Post #474
Well I havent updated this for ages, but I thought I should now.
Still getting bit. And here is some of my recent purchases.
Feeling sorry for Jim my expert fabricator and the grief we are having with the cage, I ordered a bucket seat mounting kit from tweaks to make his life a bit easier.
But as you know you cant just order one thing once you get on the web site, so I also ordered this, which will sit under the bonnet incase my bat goes flat and also its just easier to jump off than climbing behind the seat.
and also some anchor plates for the eyelets for the harnesses
I also put an order in to frosts for some radiator black (see the pic later in the thread)
Some underseal remover, some plasticgauge and some heat reflective stuff so I can use this instead of heat sheilds
But for 60 quid for that its a bit expensive.
I want to get the car rolling as soon as possible so I have sent my trailing arms off to Bridge craft engineering to have 3degs of negative camber machined into them.
I also odered this little lot
That is 25mm torsion bars and a 30mm ARB.
I need to put some earth points into the car so I brought a bag of weld in nuts for this.
So I set about yesterday to sort out stealthing my intercooler, and to be honest I think it looks better in satin black than natural.
Before
after
after 1 coat
after the second coat
I do love the stealth look.
I then did the same to the oil cooler
but forgot the after pic DOH.
And now for the cage!!
Now once they are fitted, there is no arguments they are so much better than a bolt in Jobbie, but OMG what a pain to get it in.
None of the rear stays are right, the A pillar bits are wrong, its mental.
But we will get there, its just gonna take a whole heap of time.
