 2008 at 23:43
chris with a pug
Post #160
I was there for well over an hour it was loose but wouldnt come away, it was two tiny torex screws for the heater, was not happy
Posted 8th Dec 2008 at 23:44
Post #161
wouldn't mind i have nothing behind the dash either LOL heater and all the matrix etc is gone
Posted 9th Dec 2008 at 00:25
chris with a pug
Post #162
How do you get on with that?
I am thinking of doing the same thing and then make a custom dash out of alloy and install 2 de misters
Posted 9th Dec 2008 at 00:47
Post #163
Where did you find the electric heaters Chris?
Posted 10th Dec 2008 at 05:19
Post #164
CBS do a couple of nice little ones.
Posted 10th Dec 2008 at 05:25
midlife
Post #165
Come on Phillip, spill the beansNo No
Cool
Team 330™Cool
Team "no front end or engine"
Posted 10th Dec 2008 at 05:33
Post #166
I'm too nice to you lot
Got 2 of those in Marks new car and they clear the screen within about 30 seconds.
Posted 10th Dec 2008 at 05:35
midlife
Post #167
Just ordered a pair, cheers PhillipThumbs up
Cool
Team 330™Cool
Posted 10th Dec 2008 at 05:47
Post #168
LOL
Been hunting for a while have you?
Posted 10th Dec 2008 at 05:48
midlife
Post #169
Been looking everywhereDoh
Cool
Team 330™Cool
Posted 10th Dec 2008 at 05:53
Post #170
Doh
Make sure you get them right against the windscreen, they don't have the oomph of a normal heater, but then they don't weigh 14 tons either...LOL
Posted 10th Dec 2008 at 05:56
chris with a pug
Post #171
They are the ones I am getting phil, glad you recomend
Posted 10th Dec 2008 at 21:49
chris with a pug
Post #172
So had another productive day today.
First job was to remove the heater box, as I had already unbolted it yesterday didnt take very long.
I first throught I would remove the plate that holds the servo and pedals so first off I removed the servo and steering column, just ofr further reference the nuts/bolts combo things are left hand thread
but once all that was off, I found out they bond them in so instead of cutting it out, I got some apoxy metal stuff and made up a plate and stuck it on, instead of getting it welded.
the stuff looks pretty strong and as I am a tart gave it all a paint so it looks good
Plate was made from my trusty transit cut out
I am going to use this method to do the waste pipe hole for the heater and the air intake hole too
so while I was waiting for the paint to dry and stuff, I stripped the dash
First out came the loom
then I took out the ducting, its all plastic welded togehter so drilled out the rivots and it pulled apart quiet easily
After thinking about it, I am going to keep this dash and get it covered as making one will be a right ball ache.
As I now have a spot weld drill I started removing some of the fittings
The only trouble with this time of year is it gets dark at 4 so have to stop, but at least it keeps your drink cold
Posted 10th Dec 2008 at 22:36
Post #173
Somebody's been busy...Big grin
Posted 11th Dec 2008 at 03:16
puglover Banned!
Post #174
just get a heated screen Roll eyes
Posted 11th Dec 2008 at 03:19
chris with a pug
Post #175
where from?
Posted 11th Dec 2008 at 03:21
