Post #379
So got up bright and early this morining and Dave came over and he had a good go at some more of the body work, it really is starting to get there now.
Forgot to take any photos.
I got on with getting the oil cooler and intercooler mounted.
Fist off I refitted the slam panel and rad.
I had to unscrew the loom under the cross member (didnt wanna drill through it
I then used the spacers supplied with the cooler and the two plates they supply, but the slots are not big enough for the bolts for the intercooler to go though, so had to file them out.
then fitted the cooler
then fitted the bumper to check clearance
the good thing with using the mounting plates supplied, is that there is so much room to move the cooler.
It can be moved 2 inches either side, or six inches backwards,
then the biggest pain in the arse job of the day, fitting the oil cooler.
What a ball ache, so much fiddling but its all fitted now
I used one of the bolts that holds the bumper on to hold the bracket for the left side of the cooler, I thought that was pretty genius
With the cut offs from those 2 fixings I made the supports for the top, they will be welded on, just need to speak to jim as to the best way to do it.
that looks pretty mean like that, but will be getting a badged carbon bonnet from NUR.
and with the rad fitted
I did a little prep work today on a bumper I brought (my idea or mint and other peoples is very different) but its getting there now
and I finsihed off by seam sealing the rear panel
Its starting to take shape now.
