Try http://www.heatedwindscreen.com/acatalog/peugeot.html I had one of theirs in a Rover Metro of mine, it worked very well.
Tim
| Author | Subject: Project PUG |
kman1600
Regular Location: Eglinton Registered: 13 Feb 2007 Posts: 104 Status: Offline |
Post #176
Hi,Try http://www.heatedwindscreen.com/acatalog/peugeot.html I had one of theirs in a Rover Metro of mine, it worked very well. Tim |
stu
Seasoned Pro Location: Milton Keynes Registered: 22 Aug 2006 Posts: 5,525 Status: Offline |
Post #177
Heated Screen Clicky |
chris with a pug
Seasoned Pro Location: Southampton Registered: 16 Feb 2003 Posts: 5,366 Status: Offline |
Post #178
Do they come with the kit to wire them in? |
kman1600
Post #179
Hi,Nothing special needed to wire them in, I actually used the wiring for the rear heated screen for mine. Sprint car so why would be looking out the back ![]() Relay or high amp switch is all you need. Tim |
chris with a pug
Post #180
that might be a better idea than using the blowers |
kman1600
Post #181
Hi,I don |
chris with a pug
Post #182
So another day on the car,First off I refitted the servo, took it off because i thought the gromit goes through the bulk head, but it doesnt it goes through the sound deadening. But all done after a little swearing ![]() then got the steering column refitted, this was a lot easier, but the big rubber gromit is a bit fiddley to get in but all sorted. So then set about cutting down the loom from the dash, I plugged in all the stuff from the dash and heater and stuff, I then cut off the ones for the heaters radio etc. ![]() ![]() I have now decided to run the fuel pipes through the cab as I think it will be so much easier and will not have the problem of getting round the rear beam. ![]() but cant finish running them until I remove all the sound deadening off the floor, so set about doing that, I got the drivers footwell and a bit of the rear footwell done but the light beat me, my weapon of choice was a chissel and it worked a treat. ![]() Need to get a load done tomorrow as cant do any over the weekend |
rikky
Post #183
what you should do is pull the entire loom from inside out, and lay it all out and locate the plugs that aren't needed or used anymore, and remove them spade terminals from the plugs and trace them back as far as you can. i have done this with all of mien and have cut the loom down about 75% and it's not got anything 'chopped off' as such, but properly isolated and removed from each end. you'll save a lot more time finding what's not needed this way and also save more weight!every unused wire from my car is sat in a box in the garage and there's about 30kg, and more has been removed since ________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
chris with a pug
Post #184
I only chopped the connecters off that wasnt needed anymore i traced all the wires back to the plugs.What did you remove to loose 75 %? I am keeping the central locking and alarm |
rikky
Post #185
everything basically electrical! alarm has gone, central locking all gone, whole door and electric window loom, electric mirror loom, all the stuff running to the fusebox, all speaker wiring and headunit wiring, all rear wiper and heated windscreen electrics, all interior unused wiring plugs near the rear quarter card, all foglight wiring. my entire interior wiring loom is fuel pump and rear light cluster, nothing else atall. am in the process of removing the abs and rerouting brake pipes inside, so all the abs loom from the engine bay/fusebox and underneath the car has gone, including abs unit obviously [and all the f*cking brake pipe].. loads more tbh depends where you're using the car i guess, i've got no intention of using mine on the road ________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
chris with a pug
Post #186
I will be doing similar, I need to re route the heated rear to the front though |
rikky
Post #187
i'm just buying a heater from CBS, someone posted a link to the same one i'm getting anyway the other day on here, they just mount in the dash and have a little independent switch________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
chris with a pug
Post #188
I was thinking of those, but a heated screen is going to weigh less and I need a new one anyway so it makes sence |
rikky
Post #189
yeah can get a decent one for ________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
chris with a pug
Post #190
I thought the heated screens where glass anyways |
chris with a pug
Post #191
there are on the page before this |
midlife
Seasoned Pro Location: Colne, Lancashire Registered: 13 Mar 2006 Posts: 7,544 Status: Offline |
Post #192
phillipm wrote: I'm too nice to you lot Got 2 of those in Marks new car and they clear the screen within about 30 seconds. midlife wrote: Just ordered a pair, cheers Phillip ![]() Well they have turned up, ordered at 1am on wednesday morning & delivered at 11am thursday morning. Bloody good service that, cheers for the tip off Phillip ![]() ![]() ![]() ________________________________________ Get used to seeing the yellow one !!!![]() ![]() ![]() ![]() ![]() Team 330™ ![]() Team "no front end or engine" Team "LIMITED EDITION" I live for the 306 sticker ![]() Team 0-60 in 6.44 & standing qtr in 14.808 @ 94.55mph all with std engine ![]() 203bhp Corolla T-Sport daily driver stealthier than Kwai Chang Caine |
chris with a pug
Post #193
how heavy are they? |
rikky
Post #194
pics not working, all i can see is females ![]() are the heated windscreens glass? http://www.heatedwindscreen.com/acatalog/peugeot.html edit: these are the ones i found anyway when searching for ricky evans motorsport by pure chance ![]() ________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
chris with a pug
Post #195
yeah thats the ones, I tried to email thewm but there site email thing not working |
Welly
Forum AdminLocation: Brizzle Registered: 11 Jan 2004 Posts: 21,796 Status: Offline |
Post #196
Please tell me this is just tempory and your going to fit proper bulkhead connectors if this is fuel?![]() ________________________________________ Life is a lie. The only certainty of which is death. Go live and enjoy yourself. The clock is tickingVrs power!! |
chris with a pug
Post #197
what the hell are bulk head conectors? the hose is fine like that I though |
midlife
Post #198
chris with a pug wrote: how heavy are they? They weigh bugger all, the wireing loom & switch weighs more than the blower unit. The bonus these have over a heated screen is that they will put some heat into the car on a cold morning. ![]() ________________________________________ Get used to seeing the yellow one !!!![]() ![]() ![]() ![]() ![]() Team 330™ ![]() Team "no front end or engine" Team "LIMITED EDITION" I live for the 306 sticker ![]() Team 0-60 in 6.44 & standing qtr in 14.808 @ 94.55mph all with std engine ![]() 203bhp Corolla T-Sport daily driver stealthier than Kwai Chang Caine |
Welly
Post #199
chris with a pug wrote: what the hell are bulk head conectors? the hose is fine like that I though Remember that little fuel incident you had a few weeks back? You'll have another. if your involved in an accident, or run off on the track onto gravel. Your hose runs the risk of getting trapped and splitting. Ripping the hose and spraying fuel everywhere when it rips on the metal. Bulkhead connectors SHOULD be used whenever transporting any fluid through the car. But hey, it's your car. ________________________________________ Life is a lie. The only certainty of which is death. Go live and enjoy yourself. The clock is tickingVrs power!! |
chris with a pug
Post #200
what are they? I made gromits up so the hose wont rub |
