displaying posts 351 to 375 of 643
Pages (26): first .. 14 [15] 16 .. last
Author Subject: Project PUG
chris with a pug
Post #351
Collected I think.
Posted 4th Mar 2010 at 23:19
clen666
Post #352
I thought it would be, tbh I'd rather collect it than risk some p*ssed off delivery driver throwing it around! Just a little far for me to travel Sad
Team 'unintentional rat look'
Posted 5th Mar 2010 at 00:22
chris with a pug
Post #353
I suppose, but its not like metal and wont dent too easily
Posted 5th Mar 2010 at 01:27
clen666
Post #354
true, I'll look into it......Ninja
anyway, get some more pics up!
Posted 5th Mar 2010 at 02:05
chris with a pug
Post #355
I will do sat, got my new camara phone to try out!
Posted 5th Mar 2010 at 02:07
clen666
Post #356
Good man!
Posted 5th Mar 2010 at 02:11
chris with a pug
Post #357
Was A nice today today, so set about doing somework on the car. My body guy let me down again so I got on with some other jobs.
First thing was to remove the rear hubs, I brought a hub puller from Halfords last weekend and it did the job, but the races did split so will need new bearings, but I was expecting that.
I then heated up the race that was still on the stub axle and tried to knock it off with a drift, but it wasnt working too well, so I had a genius Idea and unbolted the caliper brackets and knocked them off with that, worked a treat, except one of the bolts snapped so so i drilled a hole in it and beat a old torque into it and it came out.
So now I seem to have this desease most rallye drivers have and need to save weight I cut off the part of the bracket that holds the ABS sensor.
Before
cutting off the bits
After that I give them a good spray of degreaser
Washed them off and gave them a lick of paint
Also I attatched the loom back into the dash
and terminated the wires in the engine fuse box
And I fitted my new oil catch tank
I then set about fitting the dash in the car, and finding a way to mount it.
I am still not sure on how I will do it on the top yet, but want do much until the cage is fitted as the dash bar runs close to where it will be mounted.
Cant really drive arround like this, but it held it in place while I made a support bracket for underneath.
Out came my trusted transit side
cut out a bit and marked out what I wanted
I then painted and fitted it, there are two holes on the botom of the dash that where used but not any more, was a bit picky usig wood screws, but you cant really see them and they do the job
And the dash fitted
The dash was such a pain in the arse, very stress ful, next time would ask for an assistant
And lastly I fitted the swirl pot
Posted 7th Mar 2010 at 01:10
jimmy_boy
Post #358
Nice update and some good progress Cool
You got the cage on order?
GTI-6 & Rallye
Rallye gets sideways in the wet at Snetterton Ninja
Posted 7th Mar 2010 at 01:16
chris with a pug
Post #359
not yet, I spent 500 quid this month on the rear tailgate, catches, bumper, PTFE gasket and oil catch tank.
So will order it the beginning of next month.
Posted 7th Mar 2010 at 01:19
chris with a pug
Post #360
Forgot to add, I text rich and he is going to unlock my ecu so out came the transponder.
Posted 7th Mar 2010 at 01:20
chris with a pug
Post #361
Was a lovely day today, and thought I would have ago at some of the body work on the car, 2 hours later covered in dust and more p*ssed off than when I started, I turned my attention to some of the other jobs.
I was so fed up of filing out holes I went to machine mart and brought my self a set of these.
They are bloody brilliant and so much easier.
I then cut 2 holes for the wires going through the bulk head.
I then set about getting the bulk head fixings fitted in the boot floor
The bulk head fittings need a washer as the bolt does not come all the way down the shaft, so had to drill them out too.
and I then fitted the fittings to the fuel pump
And my god they do the fittings up tight.
will get that fitted this week hopefully.
Posted 8th Mar 2010 at 00:45
Post #362
the cage bar should be about 4" lower than the dash mount holes ideally. mine runs right through the steering column housing - you ever tried removing the brake switch with a cage bar through the hole? Laugh my ass off and make sure you cut some grooves outta the column surround FIRST if you're gonna put the bar through it.. mine was fitted through the steering column housing and then when i needed to remove it i completely overlooked that i wouldn't be able to! so had to cut a slit out of each side so it'd pull free
Posted 8th Mar 2010 at 04:11
mabgti
NV motors
Post #363
looking good... goood choice for drillingYes
loving this projectBig grin
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 8th Mar 2010 at 04:31
chris with a pug
Post #364
LOL Ill bear that in mind.
Those holes wont be any good for mounting the dash I dont think, and I thought the dash bar was higher than that, thought they block those holes, might be easier if its that low!!
Posted 9th Mar 2010 at 03:31
Post #365
Posted 9th Mar 2010 at 05:22
Post #366
LOL
'S not a bad idea as it fires the dash and steering column away in a heavy front
Posted 9th Mar 2010 at 05:46
chris with a pug
Post #367
Thats where I thought it went, cant remember where Jims is
Posted 9th Mar 2010 at 13:58
Post #368
Mines not fully welded in yet as I want a curved one, instead of the straight piece of tube CC sent out.
Posted 9th Mar 2010 at 14:01
Post #369
LOL
Posted 9th Mar 2010 at 14:06
chris with a pug
Post #370
So whats your loom and all that cable tied to?
Posted 9th Mar 2010 at 14:18
Post #371
quote:
[quote="daveyboy"
Doh
If you'd have said earlier we could have bent you one up and dropped it off this weekend Mellow
Posted 10th Mar 2010 at 02:20
Post #372
The crappy dash bar they sent me, just tack welded in place temporarily.
Posted 10th Mar 2010 at 13:55
Post #373
phillipm wrote:
quote:
[quote="daveyboy"
Doh
Were you near Scumhampton at the weekenrd then? Doh!
Posted 10th Mar 2010 at 13:56
Post #374
Sidbury Hill on saturday, ringwood on sunday! Doh
Posted 10th Mar 2010 at 18:00
chris with a pug
Post #375
Are you feeling alright LOL
Posted 11th Mar 2010 at 01:29
